When I tried to burn an old home movie onto a blank disc, I was surprised to find several types of DVDs. Each looked identical, yet only one worked with my DVD burner. That experience made me realize how confusing DVD formats can be, especially when compatibility differs from one device to another.
If you've ever wondered which DVD format works best for recording, playback, or data storage, this guide will make things clearer. In the following sections, I'll explain the differences among all major DVD types, how they affect performance and compatibility, and which one you should use depending on your needs, whether that's burning videos, creating backups, or preserving movie collections.
Different types of DVD formats
Quick Answer: Which DVD Format Should You Use
  • For older DVD players: DVD-R, authored as DVD-Video and finalized.
  • For newer DVD players: DVD-R or DVD+R, depending on what the player accepts.
  • For test burns: DVD-RW or DVD+RW, because the disc can be erased and written again.
  • For computer file storage: DVD-R, DVD+R, or DVD-RAM, depending on the reader you plan to use.
  • For commercial movies or software: DVD-ROM, which is factory-pressed and read-only.
Below is a quick reference guide comparing the main DVD formats you'll encounter. Each format differs in write capability, reusability, compatibility, and ideal usage scenario.
Format Writable Rewritable Typical Capacity Playback compatibility Common use
DVD-R Yes (once) No 4.7 GB SL / 8.5 GB DL Strong on many older players when authored and finalized correctly Home movie DVDs, older players
DVD+R Yes (once) No 4.7 GB SL / 8.5 GB DL Works well on many newer players; book type settings may help some older players Movie DVDs, data discs, newer players
DVD-RW Yes Yes 4.7 GB Mixed; some older players reject rewritable media Test burns, temporary storage
DVD+RW Yes Yes 4.7 GB Mixed; better for testing than final movie discs Rewritable data discs, short tests
DVD-RAM Yes Yes Usually 4.7 GB Low in set-top DVD players Computer storage, some DVD recorders
DVD-ROM No No 4.7 GB / 8.5 GB Very high for pressed commercial discs Movies, games, software discs
NOTE: DVDFab DVD Ripper can read and convert any DVD format into high-quality digital files such as MP4, MKV, AVI, MOV, or WMV. It automatically removes region codes, CSS encryption, and copy restrictions. The software also supports multi-core CPU, GPU acceleration, enabling faster conversion speed without compromising quality.
Different Types of DVD Formats Explained
DVD-R
DVD-R (Digital Versatile Disc Recordable) is a generic recordable DVD format that looks like a traditional DVD but allows information to be written only once and read multiple times. DVD-R is a DVD format that is compatible with all recordable DVD formats. It can store up to 4.7 GB of information or media records on a primary disk and up to 8.5 GB on a double-layer disk. A disc can only be used once and cannot be used for re-recording whenever it is removed from the drive.
DVD+R
Released in 2002, described as DVD Plus R. It is a recordable DVD format similar to DVD-R but does not carry the DVD logo. It uses the ADIP method and is usually slightly more expensive than DVD-R. Playback compatibility with all DVD players has been improved to approximately 80%.
Quick tip: If your burner supports bitsetting, always enable it when using DVD+R—this can dramatically improve playback success across older devices.
DVD-RW and DVD+RW
DVD-RW and DVD+RW can be erased and written again. They are useful when you want to test a menu, check chapter points, or move temporary files.
They are not my first choice for a final movie disc. Older DVD players may reject rewritable media, and some players are sensitive to how the disc was recorded. For a final disc that you plan to give to someone else, use DVD-R or DVD+R instead.
DVD-RAM
DVD-RAM is the most technically advanced of all recordable formats. It supports true random access, built-in defect management, and an exceptional rewrite lifespan (up to 10,000 cycles). This makes it extremely reliable for data backup, professional archiving, and video recording devices like Panasonic camcorders or set-top recorders. However, DVD-RAM discs are not compatible with most standard DVD players or drives, and their availability has declined in recent years.
DVD-ROM
DVD-ROM is the factory-pressed, read-only format used for commercial movies, games, and software distribution. These discs cannot be burned or modified. Their universal compatibility makes them the standard for pre-recorded media. Every DVD player and drive can read DVD-ROM discs without issue.
DVD-R DL and DVD+R DL
DL means dual layer. These discs hold about 8.5 GB, compared with about 4.7 GB on a single-layer disc. Dual-layer discs can help when a movie is too long for a single-layer DVD. The trade-off is compatibility. Some players pause at the layer change, and low-quality blank media can cause read errors. If the disc must play in an older DVD player, a single-layer DVD-R with a shorter project is often safer.
While all DVD formats share the same disc size and storage capacity, their write behavior, reusability, and compatibility differ significantly. For everyday use, DVD+R remains the most reliable and available option, whereas DVD-RAM continues to lead in durability for archival storage.
Physical vs Logical DVD Formats
When people talk about DVD format, they often mix up two very different concepts: physical formats and logical formats. Understanding this distinction helps explain why two DVDs that look identical can behave very differently when you try to play or copy them.
Physical DVD Formats: The Disc Itself
The physical format refers to the type of disc you can hold in your hand, such as DVD-R, DVD-RW, DVD-RAM, or DVD-ROM. Each type determines how data is recorded onto the disc's surface, whether it can be rewritten, and how compatible it is with different drives.
DVD-R or DVD+R can store video, audio, or any digital data, but they serve merely as a carrier and are not the content format itself.
Logical DVD Formats: The Data Structure
The logical format defines how the data is organized and read by a computer or player.
Two main logical formats exist:
  • DVD-Video: Designed for film playback, it uses a specific folder structure (VIDEO_TS and AUDIO_TS) and the UDF 1.02 file system. This format is recognised by DVD players, ensuring smooth playback of menus, subtitles, and chapters.
  • DVD Data Disc: Used to store general files such as videos, documents, or images, similar to a USB drive. It usually uses UDF 1.5 or higher, which allows larger files and modern encoding formats.
File Systems Used in DVDs
DVDs can use several file systems to organize data:
  • UDF 1.02: Common for DVD-Video discs used in set-top DVD players.
  • UDF 1.5 or newer: Common for data discs and larger file storage.
  • ISO 9660 and Joliet: Older computer file systems sometimes used for backward compatibility.
  • UDF + ISO hybrid: A mixed structure that can improve reading on older computers and some players.
For movie playback, do not choose the file system manually unless your authoring tool asks for it. Use a DVD authoring mode or "Video DVD" mode instead of a plain data burn.
DVD-R vs DVD+R, DVD-5 vs DVD-9, and PAL vs NTSC: How They Work Together
DVD-R, DVD+R, DVD-5, DVD-9, PAL, and NTSC are often discussed together, but they do not describe the same thing. They belong to different parts of a DVD project.
Concept What it means User decision Example
DVD-R / DVD+R Recording disc type Which blank disc to buy Use DVD-R for many older players; use DVD+R when your player accepts it
DVD-5 / DVD-9 Capacity and layer type How much video the disc can hold DVD-5 holds about 4.7 GB; DVD-9 holds about 8.5 GB
PAL / NTSC Video standard Which region and player the video should match US DVD players usually expect NTSC
These labels can appear on the same disc. For example, a DVD-R DVD-5 NTSC disc means the disc is a write-once DVD-R, it has single-layer capacity, and the video is authored for NTSC playback. A DVD+R DL DVD-9 PAL disc means the disc is a write-once DVD+R dual-layer disc with PAL video.
💿 DVD-5 and DVD-9 are sometimes called DVD types, but they are more accurately capacity types. DVD-5 is a single-layer disc with about 4.7 GB of space. DVD-9 is a dual-layer disc with about 8.5 GB of space. A DVD-9 can hold longer video, but some older players are less reliable with burned dual-layer media.
💿 PAL and NTSC are not blank disc types. They describe the video standard used inside a DVD-Video project. For US playback, NTSC is the safer choice. If you create a PAL DVD for a US player, some older setups may show playback errors, wrong motion, or no picture.
For a US home DVD player, a practical starting point is DVD-R, DVD-5, NTSC, authored as DVD-Video, and finalized after burning. Use DVD-9 only when the video is too long for a single-layer disc, and test the target player before making more copies.
What is the best DVD format for DVD players?
For older DVD players, start with DVD-R. For newer players, DVD+R can also work well. In both cases, the disc should be authored as DVD-Video and finalized.
What DVD type should I use for burning movies to play on a DVD player?
For an older DVD player, start with DVD-R, DVD-5, NTSC, and DVD-Video authoring, then finalize the disc after burning. For newer players, DVD+R can also work, but test one disc before making more copies.
Do not simply copy an MP4 or MKV file to a blank DVD if you need normal DVD player playback. That creates a data DVD, not a DVD-Video disc. Use DVD authoring software and choose DVD-Video output.
Do I need to finalize a DVD-R or DVD+R?
Yes, if you want to play it on another DVD player. Finalization writes the closing information the player needs to read the disc as a completed DVD.
Understanding the different DVD formats helps you choose the right disc for recording, playback, or archiving. While physical media still serve valuable purposes, their lifespan and compatibility are limited. To ensure your movies, data, and memories remain accessible, converting discs to digital files with DVDFab DVD Ripper is a better solution.
