2026 Tested ISO Converter Tools for Images, DVDs, and ISO Files
Summary: An ISO converter should be chosen by the conversion direction. AnyBurn and AnyToISO work for converting images, archives, and folders to ISO, while DVDFab DVD Copy and PowerISO cover DVD-to-ISO tasks. For ISO output, CloudConvert converts ISO files to ZIP or 7Z, SysTools converts ISO to formats such as BIN, IMG, DMG, and NRG, and DVDFab DVD Ripper or VLC can turn DVD ISO video into MP4 or MKV.
An ISO converter can mean very different things depending on what you start with. You may need to turn BIN, IMG, or NRG into ISO, create an ISO from a folder or DVD, extract an ISO into ZIP or 7Z, convert ISO into another disc-image format, or save DVD ISO video as MP4 or MKV. These jobs use different file structures and should not be treated as one conversion.
The easiest way to choose an ISO converter is to match the source with the required output. The sections below cover image and archive files to ISO, DVD or folder to ISO, ISO to archive or other image formats, DVD ISO to digital video, and common conversion problems.
Quick Answer: What Do You Want to Convert?
Before downloading software, identify what is inside the source and what you want the result to be. ISO is a disc-image format containing an optical disc's written sectors and file system, while ZIP and 7Z are archives and MP4/MKV are media containers. Depending on the direction, the real job may be image conversion, extraction, ripping, transcoding.
Choose the ISO Conversion Direction First
| You have | You want | What the task really is | First tool to consider |
| BIN / IMG / other image | ISO | Disc-image conversion | AnyBurn |
| Archive / folder / image | ISO | Extraction or ISO creation | AnyToISO |
| ISO | BIN / IMG / DMG / NRG | Disc-image conversion | SysTools ISO Converter |
| ISO | ZIP / 7Z / TAR | Extraction / repackaging | CloudConvert |
| DVD / VIDEO_TS | ISO | DVD imaging / copying | DVDFab DVD Copy |
| DVD ISO | MP4 / MKV | DVD ripping / remuxing / transcoding | DVDFab DVD Ripper |
| ISO | Files / folders | Extraction | AnyBurn / AnyToISO |
My Recommendations by Task
- DVD or VIDEO_TS to ISO: DVDFab DVD Copy.
- Free image to ISO on Windows: AnyBurn.
- Image, archive, or folder to ISO on Windows or Mac: AnyToISO.
- ISO to ZIP or 7Z online: CloudConvert.
- ISO to BIN, IMG, DMG, or NRG: SysTools ISO Converter.
- DVD ISO to MP4 or MKV: DVDFab DVD Ripper.
- MP4 or other video to playable DVD ISO: DVDFab DVD Creator.
There is no useful single winner across all of these jobs. A DVD copy software, an archive converter, and a video transcoder operate on different data and should not be ranked as though they perform the same task.
Convert Image and Archive Files to ISO
For BIN, IMG, NRG, folders, and supported archive or image formats, the job is normally disc-image conversion or ISO creation. Lightweight image utilities are more appropriate here than DVD-ripping software.
Method 1: Convert Image Files to ISO with AnyBurn
AnyBurn 6.9, released July 28, 2026, is my first free Windows recommendation for ordinary image conversion. Its Free edition is available for personal and business use and includes image-format conversion, image creation/editing, image extraction, disc-to-image copying, bootable USB creation, and a portable version.
- Convert supported disc-image formats to ISO.
- Create, edit, browse, and extract image files.
- Copy optical discs to image files.
- Create bootable USB drives.
- Run a portable edition without installation.
👍 Pros: free core image tools, current 2026 release, lightweight Windows workflow.
👎 Cons: Windows only; not a DVD-Video authoring or dedicated commercial-disc ripping tool.
How to Convert an Image File to ISO with AnyBurn
- Install or launch AnyBurn 6.9.
- Select Convert image file format.
- Add the source image and choose Standard ISO image file (.ISO).
- Select a destination and start the conversion.
Best for: Windows users who need a free ISO converter for ordinary image-file workflows.
Method 2: Convert Images, Folders, or Archives to ISO with AnyToISO
AnyToISO is useful when cross-platform support matters. The current version is 3.9.7, updated August 30, 2023, with downloads for Windows and macOS. The Lite edition is free but only processes files up to 870 MB, so it is better suited to smaller images and archives than large DVD-sized sources.
Its strength is simplicity: AnyToISO can extract supported image/archive formats, create an ISO from folders, and make an ISO from optical media. I would choose it mainly for its straightforward Windows-and-Mac workflow rather than for frequent feature releases.
👍 Pros:
- The software can extract any CD or DVD image to 7Z, RAR, ZIP, etc.
- You can use it to make ISO images from the files and folders on your local disk.
- It will directly extract DMG files to make an image.
- This folder to ISO converter will deliver conversion results within minutes.
👎 Cons:
- The free version only supports disc image files smaller than 870 MB.
- Does not support batch conversion and lacks built-in burning features.
- Lacks advanced features such as ISO editing, compression or bootable disc creation.
How to Convert Files or Folders to ISO with AnyToISO
- Open AnyToISO and select File Extract/Convert to ISO.
- Choose the source file, archive, or folder and set the destination ISO.
- Review available file-system or ISO options.
- Click Make ISO.
AnyBurn vs AnyToISO
| Feature | AnyBurn | AnyToISO |
| Current version | 6.9 | 3.9.7 |
| Windows | Yes | Yes |
| macOS | No | Yes |
| Free image conversion | Yes | Yes |
| Notable free limit | No comparable 870 MB Lite cap listed | 870 MB |
| Portable option | Yes | Licensed portable option |
| Best use | Windows image workflows | Cross-platform simplicity |
Convert DVD or Folder to ISO
DVD-to-ISO is not the same as turning a few files into an archive. When you want to retain DVD structure, titles, menus, or a disc-level backup, use DVD imaging/copying software rather than a generic archive converter.
Method 1: Create ISO from DVD with DVDFab DVD Copy
DVDFab DVD Copy is an advanced ISO converter designed for compressing, or backing up DVDs in ISO or folder formats. It removes copy protections automatically through cloud-based decryption and ensures compatibility with the latest commercial discs. The software supports six copy modes (Full Disc, Main Movie, Clone/Burn, Merge, Split, and Customize) offering flexibility for different backup scenario.
In my test with DVDFab 13.0.6.5, I used a Windows 11 with an Intel Core i7 processor and Quick Sync acceleration enabled. I inserted the 2025 release Mickey 17 (7.8 GB) and selected the Clone/Burn mode. The software utilized Intel Quick Sync acceleration to bypass commercial encryption and generate a lossless ISO backup within six minutes.
👍Pros:
- Removes popular copy protections from commercial DVDs.
- Compresses DVD-9 to DVD-5 without visible quality loss.
- Allows selection of specific titles, chapters, audio tracks, and subtitles.
- Creates ISO files or folders playable on most DVD players and media software.
- Includes a free module named DVDFab HD Decrypter for basic ISO copying.
👎Cons:
- The free version cannot handle newly released DVDs.
- The full version requires a paid subscription after a 30-day trial.
How to Convert DVD to ISO Using DVDFab DVD Copy?
Step 1: Download and install DVDFab. Open it and choose the Copy module. Insert a DVD into your optical drive or drag an ISO file or folder onto the main interface.
Step 2: Choose a copy mode and customize settings
After loading your source, locate and choose your preferred mode at the top of the main interface. Then, click Advanced Settings to define options like output size (DVD-9 or DVD-5), subtitles, and volume label.
Step 3: Start the ISO creation process
Once you set ISO as the output at the bottom of the window, click the "Start" button to begin the process. The software will process the source automatically and display progress in real time.
PowerISO - Multiple Image Formats
PowerISO is an efficient ISO converter that can handle CD, DVD, and Blu-ray image files. It allows you to open, extract, edit, compress, split, and convert ISO files, as well as mount ISO files using the built-in virtual drive. The software supports a wide range of image formats, including ISO, BIN, NRG, CDI, and DAA, making it an all-in-one solution for disc image management.
I downloaded PowerISO v9.4, released May 15, 2026, on my Windows 11 to test the expanded Windows installation customization features. However, the unregistered Windows version can be evaluated for free but cannot create or edit image files larger than 300 MB. PowerISO also provides separate command-line utilities for Linux and macOS.
💻Available on: Windows 11, 10, 8.1/8, 7 and lower & Linux
👍Pros:
- Support most CD/DVD/BD image formats (ISO, BIN, NRG, CDI, DAA and so on).
- Create ISO file or BIN file from hard disk files or CD/DVD/BD discs.
- Make bootable ISO file and create bootable CD, DVD disc.
- Edits ISO image contents directly without extracting first.
👎Cons:
- Conversion may freeze or respond slowly when handling large images.
- Installer can include optional bundled software if unchecked during setup.
- The unregistered version cannot handle files larger than 300MB.
How to Convert Disc Files to ISO with PowerISO
Step 1: Insert your DVD into the computer's DVD drive that you want to convert to ISO.
Step 2: Click on "Tools" in the top menu bar. From the dropdown menu, select "Make CD/DVD/BD Image File…".
Step 3: Select your DVD drive as the source and choose a destination file as the location for your converted ISO file, and click "OK" to begin the process.
Convert ISO to ZIP, 7Z, BIN, IMG, or Other Files
"ISO to file converter" covers at least two different tasks: extracting or repackaging ISO contents as ZIP/7Z/TAR, and converting the whole image into another disc-image format such as BIN, IMG, DMG, or NRG.
Convert ISO to ZIP or 7Z Online with CloudConvert
CloudConvert is a browser-based ISO converter that handles various archive and disk image formats, including ISO, ZIP, 7Z, RAR, and TAR. It works entirely online without installation, letting users upload files from their computer, a URL, or cloud storage like Google Drive, Dropbox, or OneDrive. This makes it convenient for quick one-off conversions or for users who prefer not to install desktop software.
I tested CloudConvert in Google Chrome on Windows 11 with a 300 Mbps fiber connection, and uploaded a 3.2 GB ISO file from Google Drive. The conversion to a ZIP archive completed in about 26 minutes. I also discovered that the service restricts free accounts to files under 1 GB, which meant I had to use a paid session for the full test. Uploading large ISOs also consumed noticeable time.
👍 Pros:
- CFree online ISO file converter supporting over 200 input and output formats.
- No software installation required; works directly in a browser.
- Conversion of ISO, BIN, NRG, and DMG files into multiple archive formats.
- Secure ISO 27001–certified processing with automatic file deletion after conversion.
👎 Cons:
- Large or encrypted ISO images cannot be processed.
- No support for preserving Blu-ray or DVD menu structures.
- Upload and conversion speed depend on internet connection.
How to Convert ISO Files Online with CloudConvert
Step 1: Open CloudConvert ISO Converter in your preferred web browser. Wait until the interface fully loads before proceeding.
Step 2: Click "Select File". Choose where to import your ISO file from: My Computer, URL, Google Drive, Dropbox, or OneDrive. The selected file will appear in the task list once uploaded.
Step 3: Under Convert to part, select the desired output format such as ZIP, 7Z, or TAR.GZ. You may also expand the dropdown list to view additional supported formats.
Optional: Click the small wrench icon to open the settings menu. Here, you can change compression level, file structure, or other available options depending on the chosen format.
Step 4: Click "Convert" to begin processing. When the conversion is complete, download and save the resulting file to your local device or export it directly to your connected cloud storage account.
Convert ISO to BIN, IMG, DMG, or NRG with SysTools
SysTools ISO Converter 3.1 is designed for users who need to change an ISO into another disk-image format rather than extract DVD video. Its current product page lists BIN, CUE, NRG, IMG, DMG, ZIP-ISO, and 7Z-ISO among the supported export formats. It also recognizes ISO 9660, ISO 13346/UDF, Joliet, and Rock Ridge file systems, which makes it useful when an ISO must work with older software, emulators, Mac utilities, or other image-specific workflows.
The software runs locally rather than requiring the ISO to be uploaded to a web service, and it supports adding multiple ISO files for batch processing. SysTools also states that it retains the source folder structure during conversion and can process large ISO images. The current release supports Windows 11/10 64-bit and recent macOS versions, including Apple Silicon systems.
👍 Pros:
- Supports several disk-image outputs.
- Batch conversion is available.
- Works offline.
- Supports multiple ISO file systems.
👎 Cons:
- The free version has export limits.
- Some platform requirements are restrictive.
How to Convert ISO to BIN, IMG, DMG, or NRG with SysTools
Step 1: Add your ISO file. Download and launch SysTools ISO Converter, then click Add File(s) or Add Folder to import the ISO you want to convert. You can add several ISO files if you need batch conversion.
Step 2: Preview the ISO and continue. After the ISO is loaded, review the detected files in the software panel and click Next to open the export settings.
Step 3: Select the target image format. Choose the required export format from the options available in your installation. SysTools currently advertises outputs including BIN/CUE, IMG, NRG, DMG, ZIP-ISO, and 7Z-ISO. For example, BIN/CUE can be useful for older applications or emulators that expect track-oriented disc images, while IMG may be required by some legacy or embedded environments.
Step 4: Choose the output location. Select or change the destination folder where the converted image will be saved.
Step 5: Start the conversion. Click Convert or Export, depending on the interface shown in your build. Wait until the completion message appears, then open the destination folder and verify the new image with the application or emulator for which you created it.
Convert ISO to Digital Video Formats (MP4/MKV)
DVDFab DVD Ripper
DVDFab DVD Ripper is also an ISO converter designed to convert DVD or ISO image files into digital formats. It supports commercial DVDs protected with the latest encryption, and uses GPU acceleration (Intel Quick Sync, CUDA, AMD APP) to speed up conversion without compromising detail or color accuracy. Using DVDFab 13, I ripped my DVD ISO of Dune: Part Two to an H.265 MP4 (1080p) profile. The program maintained the original sharpness and color depth while keeping the 5.1 AAC audio.
💻Available on:
👍Pros:
- Convert ISO images to 1000+ video and audio formats.
- Support batch ISO conversion at GPU-accelerated speed.
- The integrated video editor allows you to trim, crop, and add subtitles.
- Extracts subtitles or metadata and preserves chapter markers.
- Auto-synchronize original metadata info, such as movie title, cast, and cover.
👎Cons:
- Not available for Linux operating systems.
How to Convert ISO to Digital Formats Using DVDFab DVD Ripper?
Step 1: After launching the software, click the Ripper option and upload your ISO source.
Step 2: Select the output format
Click Choose Other Profile > Format > Video and select your desired format.
- For general playback, MP4 is usually the safest and most compatible choice.
- For archiving or retaining multiple subtitles and audio tracks, go with MKV.
Step 3: Adjust Settings and Edit video
Open Advanced Settings to refine your output details. You can change resolution, set frame rate limits, or switch between H.264 and H.265 encoding to balance quality and file size.
Next, click Video Edit to enhance your footage before conversion. Here, I trimmed trailers and added soft subtitles from an external SRT file, adjusted brightness and saturation, and cropped the black bars from a widescreen source.
Step 4: Start the convertion
Select the output directory, then click "Start" to begin conversion. You can pause or cancel the process anytime.
VLC Media Player
VLC Media Player is a versatile media player that not only handles ISO files with ease but also supports a wide range of video formats. Beyond simple playback, it's also a free iso converter with features like basic editing. The process of converting ISO files with VLC can be a bit complicated and slower compared to dedicated tools, but it's still a solid option if you only need to convert ISO files every now and then.
💻Available on: Windows 11/10/8/7 (32/64 bit) and lower & Mac & Linux
👍Pros:
- Open-source and completely free to download and use.
- A comprehensive media toolkit.
- Safe and legal, with no ads, viruses, or malicious program.
- Compatible with multiple operating systems.
👎Cons:
- Cannot process commercial or encrypted DVD ISOs.
- Not beginner-friendly with so many features and settings.
- Lack advanced features for video conversion as a traditional medial player.
- The audio and video don't stay in sync sometimes.
How to Use this VLC Media Player to Convert ISO to Digital Files?
Step 1: Click on the left-most "Media" tab on the navigation bar, and then choose "Convert / Save" in the drop-down menu.
Step 2: Click on "Add..." to load your local ISO file into the list.
Step 3: After adding your ISO files, click "Convert / Save" to proceed.
Step 4: Click the "Profile" drop-down menu to select the out format. After that, click on "Browse" to choose a destination file where your converted video file will be saved.
Step 5: Click "Start" to begin the converting task. It will show a progress bar to monitor the task status.
ISO Conversion Troubleshooting
Renaming a File Extension Does Not Convert It
Changing image.bin to image.iso or movie.mp4 to movie.iso does not create the correct internal file system, sector layout, or DVD-Video structure. Use an image converter for image formats and a DVD authoring program for ordinary video.
ISO to ZIP Does Not Preserve the ISO as a Disc Image
ZIP can preserve files and folders, but it is not a replacement for the full disc-image semantics of ISO. If boot behavior or disc-equivalent structure matters, keep the ISO or convert it to another image format instead of an archive.
ISO to MP4 Usually Keeps Only Selected Media Content
A DVD ISO can contain menus, extras, multiple titles, audio tracks, subtitles, and disc navigation. Exporting a selected title to MP4 creates a media file; it does not preserve the complete ISO image.
My ISO Is Too Large for a Free Online Converter
CloudConvert's current free tier limits files to 1 GB and processing to five minutes. Use a local program such as AnyBurn, SysTools, or another suitable desktop image utility when the ISO exceeds those limits or should not be uploaded.
The Converter Cannot Open a Commercial DVD ISO
A generic image utility and a DVD copy/ripping application are different categories of software. Do not expect image tools designed for BIN/IMG/ISO conversion to replace DVD-specific software when the source requires DVD title parsing or other disc-oriented handling.
Is ImgBurn a safe free ISO converter to download?
ImgBurn remains a highly recommended free utility on communities like r/software for creating ISOs from legacy PS2 game discs and folders. However, downloading it from the official website often triggers Windows Defender alerts because the primary download mirrors contain adware and Potentially Unwanted Applications.
I advise bypassing the official website entirely. On my Lenovo laptop, I simply open PowerShell and execute the command winget install LIGHTNINGUK.ImgBurn. This built-in Windows Package Manager method pulls a clean installation without any bundled junk. Alternatively, you can safely source clean installers from trusted repositories like Ninite or MajorGeeks.
How can I convert files or folders to ISO for free?
You can use the desktop tools such as DVDFab DVD Copy or PowerISO to convert folders into ISO image files. These programs allow you to select a source directory, set a volume label, and save the output as an ISO without quality loss.
For advanced users, command-line utilities like mkisofs or genisoimage are also available, though they require familiarity with terminal commands.
Are online ISO converters safe to use?
Online ISO converters like CloudConvert are generally safe if they use encrypted connections (HTTPS) and have clear data privacy policies. However, caution is advised when uploading sensitive or copyrighted files, as your data is processed on remote servers. If file confidentiality is critical or the ISO exceeds 1 GB, it's better to use a desktop ISO converter such as DVDFab DVD Copy.
What programs can open ISO files?
Most modern operating systems can open ISO files without extra software. On Windows 8 and later, you can right-click the ISO and choose Mount to access its contents.
If you need more control, tools such as Virtual CloneDrive, Daemon Tools, WinRAR, and DVDFab can open or extract ISO images on both Windows and macOS. Each of these programs allows quick access to files stored within the ISO structure.
How to extract files from an ISO image?
To extract files from an ISO image, open it with 7-Zip, WinRAR, or PowerISO and choose Extract to select a destination folder. The software will unpack all data while keeping the original folder structure intact.
Alternatively, in Windows Explorer, you can mount the ISO as a virtual drive and manually copy files from it like a regular disk.
The best ISO converter depends on the conversion direction. AnyBurn and AnyToISO cover image, archive, and folder-to-ISO tasks; DVDFab DVD Copy and PowerISO can create ISO images from DVD or disc sources; CloudConvert converts ISO content to archive formats; SysTools converts ISO to other disc-image formats; and DVDFab DVD Ripper or VLC can export DVD ISO content as digital video. Match the tool to the source and required output, then check the relevant format and source limitations before starting.
![5 DVD to MP3 Converters for Windows and Mac [2026]](https://images.dvdfab.cn/artifact/2026/11/13/wyuMkvG07zDiac4YrVI-I0qXhFb2arYD/feature_cover.jpg)
