8 Best Free ISO Burners for Windows and Mac in 2026: Tested Picks
Summary: This guide brings together the best free ISO burners for Windows and Mac, covering simple tools for quick ISO burning as well as feature-rich options. Based on hands-on comparisons, DVDFab DVD Copy stands out as the most capable overall choice, while Free ISO Burner and ImgBurn remain reliable free alternatives for straightforward burning tasks.
The quick takeaway: choose a disc burner for physical CD, DVD, or Blu-ray media, a USB utility for an installer drive, and an ISO mount for file access. Windows has a built-in baseline, while dedicated tools add controls such as verification, speed selection, or DVD compression.
When an ISO Burner Makes Sense
Start with the medium: a disc burner writes to CD, DVD, or Blu-ray, while mounting, USB flashing, and ISO creation solve different jobs.
You need an ISO burner when an image file must become a physical disc, such as an operating-system installer or a DVD for a player without USB input. Mounting an ISO with virtual drive software is faster when you only need to open its files. The distinction between disc burning vs USB flashing matters: USB flashing prepares removable installation media, while disc burning writes an image to CD, DVD, or Blu-ray media. Creating an ISO creator image is different again from writing one to media.
Writing an ISO also does not author a DVD-Video disc; the image must already contain the required disc structure. That distinction matters before you choose a burner, because failed playback is often caused by the image layout or target media, not by the burn button itself.
My Top Picks: ISO Burner Options by Use Case
Best for a prepared Windows ISO: Windows Disc Image Burner
- Best for: a single prepared image that already has the right structure.
- Not ideal for: jobs where you need detailed burn settings, post-burn verification, or broader image management.
Best current Windows utility: Active@ ISO Burner
- Best for: Windows users who want a maintained, image-focused program with adjustable burn settings.
- Not ideal for: Mac work, DVD authoring, or DVD structure changes before writing.
Best for DVD copy and compression: DVDFab DVD Copy
- Best for: authorized protected DVD projects that need DVD-9 to DVD-5 compression, title-level selection, or queued copy tasks across Windows and macOS.
- Not ideal for: an already prepared ISO that only needs one basic write.
Legacy tools: ImgBurn and Free ISO Burner
ImgBurn offers detailed controls, while Free ISO Burner keeps the interface small. Both are older utilities, so download provenance and maintenance status deserve more weight than their feature lists.
Testing Method and Results
What We Checked
The checks focused on the decisions that change an ISO burn result: supported platform, prepared ISO handling, writable CD/DVD/Blu-ray media support, completion status, verification options, manual write-speed control, installer source, and the last official release or availability signal.
Windows tools were assessed for Windows 10 and Windows 11 relevance where the vendor or built-in system path supported it. Mac coverage was considered only where the path actually applies to macOS, such as Finder, hdiutil, or a cross-platform DVD application with a compatible external writer.
Reading Maintenance and Safety Signals
The result is not a speed ranking. For a best ISO burner shortlist in 2026, a current installer source and verification control matter more than an old utility with a longer feature list. Active@ ISO Burner and PowerISO remain stronger Windows choices for maintained image work, while ImgBurn, Free ISO Burner, and similar older utilities belong in legacy or narrow-use situations.
For DVD projects, the better choice depends on whether the ISO is already ready to burn or whether the DVD structure needs compression, title selection, or a task queue before writing. That is where a DVD-specific tool belongs; it should not replace a lighter burner for a simple prepared image.
8 Best & Free ISO Burners for Windows and Mac
Evaluation Criteria:
The options below are evaluated by the task they can complete, their platform coverage, available verification or write-speed controls, support for the required disc media, and the condition of their official download or release history. A current Windows utility is treated differently from a reachable but stale download, and Windows-only software is not presented as a Mac option.
DVDFab DVD Copy
DVDFab DVD Copy supports Windows and macOS and can write DVD content to a blank disc or save it as an ISO or folder. It provides DVD-9 to DVD-5 compression, title-level selection, six copy modes, and queued tasks. Use it to save a local copy for personal offline viewing when you are authorized to access the content and applicable law permits it.
I would reserve it for DVD structure work rather than a one-click write of an already prepared ISO. Its six modes, including Full Disc, Main Movie, Clone, Customize, Split, and Merge, matter when the disc layout or output capacity needs attention.
- Processes protected DVD content for authorized personal backup and playback.
- Burns DVD-9 ISO files to compatible media or compresses DVD-9 content for DVD-5.
- Offers six copy modes: Clone, Full Disc, Main Movie, Customize, Split, and Merge.
- Lets you select titles, chapters, audio tracks, and subtitles.
- Supports GPU acceleration; compressed output is re-encoded to fit the selected capacity.
How to Burn an ISO to DVD with DVDFab DVD Copy
Step 1: Download and launch DVDFab software, choose the Copy module, and select a copy mode. Click Add to load the source ISO, or drag it into the main window. Insert blank media that matches the target capacity before starting.
Free Download macOS 12 or newer
Step 2: Set a volume label and adjust the copy settings. Select the titles, chapters, audio tracks, and subtitles you want to keep, then choose Disc as the output destination at the bottom of the window.
Step 3: Last, click the "Start" button to begin the burning process. You can also convert DVD to ISO using this DVD copy software.
Free ISO Burner: Maintenance Status
Free ISO Burner is a lightweight Windows utility for writing ISO image files to CD, DVD, HD DVD, or Blu-ray discs. It focuses on a single burn task and includes basic controls such as write speed, cache size, and volume label. A portable version can run from a USB drive without installation. Free ISO Burner 1.22 is dated to 2017; a reachable download does not indicate active maintenance, so treat it as a stale utility rather than a current Windows recommendation.
- Burns an ISO directly without extra menus or wizards
- Portable version runs from a USB stick without any installation
- Lightweight and compatible with older Windows PCs with limited resources
- Cannot queue multiple burns or batch process several ISO files
- No built-in disc verification after burning completes
- Supports ISO format only; does not handle BIN, NRG, or other image formats
How to Burn an ISO to DVD with Free ISO Burner
Step 1: Download Free ISO Burner and run the executable. No installation is required when using the portable version. Insert a blank DVD into your disc drive before starting.
Step 2: Click the folder icon next to the ISO file field and select the ISO file you want to burn. Choose your disc drive from the dropdown list and set the write speed. Using 4x or 8x instead of maximum speed reduces error risk, particularly with lower-quality blank media.
Step 3: Click Burn. A progress bar tracks the write status. When the process finishes, the disc ejects automatically. Free ISO Burner does not run a verification step by default, so re-insert the disc and browse its contents if you want to confirm the burn completed correctly.
Active@ ISO Burner
Active@ ISO Burner is a free Windows utility for writing ISO files to CD, DVD, HD DVD, and Blu-ray media. Drag an ISO image into the main window, choose the disc settings, and select Burn. The status panel shows disc details and write activity, while additional options cover burning mode, write speed, and the number of copies. The official page lists version 26.0.1, released February 1, 2026, making it a current choice for Windows image burning rather than full authoring or Mac work.
- Simple and intuitive interface
- Free image-burning utility for Windows
- Supports a wide range of disc formats
- Can burn the same ISO image to multiple discs in sequence
- Limited advanced features compared to paid burning software
- Only supports burning ISO images
- Fewer configuration options compared to more advanced tools
ImgBurn
ImgBurn is a legacy Windows disc-burning utility with detailed controls for ISO, BIN, CUE, MDS, NRG, IMG, and other image formats. It can also build ISO images from files, folders, or existing discs. Its last release, version 2.5.8.0, dates to June 16, 2013, so it should not be treated as a current compatibility recommendation.
Use the official ImgBurn download page if you decide its format controls are worth the older interface. Check the published file hash before installation and treat third-party mirrors cautiously.
- Provides file system options, layer break adjustments and verification
- Able to create audio CDs using CUE sheets
- Can build ISO images from files or discs, not just burn existing ones
- No longer actively updated, and the interface shows its age
- Lacks one-click disc copying or ripping features
- Overwhelming for beginners due to the number of technical settings
WinISO: Legacy Status
WinISO can edit, create, convert, and burn ISO images on Windows. It supports CD, DVD, and Blu-ray image work, including bootable images. However, WinISO is no longer for sale; the official site provides downloads for existing users, so new readers should choose an obtainable alternative such as Active@ ISO Burner or PowerISO. It is best for existing users who already have access to the installer, and it is not ideal for readers choosing a current ISO burner for a new Windows setup.
- Combines ISO creation, editing, format conversion, and disc burning in one application
- Compatible with various disk image formats
- Downloads are limited to existing users
- The free version restricts access to several features
- Some users report the interface takes time to navigate
- Advanced features overlap with tools like PowerISO
ISOburn
ISOburn is a portable Windows utility for writing ISO image files to CD, DVD, HD DVD, and Blu-ray media. Select the ISO file, choose the target drive, and start the burn while the Events panel shows progress. ISOburn 2.0.0 is dated to January 2017; a reachable download does not indicate active maintenance, so treat it as a legacy utility for a narrow task rather than a current Windows compatibility recommendation.
- Supports bootable ISO images, including operating system installers
- Burns to CD, DVD, HD DVD, and Blu-ray without any extra configuration
- Portable version requires no installation and runs directly from a USB drive
- No recent updates and no active developer support or bug fixes
- No disc verification step after burning completes
- It may not support all types of ISO images
CDBurnerXP
CDBurnerXP was a Windows disc-burning utility for CD, DVD, Blu-ray, and HD-DVD media. Its features included ISO creation from discs or folders, BIN and NRG conversion, and data or audio projects. It could also copy DVD to Hard Drive by saving a disc as an ISO image for storage.
Canneverbe Limited, CDBurnerXP's original developer, was dissolved on March 25, 2025. A separate domain now hosts downloads, but it is not a verified continuation of the original developer, so download provenance is the deciding concern rather than its former feature set.
- Completely free to download and use
- Works with a wide range of disc formats
- Can burn data, audio, and ISO projects, plus convert BIN/NRG to ISO
- Limited compatibility with newer operating systems
- Older interface and occasional minor bugs
- Original developer dissolved in 2025
PowerISO
PowerISO is an active Windows image-management tool for users who need more than a basic ISO burn. It can create ISO files, open and modify existing ones, convert between image formats, and compress or encrypt images for storage. Its burning engine writes ISO and other image formats to CD, DVD, and Blu-ray, and the software also includes a built-in virtual drive for mounting images without physical media.
PowerISO is best for Windows users who need to create, modify, mount, convert, and burn image files in one application. It is not ideal for Mac users or for a single prepared ISO when Windows Disc Image Burner or a lightweight burner already covers the task.
- All-in-one image tool that can build, modify, convert, and burn ISO files
- Supports many file types beyond ISO
- Includes an integrated virtual drive for mounting images instantly
- Interface may feel overwhelming to users who only need basic burning
- The unregistered version limits certain operations and file sizes
- Some users have reported occasional bugs
Most listed freeware tools are Windows-only. Mac readers should use the current macOS options below for a prepared image, rather than assume a Windows utility will run on macOS.
Mac ISO Burning Today
Prepared Images and External Drives
For a prepared ISO on a current Mac, Finder can write the image when a compatible writable external drive is connected. The hdiutil command is another option for users who prefer Terminal. Neither path changes the image structure, so bootability depends on the ISO and the target disc media rather than the burning command.
When Advanced Control Is Worth It
Mac built-in tools are best for a straightforward image write. For authorized personal DVD copies where permitted by applicable law, DVDFab DVD Copy adds DVD-9 to DVD-5 compression across macOS and Windows. It is not ideal for a single prepared ISO that does not need DVD-specific controls.
How to Choose an ISO Burner by Platform and Task
Windows Built-In Baseline
On Windows 11, right-click a prepared ISO and select Burn disc image to use Windows Disc Image Burner. This built-in path is best for one prepared ISO when you want no additional installation. It does not offer manual burn-speed selection or the verification options found in dedicated burners, so choose a maintained third-party utility when those controls matter.
Capacity, Verification, and Speed
A standard single-layer DVD holds about 4.7 GB, while a compatible dual-layer DVD can hold about 8.5 GB. An ISO larger than a single-layer disc needs compatible dual-layer media or, for authorized DVD content, a compression option such as DVD-9 to DVD-5. Writing an ISO does not automatically make a disc bootable and does not author a playable DVD-Video disc; both depend on the image and target medium. When a tool offers verification, use it after burning, especially for installation media.
Installer Trust and Maintenance
Use the developer's official download page whenever one is available, and distinguish a reachable installer from an actively maintained release. For older utilities, check the publisher's page and published hash before installation, and avoid mirrors that do not identify the original source.
The table compares practical paths by platform, use case, controls, and maintenance or source status.
| Tool or path | Platform | Best for | Control | Maintenance or source note |
| Windows Disc Image Burner | Windows | One prepared ISO | Basic write | Built into Windows |
| DVDFab DVD Copy | Windows, macOS | DVD compression or title selection | Six modes, queue | 30-day, three-disc trial (as of July 2026) |
| Active@ ISO Burner | Windows | Current image burning | Speed and copy settings | Version 26.0.1 in 2026 |
| PowerISO | Windows | Image management | Create, mount, burn | Current commercial option |
| ImgBurn | Windows | Older format controls | Detailed burn settings | Legacy; check official hash |
| Free ISO Burner | Windows | Portable basic writing | Speed and volume label | Stale; version dated 2017 |
Does Windows include an ISO burner?
Yes. In Windows 11, insert a writable disc, right-click the prepared ISO, and choose Burn disc image . If the option is hidden, open Show more options from the right-click menu.
How do I burn an ISO on a current Mac?
Use Finder with a compatible external DVD writer, or run hdiutil in Terminal if you prefer commands. The Mac writes the prepared image as it is, so the ISO itself still determines what the disc can do.
Is burning an ISO the same as making a bootable disc or DVD-Video disc?
No. Burning writes the image to disc. A bootable disc needs boot files inside the ISO, and a DVD-Video disc needs the proper VIDEO_TS structure before you burn it.
What should I do if the ISO is larger than a single-layer DVD?
A standard single-layer DVD holds about 4.7 GB. Use compatible dual-layer media for a larger prepared image, or use DVD-9 to DVD-5 compression for authorized personal DVD content when a smaller disc is required.
Final Thought
The right ISO burner depends on the target medium, platform, maintenance status, and the controls your disc actually needs. For Windows, use the built-in entry point described above as the starting check; choose Active@ ISO Burner or PowerISO when you want a maintained image tool with more burn settings.
On a Mac, Finder and hdiutil cover prepared images when a compatible external writer is available. Treat older utilities such as ImgBurn, Free ISO Burner, ISOburn, WinISO, and CDBurnerXP as legacy or stale options, especially when installer source or download continuity is unclear.
Choose DVDFab DVD Copy when an authorized personal DVD project needs Windows and macOS support, DVD-9 to DVD-5 compression, title selection, or queued copy tasks. Do not choose it for a prepared ISO that only needs a simple one-time write. After selecting media that matches the image capacity, use the detailed ISO-to-DVD burning steps for the final write.
![How to Copy DVD to DVD or Computer on Windows 10/11/8/7 [Tested Ways]](https://images.dvdfab.cn/artifact/2026/11/13/tgbSCdMJ4Qt9FXXH8UNMG-HWk5dJyerE/feature_cover.jpg)
![How to Burn ISO to DVD on Windows 11 and Mac [2026]](https://images.dvdfab.cn/artifact/2026/11/13/o2MTcZn5QG6wyGfJvcrg2WJA305_5rWn/feature_cover.jpg)
