Best Virtual Drive Software for Windows 11: Virtual CloneDrive and Alternatives
Summary: Windows 11 already includes a built-in virtual drive feature for mounting basic ISO and IMG files. In many cases, you can right-click the image file, choose Mount, and access it as a virtual DVD drive in File Explorer. Third-party virtual drive software such as Virtual CloneDrive or DVDFab Virtual Drive is mainly useful when you need older image formats, several virtual drives at once, Blu-ray ISO support, MDF/MDS handling, or more control than the Windows built-in mount option provides.
Do You Need a Virtual Drive Tool on Windows 11?
For basic ISO or IMG files, Windows 11 may already be enough. Right-click the disc image, choose Mount, and Windows will show it as a virtual DVD drive in File Explorer. When you are done, right-click the mounted drive and choose Eject.
A third-party virtual drive tool is worth adding when Windows’ built-in Mount option falls short. This often happens with formats like BIN, CCD, NRG, or MDF/MDS, or when you want to load several disc images at once.
| Need | Best Option |
| Mount one ISO or IMG file in Windows 11 | Use Windows built-in Mount |
| Mount several images at the same time | Use Virtual CloneDrive or DVDFab Virtual Drive |
| Mount DVD, Blu-ray, or Ultra HD Blu-ray ISO files | Use DVDFab Virtual Drive |
| Open MDF/MDS, BIN, CCD, NRG, or other older formats | Use a third-party virtual drive tool |
| Edit, create, compress, or convert image files | Use PowerISO or another disc image manager |
Virtual CloneDrive Review: Features, Limits, and Best Uses
What is Virtual CloneDrive
Virtual CloneDrive is a lightweight utility designed for Windows users who need to open disc image files such as ISO, CCD, and BIN without burning them to a physical disc. Once installed, it integrates directly with File Explorer, allowing ISO images to appear as if they were real optical drives.
The tool supports up to 15 virtual drives simultaneously and works with most legacy image formats used for DVDs and software installers. Although its simplicity remains appealing, Virtual CloneDrive has no official macOS version, and modern Windows systems (10 and 11) already include a built-in Mount feature that covers basic ISO access. As a result, the program now mainly serves users who need multi-drive mounting or support for older formats beyond ISO.
How to Use Virtual CloneDrive
In addition, you can open 'Settings' dialog from the program's System Tray icon and access Help Manual and Mount/Unmount controls for each drive. Remember that this widely accepted virtual CD/DVD drive allows you to auto-mount the last image, buffer the input and output, and enable 'Eject' command to unmount image files, just like ejecting a physical disc.
Pros and Cons of Virtual CloneDrive
- Free and lightweight for everyday image mounting.
- Works smoothly with Windows File Explorer and integrates into context menus.
- Supports ISO, CCD, and BIN files without needing extra codecs.
- Requires very little system memory and starts automatically with Windows.
- Windows-only, with no macOS or Linux version.
- Cannot handle encrypted or protected disc images such as Blu-ray ISO.
- Lacks playback controls and modern interface updates.
- Less necessary for users who only mount standard ISO or IMG files in Windows 11.
These practical limitations explain why many users look for Virtual CloneDrive alternatives that provide broader format support, modern interfaces, and cross-platform compatibility.
Detailed Picks: Best Virtual Drive Software for Windows 11
Virtual CloneDrive works well for basic mounting, but it does not cover every Windows 11 use case. If you need MDF/MDS or NRG support, multiple virtual drives, Blu-ray ISO mounting, or image editing features, the alternatives below may fit better.
The alternatives below are grouped by practical use case, so you can choose a tool based on the file type you need to open and the features Windows built-in Mount or Virtual CloneDrive does not provide.
- Best for: DVD, Blu-ray, and Ultra HD Blu-ray ISO mounting on Windows
- Available OS: Windows 11/10/8.1/8/7 (64-bit)
- Price: Free
DVDFab Virtual Drive is a free virtual drive tool for Windows users who need more than the basic ISO Mount option built into Windows 11. It can emulate up to 18 virtual drives and mount disc image formats such as ISO, BIN, CCD, DVD, IMG, MINISO, NRG, and UDF.
This tool is a strong fit for DVD, Blu-ray, or Ultra HD Blu-ray images created by DVDFab or other disc tools. You can mount or unmount images from the system tray, set the number of virtual drives, and reload recently used image files when needed.
- For users who need to create ISO files or extract them from discs, DVDFab also provides disc copy software: DVD Copy and Blu-ray Copy, which can remove copy protection and ensure compatibility with any playback software.
How to Use DVDFab Virtual Drive [Tutorial]
Step 1: Download and install this best free virtual drive. After installation, right-click on the DVDFab Virtual Drive icon that has been minimized to the system tray, then select "Set Number of Drives" to choose the number of virtual drives you want to emulate.
Step 2: There're three ways to mount the ISO image file to the specified virtual drive. You can right-click the ISO file directly, you will see the "Mount" option and all available virtual drives will be displayed. Or you can right-click on the DVDFab Virtual Drive icon in the tray and select the "Mount" option under each virtual drive in the pop-up menu. If you want to remount an opened ISO file, just right-click on the icon and click on "Recently Used Mirrors", then you can select the ISO file you want to remount.
Step 3: Use PlayerFab or another player to play ISO files. Just click the "Open File" button, select the ISO file mounted by DVDFab Virtual Drive and start playing it.
PowerISO
- Best for: Editing, creating, converting, and mounting image files
- Available OS: Windows 11/10/8.1/8/7/Vista/XP
- Price: Paid software with trial version
PowerISO offers a full suite of virtual drive and disc authoring tools. Beyond mounting ISO files, it can create, edit, burn, and compress popular disc image format, including ISO, BIN, NRG, CDI, and DAA. The software allows you to make bootable USBs, extract music or data from discs, and convert images between multiple formats.
Its internal virtual drive integrates with Windows for one-click ISO mounting, while the portable edition provides flexibility for users who manage discs across several systems.
Daemon Tools Lite
- Best for: Users who need older image formats and extra disc tools
- Available OS: Windows 11/10/8.1/8/7/Vista/XP/2000/98
- Price: Free version available; some features are paid
DAEMON Tools Lite is a long-running virtual drive application with broad disc image support. It supports over 20 image formats and can emulate multiple DT, SCSI, IDE, and HDD virtual drives simultaneously. In addition to mounting, the software can create, edit, and protect image files, as well as generate writable virtual drives to simulate burning data without a physical disc.
The limitation is that the free version may include ads or locked features, while advanced tools require paid modules or upgrades. It suits users who need broader format support and do not mind a heavier program.
OSFMount
- Best for: Disk image testing, forensics, and RAM disk workflows
- Available OS: Windows 11/10;Windows 8/7
- Price: Free
OSFMount, developed by PassMark Software, is a reliable and lightweight free virtual drive utility that also integrates with OSForensics. It supports 11 image types and lets users mount ISO files, local disk images, or RAM drives directly within Windows.
Power users can decide whether each image appears as a removable drive or a writable RAM disk, which makes OSFMount well suited to testing, forensic analysis, and data recovery. Despite being free, it offers advanced control over mounting parameters, caching, and drive-emulation modes.
ImgDrive
- Best for: Lightweight mounting, audio disc images, and folder-to-disc emulation
- Available OS: Windows 11/10/8.1/8/7/Vista/2003/XP
- Price: Free
ImgDrive by Yubsoft is a free and lightweight virtual drive tool. It can emulate up to seven virtual drives simultaneously and supports both standard disc images (ISO, CUE, NRG, MDS, MDF, CCD, ISZ) and audio formats such as APE, FLAC, and WAV.
Unlike many ISO mounters, ImgDrive also allows mounting folders as virtual DVDs or Blu-rays, and includes command-line support for batch operations.
gBurner Virtual Drive
- Best for: Basic mounting and common disc image workflows
- Available OS: Windows 11/10/8.1/8/7/Vista/XP/2000/Me/98
- Price: Free
gBurner Virtual Drive mounts common disc image formats in Windows. Choose it when the built-in Mount option cannot open files beyond standard ISO or IMG, especially formats such as BIN, CUE, MDF/MDS, NRG, VHD, or VDI.
The program can mount multiple virtual drives and supports formats such as ISO, BIN, CUE, MDF/MDS, NRG, VHD, and VDI. It may fit users who already work with gBurner tools or need a simple way to open several image formats.
Legacy Virtual Drive Tools for Older Windows Systems
Some older virtual drive tools still work for legacy Windows setups, but they are not the first choice for Windows 11 users. Use them only when you maintain an older computer, need a familiar interface, or work in an offline testing environment.
WinCDEmu
- Best for: Open-source mounting and simple double-click use
- Available OS: Windows XP/Vista/7/8/8.1/10
- Price: Free and open source
WinCDEmu is a lightweight, open-source virtual CD/DVD/Blu-ray emulator designed for quick ISO access. Once installed, you can mount image files by simply double-clicking them in Windows Explorer, making it one of the most intuitive free Virtual CloneDrive alternatives available. It supports common formats such as ISO, NRG, MDS/MDF, and IMG, as well as multilingual support for over 20 languages.
The program allows users to create ISO files directly from physical discs and supports multiple virtual drives without performance loss. For Windows 11 users, check the current compatibility and installer behavior before relying on it as your main virtual drive tool, since the official system list focuses on Windows XP through Windows 10.
Gizmo Drive
- Best for: Legacy Windows systems and virtual hard drive images
- Available OS: Windows 2000/XP/2003/Vista/Server 2008/7
- Price: Free
Gizmo Drive mainly serves legacy Windows setups that still rely on virtual hard drive images or earlier disc-image formats. It works with ISO, BIN, IMG, NRG, MDS/MDF, and VHD, and can also create encrypted image files in its own .GDRIVE format.
The program can mount multiple virtual drives and includes command-line controls, which may be useful in legacy testing environments or virtual machines. Since its official updates stopped around the Windows 7 era, it is not a first choice for modern Windows 11 systems.
MagicISO
- Best for: Older ISO/BIN editing tasks
- Available OS: Windows 98/ME/NT/2000/XP/2003
- Price: Paid software with legacy usage
MagicISO is a legacy disc image tool for opening, creating, and editing ISO and BIN files. It can also extract files from disc images and convert between BIN and ISO, which may still help users maintaining older Windows systems or old image archives.
Its limitation is age. The last commonly referenced version is 5.5 from 2010, so it is not a practical first choice for Windows 10 or Windows 11 users. If you need current ISO mounting, image conversion, or Windows 11 compatibility, choose a newer tool such as PowerISO, DAEMON Tools Lite, or DVDFab Virtual Drive based on the file format you need to open.
ISODisk
- Best for: Simple ISO mounting on older Windows systems
- Available OS: Windows XP/2003/Vista
- Price: Free
ISODisk is a free virtual drive tool for mounting ISO image files as virtual CD or DVD drives. It supports up to 20 virtual drives at the same time, so users can open ISO contents without using a physical disc.
ISODisk does not include the advanced features found in newer tools, and it does not support Windows 10 or Windows 11. It is mainly suitable for older systems, offline setups, or testing environments where basic ISO mounting is enough.
Does Windows 11 have a built-in virtual DVD drive?
Yes. Windows 11 can mount ISO and IMG files without third-party software. Right-click the image file, choose Mount, and Windows will show it as a virtual DVD drive in File Explorer. When you are finished, right-click the mounted drive and choose Eject.
Does Virtual CloneDrive work on Windows 11?
Yes. The official Virtual CloneDrive product page lists Windows 11 among its supported systems. It is still a lightweight option for mounting disc image files, although many Windows 11 users may only need the built-in Mount feature for ISO and IMG files.
Is Virtual CloneDrive safe to download?
Virtual CloneDrive should be downloaded from the official Elaborate Bytes website. Avoid third-party download sites when possible, because they may host outdated installers or repackaged versions.
Does Virtual CloneDrive support MDF files?
Virtual CloneDrive is mainly known for mounting formats such as ISO, BIN, CCD, IMG, UDF, and DVD images. If your main files are MDF/MDS images, check the current format list before installing it, or consider tools such as WinCDEmu, DAEMON Tools Lite, or PowerISO.
What is the best virtual drive software for Windows 11?
For basic ISO and IMG files, Windows 11’s built-in Mount feature is the easiest option. For DVD, Blu-ray, or Ultra HD Blu-ray images, DVDFab Virtual Drive is a good choice. For MDF/MDS and older image formats, consider WinCDEmu, DAEMON Tools Lite, or PowerISO depending on whether you prefer open-source, broader format support, or image editing features.
How do I remove a virtual drive that stays in This PC?
First, right-click the mounted virtual drive in File Explorer and choose Eject. If it remains visible, close the mounting program from the system tray, unmount all images inside the program, or restart Windows. If the issue comes from third-party virtual drive software, open its settings and reduce the number of virtual drives to zero before uninstalling it.
Windows 11 already handles basic ISO and IMG mounting, so a third-party virtual drive is not always necessary. Virtual CloneDrive can still cover simple right-click mounting and multiple virtual drives, but it may feel limited when you need broader format support or disc-image workflows beyond basic mounting.
If those limits affect your use case, a tool such as DVDFab Virtual Drive is worth considering for Windows users who work with DVD, Blu-ray, or Ultra HD Blu-ray image files.
![How to Burn ISO to DVD on Windows 11 and Mac [2026]](https://images.dvdfab.cn/media/Screenshot_2026-08-07_at_10.57.26_d3iqro.png/public)
![How to Rip DVD to ISO on Windows 11/10/8/7 and Mac? [2026 Update]](https://r3.dvdfab.cn/upload/resource/dvd-to-iso-ei38.jpeg)
![Top 11 ISO Creators to Create ISO File on Windows & Mac [2026 Updated]](https://r3.dvdfab.cn/upload/resource/create-iso-file-ytTu.jpeg)
![How to Copy DVD to DVD or Computer on Windows 10/11/8/7 [Tested Ways]](https://r1.dvdfab.cn/upload/resource/how-to-copy-dvd-windows-10-hO78.jpeg)
