A Detailed WinX DVD Ripper Platinum Review: 2026 Updated
Summary: WinX DVD Ripper Platinum is a beginner-friendly DVD ripper for converting DVD discs, ISO images, and VIDEO_TS folders to MP4, AVI, and other digital formats. It supports GPU acceleration, 350+ output profiles, protected and 99-title DVDs, plus ISO/folder backups. Its main drawbacks are the 5-minute trial limit, no MKV passthrough output, and a lack of advanced audio controls.
WinX DVD Ripper Platinum can convert DVDs to MP4 and other digital formats, but the important purchase questions are whether the Free Edition meets your needs, what Platinum costs, and which audio and subtitle tracks survive a DVD to MP4 conversion. This WinX DVD Ripper review checks those limits, its DVD-only scope, and a same-disc comparison with an alternative.
What is WinX DVD Ripper Platinum?
WinX DVD Ripper Platinum converts DVD discs, ISO images, and DVD folders into digital video or audio files. It supports common outputs such as MP4, AVI, MPEG, WMV, MOV, MP3 and other profiles, while its preset system lets you choose a playback format or device without configuring every codec parameter manually.
For discs with unusual title structures, WinX includes title analysis for sources such as 99-title DVDs and some damaged or non-standard discs. Physical damage and unusual disc structures still vary, so these functions should not be read as a guarantee that every difficult disc can be recovered.
Here is further information about this software:
| Item | WinX DVD Ripper Platinum |
| Supported Input | DVD discs, ISO image files, VIDEO_TS/DVD folders |
| Common Outputs | MP4, AVI, MPEG, WMV, MOV, MP3 and other video/audio profiles |
| Preloaded Profiles | 350+ format and device profiles |
| Copy Options | ISO image, DVD folder, MPEG-2 and other copy-oriented outputs |
| GPU Acceleration | Intel, NVIDIA and AMD hardware support on compatible systems |
| Supported OS | Windows and macOS versions are available |
WinX DVD Ripper vs Platinum: What's the Difference?
There was previously a standalone free version called WinX DVD Ripper. The previous version is no longer available for download, but the WinX DVD Ripper product page is still live. When you download and install the program, you'll actually get WinX DVD Ripper Platinum. The free version is integrated but includes only a subset of the features available in the full Platinum version.
Windows users get WinX DVD Ripper Platinum, while Mac users get WinX DVD Ripper for Mac. Both allow ripping only the first 5 minutes of a DVD movie for free. The original free version stopped updating in 2014 and didn't have a Mac version.
Is it Safe to Download?
Yes, WinX DVD Ripper is safe to download the official WinXDVD website. After downloading the installation file (only 31.64 MB), I scanned it using the well-known online virus scanner, VirusTotal. The scan shows that there is no malicious software, and confirm that the file is clean.
How to Rip a DVD Using WinX DVD Ripper Platinum?
Pros and Cons of WinX DVD Ripper Platinum
- Supports DVD discs, ISO images, and DVD folders with multiple conversion and copy outputs.
- Supports GPU acceleration on compatible Intel, NVIDIA, and AMD hardware.
- Provides 350+ format and device profiles for users who do not want to configure every codec setting manually.
- Includes trimming, cropping, merging, subtitle selection, and external-subtitle options.
- Provides 1:1 ISO/DVD-folder copy options and multi-track MPEG-2 copy modes instead of requiring every job to be transcoded.
- Free version is limited to converting only the first 5 minutes of content, which is too short to validate a full movie rip.
- No support for lossless DVD to digital conversion (e.g., no MKV passthrough).
- Lacks batch processing or multi-task ripping capabilities.
- Relatively low update frequency (only 3–5 releases per year).
- Does not support automatic disc detection or drag-and-drop loading.
Feedback on WinX DVD Ripper
As of August 12, 2026, the WinXDVD Trustpilot profile has a 4.0/5 TrustScore from 411 reviews. About 76% of users gave it 5 stars, citing ease of use and solid performance for basic DVD backups. Around 17% rated it 3 stars or below, pointing to disc compatibility limits and fewer advanced controls.
Positive Feedback
- Recent reviewers frequently mention responsive customer support and quick replies to technical questions.
- Some users report successfully resolving DVD or Windows-related problems after contacting support.
- Other positive reviews describe the software interface as easy to learn for common conversion tasks.
Negative Feedback
- Some reviewers report discs or systems on which the software did not work as expected.
- Recent complaints include freezes or failures when reading difficult DVDs.
- Can't select multiple audio and subtitle tracks — limited control over output streams.
- Lacks customization, and limited settings for power users.
- No surround-sound encoding; DTS-HD output is not available.
- Fewer output formats, with some advanced codecs and containers missing.
Best Alternative to WinX DVD Ripper: DVDFab DVD Ripper
WinX covers common DVD conversion and several copy modes, but some collections require a different set of output choices. DVDFab DVD Ripper is worth comparing when you need MKV Passthrough, a larger profile library, task queuing, or more detailed audio and subtitle selection.
- Supports removing copy protection on old and newly released discs via its Cloud Decryption Service for quick decryption.
- Converts DVD disc, folder or ISO to MP4 and other 1000+ formats and outputs high-definition video for home theater use.
- Handles multiple DVDs in a Task Queue and uses modern GPU acceleration for faster processing.
- Includes advanced tools to extract audio tracks, trim/crop/edit video, and add watermarks and subtitles.
- Offers ready-made profiles for 260+ devices (Apple, Google, Huawei, Microsoft, Sony, etc.).
- Provides a range of customer support via email, live chat, and a user forum.
How to Rip DVDs with WinX DVD Ripper Alternative?
Step 1: Launch DVDFab DVD Ripper and Load the Source
Download and install this DVD Ripper for Windows and Mac. Insert the DVD you want to rip. If you're using an ISO or a DVD folder, drag it into the main window.
Step 2: Choose Output Format
Click "Choose Other Profile", and you'll see two main tabs: Device and Format.
- Under Format, choose from a full list of file types, including MP4, AVI, MKV, and others.
- Under Device, select presets optimized for playback on specific hardware. You can rip your DVD to iPad, Android, Apple TV, PlayStation, or Smart TVs.
Step 3: Adjust and Edit DVD Video
You can adjust the following parameters for greater output control:
- Select the audio tracks and subtitles you want in the final file.
- Open the "Advanced Settings" panel to refine the output: adjust bitrate, frame rate, resolution, audio quality and more.
- Next, click "Video Edit" to make visual adjustments before ripping. You can trim unwanted scenes, crop black bars, rotate or flip the image, and even add external subtitles.
Step 4: Start the Ripping Process
Once everything looks right, choose the Output folder for the converted files. Click "Start" to begin ripping your DVD. A progress bar will show real-time status, and you can pause, cancel, or close the program without losing your task.
Winx DVD Ripper Platinum vs. DVDFab DVD Ripper
Here's a comparison of key features between WinX and DVDFab, so you can see at a glance which tool aligns better with your DVD-ripping needs.
| Functions | WinX DVD Ripper | DVDFab DVD Ripper |
| Working System | Windows & Mac | Windows & macOS |
| DVD Decryption | Most DVD copy protection | Keep updating to handle both older and newly released DVD protections |
| Output Formats | Over 210+ video & audio formats plus device presets. | Over 1000+ media formats and more than 260 device profiles |
| Lossless Output | No | Yes |
| GPU Hardware Acceleration | Yes (Intel and NVIDIA only) | Yes ((Intel Quick Sync, NVIDIA CUDA, AMD, etc)) |
| Chapter Selection | No | Yes |
| Bonus Features | Basic video editing | Advanced editing tools, and metadata synchronization |
I also tested both programs with the same movie, 8 Mile, on the same computer to compare the completed outputs.
| Test Environment: Win10 x64, i7-6700, RTX 4060 Ti 8GB, 16GB RAM Movie: 8 Mile (Duration: 1h 50m; Original Size: 6.13GB) | ||
| Test Metrics | WinX DVD Ripper | DVDFab DVD Ripper |
| Codec | H.264 / AAC | H.264 / AAC |
| Ripping Time | 6m 51s | 5m 29s |
| Video Resolution | 720x404 | 720x404 |
| Output Audio | AAC 2.0 | AAC 5.1 |
| Output File Size | 1.03 GB | 1.91 GB |
🏆DVDFab DVD Ripper: Faster Rips, Better Results
- DVDFab's ripping speed is about 20% faster than WinX, performing better in terms of hardware acceleration and decoding efficiency.
- The file size generated by DVDFab is about 1.85 times that of WinXDVD. Plus, DVDFab uses the AAC 5.1 multi-channel audio format, demonstrating that its audio quality and multi-channel support are richer.
Is WinX DVD Ripper safe to use?
Yes, WinX DVD Ripper is generally safe. It's a long-standing and widely used DVD ripping software that converts discs into digital files. To avoid potential malware or unwanted installers, always download it from the official WinX DVD Ripper website or other verified sources rather than from mirror or third-party sites.
Is WinX DVD Ripper really free?
It has been verified that WinX DVD Ripper Free is a trial version of the Platinum edition. Regardless of which product page you download from, you will get the WinX DVD Ripper Platinum build. During the trial period, you can use the basic DVD ripping function, but the output length is capped at 5 minutes per file.
Can WinX DVD Ripper handle Blu-ray or 4K UHD discs?
No. WinX DVD Ripper Platinum is marketed for DVDs, ISO images, and DVD folders; its official product page does not advertise Blu-ray or 4K UHD disc ripping. If you need a broader disc-handling tool, the alternative section above explains the DVD-focused capabilities of DVDFab DVD Ripper.
What does WinX DVD Ripper Platinum cost?
The US Platinum terms listed above are $34.95 for the first year on three PCs, renewing at $39.95 yearly, or $59.95 for a one-PC lifetime license.
What are the best alternatives to WinX DVD Ripper?
If you need more advanced features or lossless output, DVDFab DVD Ripper is a strong alternative. It supports faster GPU-accelerated conversion, broader format options, and precise control over audio tracks, subtitles, and chapters.
For free DVD ripper, HandBrake is a good open-source option for unprotected discs, while MakeMKV works well for creating lossless MKV backups from encrypted DVDs.
Final Thoughts
WinX DVD Ripper is a practical option for users who want straightforward DVD conversion without a steep learning curve. It performs well for standard backups and simple format transfers. For those who need more advanced controls, DVDFab DVD Ripper offers a stronger alternative solution. Its regular updates, better decryption support, and multi-device profiles make it a dependable choice for both casual users and collectors who value quality preservation.
![How to Rip Audio from DVD with 5 Best Free DVD Audio Extractors [2026]](https://images.dvdfab.cn/media/how_to_rip_audio_from_dvd_5r8iyw.png/public)
![How to Rip a DVD: 8 Tested Tools With Step-by-Step Guide [2026]](https://images.dvdfab.cn/media/how_to_rip_a_dvd_vlh4iu.png/public)
