DVD Case Dimensions & Cover Sizes: The Complete Guide for Collectors
Summary: A standard DVD case measures 190 mm x 135 mm x 14 mm (7.48" x 5.31" x 0.55"). This guide details these physical specs alongside exact dimensions for covers and internal inserts. We also provide storage density tips, comparisons with Blu-ray/CD formats, and expert advice for distortion-free printing. Finally, learn how to protect your library by digitizing your collection in simple steps.
When I first started reorganizing my home media library, I quickly realized that getting the exact dvd case dimensions right is more complicated than simply picking up a ruler. Whether you are replacing a cracked retail shell or designing a custom masterpiece for a gift, missing the mark on standard dvd case dimensions by even a few millimeters means the artwork won't sit flush or the spine text ends up looking off-center. Dealing with the trial-and-error of wasted photo paper and misaligned inserts is a frustration that often turns a simple project into a headache.
I've put together this comprehensive breakdown of dvd case dimensions to take the guesswork out of these industrial sizing standards. We will look at the specific measurements for standard, slim, and multi-disc formats across both imperial and metric units to ensure your designs fit perfectly every time. By walking through these technical specs, I hope to help you get your printing and storage settings exactly right on the very first try.
DVD Case Dimensions
When organizing a media library, understanding the specific dvd case dimensions for various packaging styles is essential. While the 14mm "Amaray" case is the industry standard, several other formats exist to cater to space-saving needs or premium collectibles.
DVD cases are prevalent in retail packaging, personal collections, and archives. They come in several common types, each tailored for specific usages:
📀 Standard DVD Case Dimensions (Amaray Style): The industry norm for single-disc packaging. It measures 190mm x 135mm x 14mm. This is the classic box used for most movie releases and software.
📀 Slim DVD Case Dimensions: About half the thickness of a standard case, typically 7mm or 9mm. These are ideal for space-saving storage or bundling multiple discs in a thin profile.
📀 Double/Multiple DVD Case Dimensions: Designed to securely hold 2 to 6 discs within a standard or slightly thickened shell (up to 25mm). These are the "go-to" for TV series box sets or special editions.
📀 Jumbo/Eco DVD Case Dimensions: Jumbo cases (up to 50mm thick) hold massive collections, while Eco-cases feature "cut-out" holes in the plastic to reduce environmental impact while maintaining standard outer dimensions.
📀 SteelBook Edition DVD Case Dimensions (New): A premium metal alternative to plastic cases. While the height and width are nearly identical to standard cases (190mm x 135mm), they often feel slightly thinner and more rigid (15mm), making them a favorite for high-end collectors.
📀 Mini DVD Case Dimensions (80mm) (New): Specifically designed for 8cm "Mini DVDs" used in older camcorders or GameCube consoles. These compact cases measure approximately 124mm x 142mm x 10mm, requiring much smaller storage slots.
To help you select the suitable cases for your collection, here is a comparison table covering case type and dvd case dimensions for quick reference:
| Case Type | Dimensions (Metric) | Dimensions (Imperial) | Best For |
| Standard | 190 x 135 x 14 mm | 7.48 x 5.31 x 0.55 in | Retail Movies, Software |
| Slim | 190 x 135 x 7 mm | 7.48 x 5.31 x 0.28 in | Space-saving, Home Backups |
| Double | 190 x 135 x 14-25 mm | 7.48 x 5.31 x 0.55-1 in | 2-6 Disc Sets |
| SteelBook | 190 x 136 x 15 mm | 7.48 x 5.35 x 0.59 in | Premium Collectibles |
| Mini DVD | 124 x 142 x 10 mm | 4.88 x 5.59 x 0.39 in | 8cm Camcorder Discs |
Note: Actual dimensions may vary slightly by manufacturer.
DVD Cover Size (The External Wrap)
The paper insert must be slightly smaller than the outer plastic sleeve so it fits without buckling. A precise dvd cover size ensures the artwork displays correctly across the front, back, and spine sections once inserted into the case.
For DVD cover size dimensions, a standard DVD cover size is 183mm x 273mm (7.2 inch x 10.75 inch). Most of the time it is possible to fit a whole DVD cover on a single A4-sized paper. However, it does depend on your printer and paper size. DVD cover of slim case is a bit smaller, comes in 183mm x 266mm (7.2 inch x 10.47 inch). So make sure you've printed the right size for your DVD cases.
But where can you download DVD convers? Here we recommend four websites for you to bring color for your DVD cases.
- DVDcover.com: offers 4K Ultra HD Blu-ray Disc covers, movie DVD covers, game covers and more. Free accounts can only download the first cover at a lower resolution.
- Cover Century: a large library of ready-to-print DVD, Blu-ray, and CD covers for movies, TV shows, and games.
- Customaniacs: offers extensive member-created custom covers and labels for movies and music.
- CoverCity: provides ultra-high resolution DVD/Blu-ray/4K/UHD covers, disc maps, etc. The interface is simple and the classification is clear. It also supports multi-condition search and browsing by subject.
DVD Case Insert Size (Internal Booklets and Leaflets)
The dvd case insert size describes the printed materials placed inside the case, usually held by the plastic clips on the left-hand side. These are typically booklets, chapter lists, or promotional flyers. Because these items sit inside the recessed area of the case, they are smaller than the external cover.
A standard dvd case insert size for a single-sheet flyer or a multi-page booklet is 120 mm wide by 180 mm high (4.72 inches x 7.08 inches). This provides enough clearance so the booklet does not interfere with the disc hub or the closing mechanism of the case.
- Technical specifications for internal inserts include:
- Single-sheet inserts: Use 120 mm x 180 mm dimensions.
- Multi-page booklets: The width should remain 120 mm, but as the page count increases, the thickness can prevent the case from snapping shut. Standard clips can usually hold a booklet up to 2 mm thick.
- Pixel Dimensions (300 DPI): Set your canvas to 1417 x 2126 pixels for a single panel.
Maintaining these precise measurements for the dvd case insert size ensures that the contents do not slide around or get pinched when the case is handled.
DVD Storage Size
The capacity of a DVD is the primary factor that stands it apart from other DVD formats. The DVD storage size of a standard single-layer recordable DVD is 4.7GB which can hold about 120 minutes of video at DVD quality.
The amount of data that a DVD can hold, is mainly dependent on the number of sides and layers. Double-sided or double-layered DVDs naturally hold more content than single-layered and single-sided DVDs.
Some of the highly used DVDs, DVD size limit and specifications are as follows:
- DVD-5: DVD size limit is 4.7GB; supported by the DVD+R/RW and DVD-R/RW formats- is single-sided and single-layered
- DVD-9: DVD size limit is 8.5GB; supported by the DVD+R and DVD-R formats; commonly known as DVD-R DL and DVD+R DL- is single-sided and double-layered
- DVD-10: DVD size limit is 8.75GB; supported by the DVD+R/RW and DVD-R/RW formats- is double-sided and single-layered
- DVD-18: DVD size limit is 15.9GB; supported by the DVD+R format- s double-sided double-layered
How to Copy Your DVD Collection
After organizing your physical library using the correct dvd case dimensions, digitizing your collection is the next step to ensure long-term preservation. Moving your media into a digital format protects your movies from physical wear and disc rot while making them accessible on smartphones, tablets, and home media servers.
DVDFab DVD Ripper is a professional-grade tool capable of bypassing all standard DVD copy protections, including CSS, APS, and region codes. It supports converting physical discs into over 1,000 video and audio formats, such as MP4, MKV, and MOV, without sacrificing visual quality. The software utilizes GPU acceleration to ensure high-speed processing, often completing a full-disc conversion in as little as five minutes.
Supported OS:
Follow these three steps to digitize your collection:
Step 1: Launch DVDFab DVD Ripper and insert your disc into the optical drive. The software will automatically detect the disc and decrypt the content.
Step 2: Choose your desired video format from the profile library. You can select specific audio tracks and subtitles or use the built-in editor to crop and trim the footage.
Step 3: Select your destination folder and click the Start button.
Every 10 standard 14mm cases occupy 140 mm (5.5 inches) of linear shelf width. Using 7mm slim cases doubles storage density, allowing 20 units to fit in the same 140 mm span. This transition reduces the horizontal footprint by 50% while maintaining consistent shelf height and depth.
No, a standard DVD will not fit in a standard CD jewel or Blu-ray case because DVD cases are taller and have different locking mechanisms. CD jewel cases are much shorter and narrower, and Blu-ray cases are approximately 13mm shorter than standard DVD cases. Using the wrong case type will prevent standard-sized DVD cover inserts from fitting properly.
Set your printer scaling to "Actual Size" or "100%" in the print dialog to prevent automatic image distortion. Most software defaults to a "Fit to Page" setting, which stretches the fixed dvd cover size and causes misalignment on the spine. To ensure an accurate 273 mm x 183 mm output, use A4 or Legal-sized paper and verify that your design resolution is set to 300 DPI before hitting print.
Mastering dvd case dimensions is essential for creating professional covers and efficient storage layouts. Whether you are printing 300 DPI inserts or planning shelf space, precise measurements prevent wasted effort. After organizing your physical library, using DVDFab DVD Ripper to digitize your collection ensures your movies remain protected and accessible.
![Top 7 Best DVD Editing Software for Windows & Mac [2026 Update]](https://r5.dvdfab.cn/upload/resource/dvd-editing-3Gay.jpeg)
