How to Copy DVD to USB Flash Drive
I've spent years moving DVD collections to USB and other digital formats for families, small studios, and my own archive. During this work, I have frequently encountered the same technical issues: a TV refuses to play a copied file, a transfer fails at the FAT32 4GB limit, or the computer only displays a VIDEO_TS folder instead of a single movie. After testing these conversions across laptops, media boxes, and car head units, the results are consistent. While some discs are simple data DVDs that allow for direct copying, most movie DVDs are authored specifically for players and require conversion to a standard video file before a USB device will play them.
I also reviewed how users handle the same task in practice. A Reddit discussion on r/DataHoarder shared workflows from people who routinely back up and transcode their movie collections. Their insights confirmed that even with the same tools, results vary widely depending on drive quality, encoding choices, and playback hardware. This guide combines those experiences with my hands-on testing, guiding you from disc to smooth USB playback.
Quick Answer: My Picks to Copy DVD to USB
Copy existing readable data files directly, or convert DVD-video to a supported MP4, copy it to USB, and test playback. For the computer-based methods, you need a Windows or Mac computer supported by the selected software, an internal or external DVD reader, and a separate flash drive. The reader accesses the disc; the flash drive stores the output. A USB-C connector does not convert video.
DVD reader sends video to DVDFab DVD Ripper, then an MP4 moves to a USB drive for TV playback.
Disc or EquipmentMethodMain Actions
DVD-video for USB playbackDVDFab DVD Ripper; MakeMKV; HandBrake for unprotected DVDsConvert, copy to USB, test playback
Readable data filesDirect Copy and PasteCopy files, check completeness and playback
No computer or DVD readerTransfer service or recorder with DVD-to-USB recordingConfirm disc acceptance and USB output
💡1. Professional DVD Ripper (see details):
Conversion software is not the only reliable option: readable data files can be copied directly. Commercial discs may also use native copy protection that ordinary file copying does not remove. DVDFab DVD Ripper can remove supported native disc copy protection and rip DVD video to MP4 or MKV. HandBrake converts unprotected DVD sources to MP4, MKV, or WebM and offers hardware-accelerated encoding on supported hardware. USB playback requires a compatible container, video codec, audio codec, and file system.
💡2. Direct Copy and Paste (see details):
If your DVD contains personal photos or documents without protection, you can drag the files directly to the USB drive. This method is free and requires no software. However, it typically fails for movies DVD because playback devices cannot parse the raw folder structure found on a standard video disc.
💡3. DVD to USB Transfer Services Near You (see details):
If you do not own a computer or an external disc drive, local DVD to USB conversion services can digitize your collection for you. These businesses use professional hardware to move your DVD data to a USB stick or cloud storage. This is a hands-off solution for people who only use mobile devices and want to avoid buying extra equipment.
Way 1: Convert DVD to USB with a Specialized DVD Ripper
Copying a video DVD's VIDEO_TS folder to USB does not make it playable on every TV or car player. With a compatible computer and DVD reader, you can convert DVD to MP4, MKV, or another format supported by your player. The three tools below offer different options for compression, source-stream preservation, and audio or subtitle selection.
DVDFab DVD Ripper: Flexible Formats and GPU Encoding
DVDFab DVD Ripper is a reliable DVD to USB converter for Windows 11/10 (64-bit) and macOS 12+ that exports MP4, MKV, and other video or audio formats. It removes supported native DVD copy protection and converts the selected title into a file for USB playback on compatible TVs and car players. Passthrough profiles preserve compatible source video and audio streams without re-encoding; H.264 or H.265 encoding can reduce file size. The free trial lets you fully process up to 3 DVDs within 30 days.
In my test, DVDFab 13 converted a 6.13 GB DVD ISO (8mile.iso) to H.264 MP4 in just 5 minutes and 31 seconds on a Windows 10 PC with an Intel i7-6700, 16 GB RAM, and an RTX 4060 Ti. It can also compress a 4.3 GB DVD movie into an 890 MB MP4 in roughly five minutes, with no noticeable loss of visual detail. At that file size, a 64 GB USB drive could hold around 70 movies. Unlike MakeMKV, which extracts DVD video without re-encoding, DVDFab can compress the video directly into MP4 without requiring a separate tool like HandBrake. I also like being able to choose the audio tracks and subtitles to match the device I plan to use for playback.
Pros:
  • Removes supported native DVD copy protection.
  • Supports hardware-accelerated encoding on compatible hardware and profiles.
  • Offers compressed output and passthrough profiles that preserve source streams.
Cons:
  • After the trial, free functionality falls back to the more limited HD Decrypter scope; use the DVD Ripper trial to evaluate its full output options.
Step 1: Run DVDFab DVD Ripper and Load Your DVD
 Free Download
 100% Safe & Clean
 Free Download
 100% Safe & Clean
Open DVDFab and choose the Ripper module. Insert the DVD into your optical drive and DVDFab will detect the disc automatically. You can also add the source manually via "+ Add" or by dragging the DVD, ISO, folder into the interface.
How to Rip DVD to USB using DVDFab DVD Ripper
Step 2: Pick Output Format or Preset Profile
After the DVD is loaded, go to the Profile liabrary. Here you have two straightforward options:
  • Choose an output container for USB playback: DVDFab supports MP4, M4V, AVI, and many other formats. If you already know which format your device accepts, use the Filter option to quickly narrow results.
  • Use a preset profile: For an even simpler workflow, it offers ready-made profiles for specific TVs, set-top boxes, game consoles, etc. Choose one of these presets and DVDFab will automatically apply the correct codec, resolution, and bitrate.
Steps to Rip DVD to USB using DVDFab DVD Ripper
Step 3: Tweak Your Video Preferences
At this stage, you can fine-tune the output before ripping.
  • Video Settings: Modify resolution and tweak bitrate or CRF for quality. Also, speed things up with hardware acceleration if you've got NVIDIA, AMD, or Intel.
  • Audio options: Choose which language tracks to keep, downmix 5.1 audio to stereo if needed, or preserve the original AC3/DTS.
  • Editing tools: Trim unneeded clips, crop black bars, rotate when needed, and adjust brightness or contrast. Use the preview to confirm the frame, subtitle position, and output appearance meet your needs.
Convert DVD to USB using DVDFab DVD Ripper
Step 4: Start Ripping DVD to Digital Format
Once satisfied with your settings, click Start. DVDFab will process the disc, apply your chosen quality and editing options, and output the file into the destination folder.
Step 5: Transfer to USB and Check It Out
After ripping finishes, locate the output file and copy it to your USB drive. Safely eject the drive after the transfer completes.
MakeMKV (For 1:1 Lossless Ripping)
Large MakeMKV files exceed FAT32 limits; exFAT or NTFS and MKV playback need device support.
MakeMKV 2.0.0 was released on September 20, 2026. Its DVD-opening functionality is free, and its MKV output preserves selected source streams without re-encoding. Converting DVD to MKV this way preserves the selected video and audio streams for a USB archive. This direct copy method reduces processing time and power consumption. File sizes remain large because the software preserves the source bitrate instead of compressing the video. The number of movies a USB drive can hold depends on the actual size of the selected titles and tracks.
In my tests, the main drawback was the large MKV file size. Many movies exceed 4 GB, which means they cannot be copied to a FAT32-formatted USB drive. I recommend checking the drive's file system first. If it uses FAT32, back up any existing files before formatting it to exFAT or NTFS, provided your playback device supports it. Despite the larger file sizes, I still prefer this method for home theater playback because it preserves the original video quality without re-encoding. Just make sure your player supports MKV and the selected audio and subtitle formats.
Pros:
  • DVD-opening functionality is free; free Blu-ray use is subject to beta terms and a valid beta key.
  • Since it does not re-encode, conversion is fast and energy efficient.
  • It preserves selected audio tracks, subtitles, and chapter information.
Cons:
  • Free Blu-ray use is subject to beta terms and a valid beta key; this does not affect free DVD-opening functionality.
  • There is no way to shrink file size.
  • Output is limited to MKV.
Step 1: Connect your external drive and open MakeMKV. The software scans for available optical hardware and displays the disc contents. You must wait for the program to parse the titles and chapters before you can make any selections.
How to Convert DVD to USB free using MakeMKV
Step 2: Navigate the tree view to identify the main movie title. You can expand this title to check or uncheck specific audio and subtitle tracks. The interface provides the codec type and language for each stream so you can decide which data to include in the final MKV container.
Step 3: Set the destination folder for your movie file. When you are ready, click the "Make MKV" button.
Rip DVD to USB for free using MakeMKV
Step 4: After MakeMKV finishes, copy the MKV file to your USB drive and safely eject the drive. If the target device does not accept MKV or the selected audio tracks, convert the file to a supported format using another tool.
HandBrake (Free, for Compressed Ripping)
HandBrake is a free, open-source video transcoding tool that converts unprotected DVDs to MP4, MKV, or WebM before you copy the files to a USB drive. This free DVD to USB converter compresses the video during the encoding process, allowing you to reduce file size with a small trade-off in image quality. It supports a wide range of codecs and can downmix 5.1 audio to stereo AAC for better playback on devices that struggle with multichannel tracks.
In my tests, HandBrake 1.11.2 (released on June 7, 2026) compressed a 6.13 GB video source into a 984 MB MP4 file, but the encoding took over 12 minutes. The smaller file size is useful for USB storage, although the processing time can add up when converting a large DVD collection. HandBrake re-encodes video, so the quality settings affect both file size and visual detail. It also supports hardware-accelerated encoding on compatible GPUs, which can reduce processing time. One limitation is that HandBrake cannot remove commercial DVD copy protection. You'll need an unprotected DVD or an existing unprotected video file as the input.
Pros:
  • HandBrake is entirely free and open-source.
  • Outputs MP4, MKV, or WebM with supported codecs.
  • Control the quality and bitrate to fit your specific needs.
  • Add a stereo AAC track while keeping the original surround track for compatibility.
Cons:
  • Does not remove commercial DVD copy protection; use unprotected DVD sources.
  • Encoding time depends on the selected codec, quality settings, and hardware.
  • The range of settings can be daunting for first-time users.
Step 1: Open HandBrake and click Open Source, then select your DVD drive. HandBrake scans the disc and lists the titles, including extras and bonus features.
How to Convert DVD to USB using HandBrake
Step 2: Select the longest title, which is usually the main feature. In Audio, keep the original surround track and add an extra track as AAC stereo downmix so basic TVs and players can switch to it. In Subtitles, choose the streams you need, including any forced subtitles.
How to rip DVD to USB Free using HandBrake
Step 3: Choose a preset for your device, then tune video and filters in this order:
1. Preset and codec
Pick a device-friendly preset such as TV 1080p30 Surround or Fast 720p30. Use the H.264 codec when you need the broadest playback compatibility, especially for standard-definition DVDs or older TVs that do not handle H.265 well.
2. Bitrate guidance
Adjust bitrate according to the source quality you are working with:
SourceTarget Bitrate
DVD (SD)about 3 Mbps
Blu-ray (FHD)about 5-10 Mbps
Blu-ray (UHD)about 30 Mbps
Lower bitrates save space but can introduce visible artifacts, so raise the value when you notice banding or loss of fine detail.
3. Make interlaced DVD progressive
  • For DVD content that shows combing on modern flat screens, enable Deinterlace or Decomb to produce a clean progressive result.
  • For film-based NTSC sources, consider inverse telecine to restore the film frame rate.
  • Add Deblocking when the source looks blocky.
4. Reduce heavy noise or grain
When older DVDs or low-bitrate sources look dark or grainy, open Filter, choose Denoise → NLMeans, and set Preset: Strong. This filter removes unwanted noise and helps the encoder keep detail in smoother gradients.
Command-line users can apply the same setting with HandBrakeCLI:
HandBrakeCLI -i input.vob -o output.mp4 -e x264 -b 3000 --denoise="nlmeans:preset=strong"
Step 4: Under Destination, choose where you want the converted file saved on your computer, and give it a clear name. Once everything is set, click Start Encode.
Step 5: Once the file has been encoded, copy it from your computer to the USB drive and safely eject the drive.
To keep this practical, I ran the same movie (8 Mile, 1h50m14s, 6.13 GB) through DVDFab, MakeMKV, and HandBrake on my Windows 10. Hardware was an Intel Core i7-6700 CPU and an NVIDIA RTX 4060 Ti 8 GB GPU. Below is a table of features and test results.
FeatureDVDFabMakeMKVHandBrake
Decryption abilityYes, handles CSS, region codes, ARccOS, abd moreLimited, bypasses some DVD protectionsNone by default, needs libdvdcss plugin
GPU accelerationYesNoLimited
Output formats1000+ video and audioMKV onlyMP4, MKV
Video editing optionsYesNoYes
SubtitlesBurn-in, external, multi-trackPass-through (keeps original)Burn-in or soft subtitles
CompressionYes, with quality/bitrate presetsNo, lossless remux onlyYes, full re-encoding
Test Results1m37s (MKV passthrough) 5m18s (H.264 MP4 encode)1m34s
(MKV passthrough)
12m28s
(H.264 MP4 encode)
Output Quality720*480
DTS 5.1
720*480
AC3 5.1
720*362
AAC 2.0
My observations
Running the same disc through each tool made the differences clear:
  • Passthrough speed: DVDFab and MakeMKV both finished in under two minutes. MakeMKV produced a slightly larger file, as it remuxes every stream by default. DVDFab outputs higher-quality audio with a smaller file.
  • Encoding performance: DVDFab took advantage of GPU, finishing the H.264 encode in about five and a half minutes. HandBrake took over twice as long as DVDFab, with a loss in quality.
  • Compatibility: The MP4 files from both DVDFab and HandBrake played on my Samsung TV and Honda car head unit without issue. The MKV files required playback on a laptop with VLC, since the TV rejected them.
After testing all three, their strengths became distinct. HandBrake excels at transcoding and compression, offering precise control for users. MakeMKV stands out for speed and lossless preservation. DVDFab DVD Ripper combines both strengths. It can perform passthrough output or hardware-accelerated encoding, giving users flexibility between archiving quality and efficient storage.
Way 2: Copy DVD to USB Directly Without Software
If your disc is a non-protected data DVD rather than a video DVD, there's a simple copy-and-paste method for transferring DVDs to a USB flash drive. The requirement is a DVD drive on your laptop, or an external DVD drive that can run your DVDs, and a USB flash drive. However, keep in mind that this method may not result in files playable on mobile players.
Copy DVD Files to USB Drive in Three Steps
On both Windows and macOS, the copy process is simple.
Step 1. Open the disc on your computer
Insert the DVD into the drive. On Windows, it should appear in File Explorer under "This PC." On macOS, the disc will mount in Finder's sidebar. Open the disc folder and check what files are present.
Step 2. Move the files to local storage
Select the video files you want to keep and copy them to a folder on your computer. This extra step reduces the risk of corrupted transfers, especially if the disc has scratches or the drive spins inconsistently. Wait until the copy finishes and confirm the files play correctly on your computer.
Step 3. Transfer the files to the USB drive
Open the USB stick or external SSD. In Explorer or Finder, drag the verified files onto the USB, then safely eject the drive after the copy completes. You now have a working copy of the DVD content on a portable medium.
How to Transfer DVD to USB Flash Drive Directly
Why You Can't Just Copy and Paste DVD Files to USB?
Copying readable DVD files to USB can preserve them for storage, but it does not convert DVD-video into a file that a TV or car player can play. Playback depends on the player's support for the folder structure, container, and video and audio codecs.
💡The Complexity of VIDEO_TS Folders
Movie DVDs do not store video as one continuous file. The data is located in a folder called VIDEO_TS which contains VOB and IFO files. VOB files hold the video but the system splits them into segments. Many TVs and car players cannot navigate a VIDEO_TS folder from USB. For those players, convert the selected title into a supported video file.
💡DVD Copy Protection and Region Codes
Commercial DVDs may use CSS copy protection and region restrictions. Copying their files does not remove those protections or convert the DVD structure. A dedicated DVD ripper can remove supported native disc copy protection and convert the selected title to a compatible playback file.
💡Hardware Compatibility Issues
Hardware like smart TVs and car players has limited codec support. MP4 with H.264 video is a common playback option, but the device must also support the audio codec. Movie DVDs use MPEG-2 video, which some USB media players do not accept. Convert the video only as needed to match the target device's supported container and codecs.
Way 3: Transfer DVD to USB Without Computer
Not everyone wants to install software, connect a drive, and manage encoding settings. In fact, I often get asked if there is a way to transfer DVDs to USB without touching a computer at all. The answer is yes, but it usually means turning to retail digitization services or stand-alone hardware solutions.
DVD to USB Service Near You
Several large retailers and photo service chains in the US offer DVD-to-digital programs. Walmart and CVS, for example, accept home movie DVDs and VHS tapes and offer USB delivery options.
MethodAdvantagesLimitations
Retail digitization services
  • No software to learn;
  • No personal DVD drive needed
  • Fees add up;
  • Processing takes time;
  • Commercial movie DVDs often rejected
A transfer service handles the conversion for you, but offers less control over bitrate, resolution, and subtitle handling than desktop software. For home videos and no access to a computer, a service with USB delivery avoids buying a DVD drive. As of November 2026, Walmart lists a starting transfer price of $15.96 for the first 90 minutes per device, $5.46 per additional 90 minutes, and a $12.96 USB add-on covering the order.
DVD Recorder with USB Output
Another option is using a DVD Player or Recorder with USB recording feature. A USB playback port alone does not mean the unit can record from DVD to USB. Select hardware whose manual explicitly supports recording or copying from DVD to USB and identifies the output format; follow its instructions for connecting the flash drive and starting the copy.
  • Simple one-button workflow
  • No PC required- Immediate access to files on USB
  • Hardware is difficult to source today
  • Usually cannot handle encrypted DVDs
  • Output formats fixed, may not play on all TVs
An MPEG-2 recording needs a player that supports both its file container and video codec. If the target TV does not support the recording, convert it to a format and codec combination the TV accepts, such as MP4 with H.264 video where supported.
Transferring DVD to USB without a computer is best suited to home video discs or users uncomfortable with software setup. For commercial DVDs, DVDFab DVD Ripper or MakeMKV can process supported discs. For unprotected DVDs, HandBrake also offers control over compression, audio, and subtitles.
Formats and Device Compatibility for USB Playback
Up to this point we've looked at how to copy or convert a DVD, but the real test comes when you plug the USB stick into a television, media box, or car head unit. Devices differ widely in what they will recognize. For a "file not supported" message, check the USB file system, container, and video and audio codecs against the player’s supported formats. Picture without sound points to an audio compatibility check; missing opening or closing scenes call for checking the selected DVD title and runtime.
Use MP4 for Compatible TV and Media Players
MP4 with H.264 video and AAC audio is a useful starting point for USB playback, but support is not universal: the TV or car player must accept that combination. Check each separately: MP4 is the container, while H.264 and AAC specify how the video and audio are encoded. If you get picture without sound, select a stereo audio track in a codec the player supports. Re-encoding can reduce file size, with picture quality depending on the source and quality settings. Remuxing preserves selected source streams without re-encoding, so it does not provide the same size reduction.
Keep MKV for quality and multiple tracks
MKV is useful for preserving selected original video and audio streams, multiple audio tracks, and subtitles without re-encoding. Selectable tracks and chapter markers are separate from interactive DVD menus, which an MKV file does not preserve. MakeMKV outputs MKV directly, and DVDFab also supports it. The trade-off is compatibility. A TV may support MKV but not the video or audio codec inside it, so compare both with the TV’s supported formats. If you rip DVDs for Plex or play the files on a laptop with VLC, MKV can preserve the selected streams, provided your playback setup supports them.
USB file system and size limits
The physical format of the USB drive often causes more problems than codec issues. FAT32 has broad playback-device support, but its single-file limit is just under 4 GiB; MediaZilla's USB formatting guide explains the file-system options for TV playback. That means long movies or high-quality MP4s can run into fail-to-copy or fail-to-play problems. exFAT supports larger individual files, but the target TV or media player must support exFAT to read the drive. NTFS works well on Windows devices but has more limited support among TVs. Before formatting, back up the files already on the USB drive, since formatting erases them. Use exFAT or NTFS for larger files only if your playback device supports that file system; FAT32 remains an option for older players when each file stays below its limit.
To estimate how many movies a 128GB flash drive can hold, divide its available storage by the actual size of a converted movie file, using the same units. Allow room for differences in file size between movies.
Can I copy a protected DVD to USB by dragging its files?
Dragging files from copy-protected DVDs to USB does not remove their copy protection or convert their DVD-video structure. For USB movie playback, use a DVD conversion tool that supports the disc and creates a file with a container and codecs your player accepts.
Can I use ISO or VIDEO_TS on USB playback?
Yes, you can copy a VIDEO_TS folder or ISO image to a USB stick, but playback depends on the device. On a computer, compatible playback software can open VIDEO_TS folders or ISO images; interactive menus require DVD-navigation support. On most TVs or car players, these structures are not recognized. They look for a single video file, not a DVD file tree. For TV or car playback, convert the disc to an MP4 with supported video and audio codecs. MP4 and MKV can retain chapter markers or selectable tracks where supported, but they do not retain interactive DVD menus. VIDEO_TS and ISO are best kept for archiving.
Why does my USB fail to copy files over 4GB?
This usually comes down to the FAT32 file system. FAT32 has a single-file limit just under 4 GiB, even if the drive has plenty of free space. Two-hour DVD rips often exceed that limit. Back up the USB drive before reformatting, since formatting erases its contents. Choose exFAT or NTFS for larger files only if the target playback device supports that file system. If reformatting is not possible, split the video into two parts during encoding.
How Can I Keep DVD Subtitles on USB?
DVD subtitles are stored as separate image streams, not text. When converting, you have two choices:
  • Burn in: subtitles are overlaid permanently onto the video and remain visible whenever the video plays.
  • Soft subtitles: kept as switchable tracks in MKV or MP4. This is flexible but requires the player to support them.
Burn-in is useful for TV and car players that do not support switchable subtitles. For Plex or VLC, keep switchable tracks if your playback setup supports them. When you extract subtitles from DVD, DVDFab DVD Ripper on Windows also offers OCR conversion to SRT, turning subtitle images into text. An external SRT file needs player support and a filename matching the video.
Which Free DVD to USB Converter Suits Home Movies?
HandBrake is free and open source and converts unprotected DVDs to MP4, MKV, or WebM. MakeMKV offers free DVD-opening functionality and saves selected video, audio, and subtitles in MKV without re-encoding. For home movies that need smaller files, use HandBrake; to preserve selected source streams, use MakeMKV if your player supports them. Existing readable data files can also be copied directly to USB without conversion software.
Can an Online Converter Read a Physical DVD?
An upload-based online converter needs video files already extracted from the disc. It cannot replace a connected DVD reader or the software needed to extract DVD-video. If you already have a video file, an online converter may convert it to a format your player supports. If you have no computer or DVD drive, a transfer service is an option for home videos.
Why does my TV not play video from USB?
The USB drive's file system, the video container, and the video and audio codecs must all be supported by the TV. Check the device manual, then use the compatibility guidance above to choose an output the TV accepts.
Choose direct copying for readable data files, MP4 when USB storage and device compatibility matter most, or stream-preserving MKV when the player supports the selected tracks. Before relying on the USB, confirm playback on the intended device.
Disclaimer: Use only discs you legally own or content you are authorized to access and reproduce for personal backup and offline playback, in accordance with applicable local laws and relevant terms. Do not redistribute copies without authorization.
