How to Play DVDs on PS4 in 3 Ways in 2025 [Free & Easy]
Summary: How to play DVDs on PS4 easily? What’s the best alternative to PS4 DVD player? If you are a game console user, these questions are crucial to you. Read this post to master three ways to play DVDs on PS4, and rip DVDs to compatible videos for better playback on mobile devices.
PlayStation 4, or PS4, is a home video game console developed by Sony for game enthusiasts. But can the PS4 play DVDs? PS4 is not only a game console; it also works as a media player for DVD/Blu-ray movies and various video files, including 4K videos.
Watching free movies on PS4 is great, but you may encounter some annoying playback issues due to various known or unknown reasons. To tackle the playback problems completely, you can convert your DVDs to popular formats, like DVD to MKV. So in this article, we will show you how to play DVDs on the PS4 directly and how to rip them to PS4 video formats and then play movies on the PS4 through a USB stick.
Part 1. Does PS4 play regular DVDs?
If you're wondering whether your PlayStation 4 can double as a DVD player, you're in luck. In addition to being a powerful gaming console, the PS4 is also fully capable of playing regular DVDs. Here's what you need to know.
- Yes, the PS4 plays standard DVDs, including commercial movie discs and homemade recordings.
- The first time you use it for DVD or Blu-ray playback, your console will need to connect to the internet to enable this feature.
- Note that the PS4 does not support DVD-Audio or certain specialty formats.
PS4-supported DVD and Blu-ray Formats
✅Supported DVD Formats:
| Disc Type | Supported? |
| DVD-ROM (commercial) | ✔ Yes |
| DVD-R / DVD-RW | ✔ Yes |
| DVD+R / DVD+RW | ✔ Yes |
| DVD-Video (standard movies) | ✔ Yes |
| AVCHD (on DVD) | ✔ Yes |
💡Note: Copy-protected or region-locked DVDs may not work if they don’t match your PS4's region.
✅Supported Blu-ray Formats:
| Disc Type | Supported |
| BD-ROM (commercial Blu-ray) | ✔ Yes |
| BD-R (single-layer and dual-layer) | ✔ Yes |
| BD-RE (rewritable) | ✔ Yes |
| 3D Blu-ray | ✔ Yes (from system software 1.75 and above) |
💡Note: Ultra HD Blu-ray (4K UHD) discs are not supported — only the PS5 supports those.
Part 2. How to Play DVDs on PS4 Directly
All the DVD formats including DVD-ROM, DVD-R/RW, and DVD+R/RW are supported by PS4, but to make sure you can play your DVDs successfully, you had better update it to the latest system version. The playback of DVDs on PS4 is pretty easy, and you can begin by inserting a DVD disc into the disc tray of your PS4. In this sense, you have come to an easy PS4 DVD player.
How to Play DVDs on PS4 Easily: A Complete Guideline
- Step 1: Turn on your PS4 and sign in to your account if needed.
- Step 2: Insert the DVD you want to watch into the optical drive of your PS4.
- Step 3: When the menu appears, find the disc icon and press the play button to start the DVD movie.
For those interested in more than just DVDs, you might be curious about how to play Blu-ray on PS4. The process is similar, with the PS4 also supporting Blu-ray discs, allowing you to enjoy high-definition content seamlessly.
Common PS4 DVD Playback Errors & How to Fix Them
1. "Cannot Start the Application" or "Needs Internet Connection"
Cause:
- First-time use of DVD playback
- Feature not yet activated online
Fix:
- Connect the PS4 to the internet at least once to enable disc playback functionality.
- Restart the console after the connection is established.
2. Disc Skipping, Freezing, or Noisy Operation
Cause:
- Dirty, dusty, or scratched disc
- Disc not seated properly
- Poor ventilation causing overheating
Fix:
- Clean the DVD gently with a microfiber cloth from the center outward.
- Try a different DVD to isolate if the issue is with the disc or the PS4.
- Keep your PS4 in a cool, dust-free environment.
- Fix scratched DVD by using a disc repair kit or applying a small amount of toothpaste to the scratched area, gently rubbing it in with a soft cloth, and then wiping it clean. This can help fill in minor scratches and improve playback.
3. Region Code Mismatch
Cause:
- DVD is locked to a region different from your PS4
Fix:
- Only use region-matching DVDs (e.g., Region 1 for North America).
- For frequent foreign discs, consider ripping the DVD to a region-free digital copy and playing it via USB.
4. No Video or Audio Output
Cause:
- Loose or improperly connected HDMI cable
- Incorrect input source or resolution
Fix:
- Check all HDMI and power cables for secure connections.
- Verify your TV is set to the correct HDMI input.
- Go to Settings > Sound and Screen > Video Output Settings and adjust resolution.
5. Blu-ray/DVD Playback Stutters or Lags
Cause:
- System overload
- Disc issues
- Outdated system software
Fix:
- Restart the PS4 and try again.
- Update your PS4 to the latest system software via Settings > System Software Update.
- Try a different disc to rule out a faulty DVD.
It is simple to use PS4 to play DVD discs, but you may meet various playback errors that prevent you from watching free DVD movies on PS4. Problems caused by the internet connection or improper assembly of the connectors, DVD dust, etc. are easy to be solved, but errors from scratched disc or region code limitations cannot be fixed.
There is still another way to play the movies on scratched DVD discs or DVD discs with region code on PS4. You can use DVDFab DVD Ripper to rip and convert your DVDs to PS4 or PS4 compatible formats and then play the converted DVD movies on PS4 with the best free media player.
Part 3. How to Rip DVDs to PS4 Compatible Videos
The Best DVD to PS4 Converter - DVDFab DVD Ripper
How to Rip DVD to PS4 to with DVDFab DVD Ripper Easily
Step 1: Run DVDFab 13, go to the Ripper module and insert the DVD disc you want to rip. Then DVDFab will load the DVD source automatically.
Step 2: In order to watch movies on PS4, hit 'Choose Other Profile' > 'Device" > 'Sony' to select the Play Station 4 as the profile. If you want to convert the DVD to a certain format you like, you should click the Format tab instead.
Step 3: Now you are able to customize the video in your way. The main movie title has been selected by default here, but you still can choose other titles when you rip DVD on PS4.
Then you can change the title name and choose the chapters, audio tracks, and subtitles you want.
When you rip DVD to PS4, you also can click the Wrench icon to customize your settings like codec, frame rate, resolution, etc., and use the built-in editor to set the aspect ratio, trim and crop the video, add watermark and subtitles, adjust picture values, etc.
Step 4: Navigate to the bottom of the main interface and click the Folder icon to select a directory to save the output video. And then you can click the Start button to start the process of converting the DVD to PS4.
Part 4. How to Play Converted DVDs on PS4 via USB
You are close to watching free movies on PS4. When the conversion is complete, you can put the PS4-supported videos on your USB stick that can be connected to your PS4 and then play it. But before playing the video, you need to download and install the Media Player app on the PlayStation Store first. Just go to the PlayStation Store, find the app, and install it.
Below are the detailed steps of playing the converted DVD on PS4 through USB.
- Step 1: Open Media Player. If your USB storage device is on the same network as your PS4, it will be detected automatically.
- Step 2: Select the USB device.
- Step 3: Find the DVD video and click it to play it.
Of course, if you are a DVDFab fan with DVDFab Player 6 at hand, it will be more convenient to play the converted PS4 DVD to video files on the best 4K media player.
Part 5. Extension: How to Convert DVD to PSP?
The Best DVD to PSP Converter - DVDFab DVD Ripper
Ever thought of watching your DVD movies on your PSP? Just also use DVDFab DVD Ripper to convert your DVDs in 4 steps, then the output can be played on the portable gaming device. If you're interested, please follow me.
Step 1: Run DVDFab, choose Ripper option, and Load in the DVD for conversion
After download and installation of DVDFab, run it and go to Ripper option. If you want to convert a DVD disc, insert it into the optical drive; if your source is a DVD folder or a DVD ISO image file, just drag and drop it into DVDFab interface.
Step 2: Select a profile compatible with your PSP
Then click "Choose Other Profile" - "Device" - "Sony" or "Other" to select a profile according to your PSP type.
Step 3: Do advanced settings and video editing
Then go back to the main interface, you can customize video and audio parameters via "Advanced Settings" and "Video Edit".
Step 4: Trigger the DVD to PSP conversion process
Hit Start button to start conversion if all settings are OK. All detailed progress info will appear right in front of you. Soon after, you will get a high quality video. Just enjoy it!
Yes, the PS4 can play Blu-ray discs in addition to DVDs. To play a Blu-ray on your PS4, simply insert the disc into the optical drive, and it will appear in the dynamic menu. Select the disc icon and press the play button. Ensure that your PS4 is updated to the latest system software to ensure compatibility with Blu-ray playback.
Does the PS5 play DVDs?
Yes, the PS5 can play DVDs. Along with support for 4K UHD Blu-ray discs and standard Blu-rays, you can insert a DVD into the PS5's disc drive and it will show up on the home screen, where you can start the movie. For more details on how this works, you can check our guide on does the PS5 play DVDs?
Does the PS3 play Blu-rays?
Yes. All PS3 models can play Blu-ray discs and standard DVDs with up-to-date system software. For backups on PS3, I prefer preserving the full disc structure with PS3 ISO image to retain menus and chapters.
To sum up, does PS4 play DVDs? YES! PS4 can play commonly used DVDs. This post told you how to play DVDs on PS4 in different ways. If there are problems when playing a DVD PS4, you can rip and convert it to PS4 compatible formats with DVDFab DVD Ripper and then play it through a USB storage device without any limitations.
![How to Rip DVDs for Plex Streaming on Windows & Mac [2025 Updates]](https://r1.dvdfab.cn/upload/resource/ripping-dvds-for-plex-B7WR.jpeg)
