How to Rip DVD with VLC Media Player on Mac, Windows, and Linux [2026]
Summary: VLC DVD Ripper is not a separate product; it is VLC Media Player's built-in disc conversion function for saving readable DVDs as MP4, MKV, AVI, or MPEG files. VLC may work well for simple, unprotected DVDs, and you can simply click "Media > Convert/Save > Disc" to rip DVD with VLC. DVDFab DVD Ripper is more suitable when VLC cannot read the disc, keep subtitles, select the right title, edit the video, or convert the DVD faster.
Here's the short answer: a VLC DVD ripper can convert an unprotected DVD to MKV or MP4, but the result depends on selecting the right title, audio track, subtitles, and output profile. VLC is useful for occasional conversions, not for discs that repeatedly fail to load or encode.
I use VLC for simple homemade DVDs because its built-in conversion tool is available on Windows, macOS, and Linux. For a commercial or unusually structured disc, the important checks are the title, MP4 profile, and a short playback test. This guide explains how to rip DVD with VLC, select the right movie or episode, and fix common VLC failures.
What VLC Can and Cannot Rip
VLC is a media player first, and its DVD ripping feature is really a conversion feature inside the player. It works best with homemade or unprotected DVDs, but it can become unreliable when a disc has copy protection, multiple titles, complex subtitles, or damaged sectors.
That is why I would check the disc type before starting. The table below shows when VLC is worth trying and when is not.
| DVD situation | VLC result | What to expect |
| Homemade or unprotected DVD | Usually suitable | Convert a selected title to MP4 |
| One movie with simple tracks | Usually suitable | Quick, occasional conversion |
| TV series or bonus-heavy disc | Limited | Select each episode title manually |
| Multiple languages or commentary | Check first | Preview the intended audio track |
| Scratched or damaged DVD | Limited | Freezes or partial files are possible |
| Protected commercial DVD | Usually unsuitable | VLC may not process the disc |
Rip DVDs with VLC on macOS, Windows or Linux: Step-by-step
Before following the steps below, download the latest VLC directly from VideoLAN rather than using an old installer from a third-party site. As of September 2026, the latest VLC 3.0 release for Windows and macOS is VLC 3.0.23.
How to Rip a DVD with VLC on Mac
Step 1: Install VLC on macOS
Download and open the latest version of VLC Media Player. If your Mac does not have a built-in optical drive, connect an external DVD drive first. Many newer Macs do not include a disc drive, so a USB or USB-C external DVD drive may be necessary before you can rip DVD with VLC Mac.
Step 2: Load the DVD into VLC
Insert the DVD into the drive and wait for macOS to mount the disc. Open VLC Media Player, then from the top menu choose File → Open Disc.
Set the disc type to DVD. If VLC keeps looping on the DVD menu, clear the check box labeled Use DVD menus or enable No disc menus, then confirm by selecting Open. VLC will begin playback, which helps you confirm that the disc has loaded correctly.
Step 3: Identify the main feature, language, and subtitles
Before converting the full DVD, play it for a minute. Open the Playback menu and pick Title. The main movie is often the longest title, but this is not always true for TV series discs or discs with bonus content.
- From the Audio menu, pick Audio Track and choose the correct language instead of a commentary track.
- From the Subtitles menu, enable the subtitle track you want to include or test before conversion.
- If the DVD has several episodes, write down the title number for each episode before ripping.
Step 4: Configure DVD Ripping Settings
Open File → Convert / Stream. Under Choose Profile, set MP4 (H.264 + AAC) as the target format. This combination is a safe starting point because it plays well on most computers, TVs, phones, and tablets.
Then open Customize to refine the conversion settings:
- Video Codec: choose H.264. For standard DVDs, start with a moderate bitrate such as 2,000-3,000 kilobits per second, or use a constant-quality value near 20 if your VLC build offers that option.
- Audio Codec: choose AAC with 128–192 kilobits per second bitrate. Keep the same channel layout as the source when possible, such as stereo or 5.1.
Step 5: Start Ripping DVD
Select Choose Destination, specify an output folder, and give the file a clear name that ends with .mp4. Click Save or Go to begin the conversion.
How to Rip a DVD on Windows with VLC
Step 1: Download the latest VLC from the official VideoLAN website and complete the installation. The official Windows download page currently lists VLC 3.0.23, so avoid old installers unless you have a specific compatibility reason.
Step 2: Open the DVD source
Insert the DVD into your computer's optical drive. On the VLC menu bar, select Media → Convert / Save. In the Open Media window, open the Disc tab and check DVD under Disc Selection.
If VLC keeps recording the DVD menu instead of the movie, enable No disc menus. You can preview the playback by pressing Play, or move on by selecting Convert / Save.
Step 3: Confirm the title and chapters
In the same window, under Starting Position, select the title or chapter you want to rip. The main movie is usually the longest title, but trailers, menus, and bonus clips can also appear as separate titles. If you are ripping a TV series DVD, you may need to convert each episode title separately.
Then select Convert / Save at the bottom of the window.
Step 4: Set the conversion options
Under Settings, choose Convert. In Profile, pick Video - H.264 + MP3 (MP4) or an MP4 profile with H.264 video and AAC audio. If VLC creates a video with no sound, edit the profile and make sure the audio codec is enabled.
Next, click the Browse button beside Destination file, choose a save folder, and give the file a name ending in .mp4.
Step 5: Start ripping DVD on Windows
Once you have checked the title, profile, and destination file, hit Start to begin conversion. The progress bar in VLC shows encoding in real time.
How to Rip a DVD with VLC on Linux
Given the user base, only the installation instructions for Ubuntu are provided here. For other Linux distributions, please refer to the official VLC website or your distribution's package manager for installation guidance.
Step 1: Install VLC to your computer. VLC is available in the default Ubuntu repositories. To install VLC, run:
sudo apt install vlcIf you require the absolute latest version of VLC, you can add the official VLC developers' PPA. First, add the PPA and update your package lists:
sudo add-apt-repository ppa:videolan/master-daily
sudo apt updateThen, install VLC with:
sudo apt install vlcStep 2: Launch VLC, click on "Media" in the navigation bar. Then, choose "Convert/Save" from the drop-down menu.
Step 3: Choose the "Disc" tab on the pop-up window. Browse to the location of your DVD and confirm you select the right disc device. If VLC gets stuck in the DVD menu, enable No disc menus. Then, click on "Convert/Save".
Step 4: Select the title or chapter you want to convert. Then, select a profile for your ripped video. If you're unsure, "Video - H.264 + MP3 (MP4)" is a reliable default. Choose the destination file and click "Start" to begin.
If VLC cannot read the DVD on Linux, the problem may be the disc, the drive, the region setting, or copy protection. Test whether VLC can play the DVD normally before assuming the conversion steps are wrong.
Troubleshooting VLC DVD Ripper: Common Errors and Fixes
If VLC fails during DVD ripping, use the table below to find the most likely cause and the first fix to try. I have grouped the issues by what you can actually see in the output file, such as no audio, missing subtitles, wrong title, freezing, or slow conversion.
| Issue | Cause and Recommended Action |
| VLC rips the DVD menu instead of the movie | DVD menus may be enabled. Turn on No disc menus and choose the main title manually. Preview the title before conversion if you are not sure. |
| VLC rips only one episode | TV series DVDs usually store episodes as separate titles. Preview the title list first, then convert each episode title separately. |
| VLC rips the commentary track | The wrong audio track may be selected. During playback, check Audio → Audio Track and choose the main language track before conversion. |
| No subtitles in output | VLC may skip embedded subtitle tracks if the subtitle track is not selected or if the subtitle format cannot be burned into MP4 output. Open Subtitles and choose the correct subtitle track before converting. For important subtitles, test a short chapter first. |
| DVD fails to load or play | The problem may be the disc, the drive, the region setting, or copy protection. If VLC cannot play the DVD normally, it will probably not convert the DVD correctly either. |
| Conversion freezes or skips | Scratches, dirt, or unreadable sectors can interrupt the ripping process and result in partial output. Clean the disc, disable DVD menus, and try again. If the same spot fails every time, VLC may not be enough. |
| Slow ripping speed | VLC conversion can take close to the running time of the DVD because it reads and encodes the video. Close other apps and avoid high bitrate settings if your computer is struggling. |
| Ripping DVD without audio | The wrong audio track may be selected, or the output profile may not encode audio correctly. During playback, check Audio → Audio Track. When setting the output profile, choose AAC or MP3 as the audio codec. |
| Audio and video out of sync | CPU overload, frame-rate handling, or unstable reading from the disc can cause sync drift. Try a short test rip, close other software, lower the output settings, or use another tool like DVDFab DVD Ripper if the problem continues. |
In my testing, the most useful habit was checking the output right after a short conversion. If the file has sound, subtitles, the correct title, and normal sync, I continue with the full DVD. If not, I adjust the track or title settings before wasting more time.
When VLC Is Not Enough: Choose the Right Tool for the Job
When a DVD has complex titles, repeated read failures, or track-selection problems that VLC cannot resolve, a different tool may be more appropriate. The comparison below distinguishes simple conversion, compression, title preservation, and dedicated personal-backup tasks.
| Tool | Best For | Not Ideal For |
| VLC | Quick conversion from simple or unprotected DVDs | Batch ripping, protected discs, complex subtitles, TV series DVDs |
| MakeMKV | Keeping DVD titles, chapters, audio tracks, and subtitles without re-encoding | Small MP4 files, because MKV output can be large |
| HandBrake vs VLC | Compressing video to MP4 or MKV with detailed control over size and quality | Copy-protected sources, because HandBrake does not defeat copy protection |
| DVDFab DVD ripper | Batch jobs, protected discs, subtitle control, and more formats and device presets | Users who only need one simple free conversion |
Best VLC Alternative: DVDFab DVD Ripper
DVDFab DVD Ripper is a dedicated DVD ripping program for users who need more control than VLC can offer. It supports copy-protected DVD discs, ISO files, and folders, and can export videos to common formats such as MP4, MKV, AVI, and other device-friendly profiles. It is especially useful when you need to choose specific titles, audio tracks, subtitles, edit the video, or process several DVD sources with fewer manual steps.
In my test using DVDFab 13.0.5.9 on Windows 10, the software ripped a 159-minute movie in about 5 minutes and 27 seconds. The actual speed may vary depending on your DVD drive, computer hardware, disc condition, output profile, and whether hardware acceleration is available, but the result was much faster than the real-time conversion I usually expect from VLC.
- Work around copy-protected discs that VLC cannot read or convert correctly
- Keep updates to support newly released discs.
- Select specific audio tracks and subtitle tracks before conversion
- Batch convert multiple titles or discs with less manual setup
- Choose device-friendly output formats such as MP4 or MKV
- Trim, crop, add subtitles and watermarks to videos before conversion
- Employs advanced GPU acceleration technology that allows users to convert DVDs faster
How to Rip DVD Using DVDFab DVD Ripper?
Now have a look at the complete user guide on how to digitize a DVD using this software.
Step 1: Open DVDFab and choose the Ripper module
Launch DVDFab and select the Ripper module from the main interface.
Free Download macOS 12 and newer
Step 2: Load the DVD, ISO file, or VIDEO_TS folder
Insert the DVD disc or add the ISO/folder source. After the source is loaded, check that the main title is selected correctly.
Step 3: Choose the output format
Open the profile panel and choose the output format you need. If you are not sure which format to select, converting DVD to MP4 is usually a practical choice for phones, computers, TVs, and media servers.
Step 4: Select audio and subtitle tracks
Choose the language track and subtitle track you actually need. This step is useful if VLC previously ripped the commentary track, missed subtitles, or selected the wrong episode.
Step 5: Select the output path and start conversion
Choose a save location, review the output settings, and click Start. After conversion, play the file for a few minutes to confirm that the title, audio, and subtitles are correct.
DVDFab DVD Ripper vs VLC DVD Ripper
| Features | DVDFab DVD Ripper | VLC DVD Ripper |
| Input Format | DVD, ISO, Folder | DVD, CD |
| Output Format | 1000+ video & audio formats | MP4, MKV, AVI, etc |
| DVD Decryption | YES (latest & advanced protections) | Partial (needs libdvdcss) |
| User Interface | User-friendly and intuitive | Basic and straightforward |
| Ripping Speed | 50X faster | Moderate speed |
| Quality Control | Advanced options for quality settings | Basic quality options |
| Batch Processing | Yes | No |
| DVD Menu Options | Yes (customizable) | No (menus disabled by default) |
| 3D and UHD Support | Yes | No |
| Output Customization | Extensive (subtitles, audio tracks) | Basic options |
| Best Use Case | Complex discs, protected discs, batch jobs, subtitle-heavy DVDs | Simple, free conversion from unprotected DVDs |
If you're not concerned about ripping speed and don't have high demands for output quality, VLC may serve you just fine for occasional, simple jobs. However, if you're ripping large libraries, dealing with tricky or scratched discs, or want to customize every detail, the time (and headache) you save with DVDFab DVD Ripper is well worth it.
FAQs about Ripping DVDs with VLC
Is it legal to rip a DVD with VLC?
Rules depend on the disc and intended use. Limit conversion to discs you are authorized to copy, keep the file for personal, noncommercial use where permitted by applicable law, and do not distribute it.
Why does my VLC DVD rip have no sound on my TV?
The selected audio stream or codec may not play on the TV. Choose the main language track, use AAC or MP3 in an MP4 profile, and test a short clip on the target TV before converting the full disc.
How Long Does It Take to Rip a DVD with VLC?
VLC often takes close to the running time of the DVD because it reads and encodes the video during conversion. A 90-minute DVD may take around that long or longer depending on your computer, drive speed, output settings, and disc condition. If speed is important, VLC may not be an efficient tool.
Can VLC Rip Copy-protected Blu-ray?
Not reliably. VLC can open some Blu-ray content, but encrypted Blu-ray discs often require AACS-related support. VLC is not a complete Blu-ray ripping solution, so commercial Blu-ray discs usually need a professional tool like DVDFab Blu-ray Ripper.
How to Rip Blu-ray with VLC?
Ripping a Blu-ray Disc using VLC is somewhat similar to ripping a DVD, but because Blu-ray Discs use stronger encryption, additional steps and requirements are needed.
Requirements:
- VLC media player: Make sure you have the latest version of VLC installed on your computer.
- libbdplus: This library is required to decrypt Blu-ray Discs.
- KEYDB.cfg: The key database for decrypting Blu-ray AACS. It can usually be found on VLC forums or other support sites.
Steps to rip a Blu-ray Disc using VLC:
Step 1: Download the KEYDB.cfg file and place it in the following directory depending on your operating system:
- Windows: C:\ProgramData\aacs\
- macOS: /Users/YourUsername/Library/Preferences/aacs/
- Linux: /home/YourUsername/.config/aacs/
Step 2: Insert the Blu-ray Disc into the Blu-ray drive. After launching VLC media player, click "Media" from the top menu and select "Convert/Save".
Step 3: Go to "Disc" tab > Select the disc type as "Blu-ray".
Step 4: After picking the title you want to rip, click the "Convert/Save" button at the bottom. In the "Convert" window, select the format and destination where you want to save the ripped video.
Is VLC better than HandBrake or MakeMKV?
It depends on the job. VLC is easiest for a quick free conversion from a simple DVD. MakeMKV is better when you want to preserve titles, chapters, audio tracks, and subtitles without re-encoding. HandBrake is better for compressing video into smaller MP4 or MKV files, but it does not defeat copy protection.
Final Thoughts
VLC is still worth trying first because it is free, familiar, and good enough for many simple DVDs. Just keep its limits in mind before you spend time troubleshooting the same disc again and again.
My practical advice is simple: use VLC for simple, unprotected DVDs, and switch tools when VLC repeatedly gives you the wrong title, missing audio, missing subtitles, or read errors. That way, you can use VLC where it makes sense and avoid wasting time where it does not.
