Ripping a disc you own looks simple until you hit encrypted Blu-ray protections, a missing device preset, or a tool that behaves differently on Mac than on Windows. I tested VideoByte BD-DVD Ripper alongside DVDFab Blu-ray Ripper on the same 33.43GB source disc with aligned output settings to give you measured results rather than marketing claims. This videobyte bd-dvd ripper review covers core features, real-world conversion performance, current Trustpilot ratings, and a side-by-side comparison so you can evaluate both tools against your actual workflow.
VideoByte BD-DVD Ripper Review 2026: Features, Test Results, and Comparison
VideoByte BD-DVD Ripper is a disc-to-digital converter for Windows and macOS. It reads DVDs and Blu-ray discs (along with ISO files and disc folders) and converts them to standard video and audio formats for playback across a wide range of devices and media players. One aspect Mac users tend to cite as an advantage: unlike Handbrake, which requires libdvdcss as a separate library to handle copy-protected DVDs, VideoByte bundles its decryption engine in the installer, reducing setup steps on macOS. Support for specific copy-protection schemes varies by disc, region, and software version; rip only discs you own and comply with local laws.
VideoByte preserves source quality and offers output up to HD or higher resolution when the source and settings allow. You can adjust parameters including resolution, bitrate, and frame rate to balance quality against file size. Upscaling can increase output resolution, but it cannot recover detail that was not in the original recording.
The sections below cover VideoByte BD-DVD Ripper's key features, hands-on pros and cons, and a step-by-step ripping walkthrough.
💡If you want to know other functions of VideoByte, you can refer to VideoByte DVD Creator Review.
Key Features of VideoByte BD-DVD Ripper
Below is a breakdown of what the software offers across its main capability areas, including practical notes on where each feature has limits.
Built-in Copy Protection Removal
VideoByte BD-DVD Ripper supports common DVD and Blu-ray protections including CSS, APS, ARccOS, CPRM, AACS, BD+, Cinavia, and region codes, converting supported discs to formats such as MP4 and MKV. The range of discs it can successfully handle depends on the specific protection variant, the disc's region, and the installed software version.
VideoByte BD-DVD Ripper copy protection removal
300+ Output Formats
The software outputs to over 300 audio and video formats including MP4, MP3, MOV, and AAC, covering most device and platform requirements. It also handles 2D and 3D video conversion. Worth noting: the device preset library is smaller than some alternatives, and presets for Google and Microsoft platforms are not prominently listed, which may affect playback compatibility on those devices.
VideoByte BD-DVD Ripper output format support
High-Quality Output with Optional Upscaling
VideoByte targets lossless or near-lossless output at a 1:1 ratio when the source and settings allow. The built-in video enhancer can upscale resolution, reduce noise, and adjust brightness and contrast for older DVDs or lower-quality Blu-ray sources. One important clarification: this upscaling works on standard DVD and 1080p Blu-ray sources. It does not decrypt or rip commercial 4K UHD Blu-ray discs. If ripping 4K UHD content is your primary requirement, you will need a tool with dedicated UHD decryption support.
VideoByte BD-DVD Ripper high-quality output settings
Subtitle and Parameter Control
You can retain multiple subtitle tracks and audio streams in the output file, or limit the selection to reduce file size. A compatible media player will then let you switch between the retained tracks during playback. Advanced parameter settings for resolution, aspect ratio, bitrate, frame rate, audio channel, and audio encoding are also available to fine-tune the quality-versus-storage trade-off.
VideoByte BD-DVD Ripper subtitle and parameter settings
Built-in Video Editing Tools
Before exporting, you can make basic edits including crop, cut, rotate, add effects, and apply watermarks. This is useful for trimming unwanted content or adjusting the picture without needing to bring the output into a separate application. The editing tools cover typical use cases but are not a substitute for dedicated video editing software.
VideoByte BD-DVD Ripper built-in video editor
Pros and Cons of VideoByte BD-DVD Ripper
The following reflects patterns from hands-on testing and Trustpilot user reviews across both the software's strengths and recurring friction points.
What it does well
  • Intuitive interface that keeps advanced settings accessible without cluttering the main view
  • Built-in decryption engine works on both Windows and macOS without requiring third-party libraries
  • Over 300 output formats cover most device and platform requirements
  • Retains multiple subtitle tracks and audio streams in a single output file
  • Handles both 2D and 3D source content
Where it falls short
  • On macOS, only one subtitle track can be hard-coded into the output file
  • Device preset library is smaller than some alternatives, with limited coverage for Google and Microsoft platforms
  • A small number of recent reviews still mention activation-code or purchase-support problems
How to Rip DVDs and Blu-rays with VideoByte BD-DVD Ripper
Author
When I loaded a Blu-ray disc in testing, VideoByte defaulted to the main movie title, which is the right call for most users. One thing to note before you start: there are separate buttons for "Load DVD" and "Load Blu-ray." You cannot drag and drop disc content into the interface — all disc sources must be loaded through the menu buttons.
Step 1: Connect a Blu-ray or DVD drive to your system and insert the disc. Launch VideoByte BD-DVD Ripper, then click Load Blu-ray or Load DVD to import the disc content.
How to rip Blu-ray using VideoByte BD-DVD Ripper Step 1
❗Please note that "Load DVD" and "Load Blu-ray" each have their own button. Videos cannot be added by dragging and dropping; they must be selected through the interface.
Step 2: Select the Full Movie list to rip the entire disc content. Otherwise, VideoByte automatically selects the main movie by default. Click the Rip all to option in the drop-down list to choose your output format and destination.
How to rip Blu-ray using VideoByte BD-DVD Ripper Step 2
Step 3: A pop-up window will appear for selecting the output format. You can also open the output settings by clicking the icon next to the listed movie titles.
How to rip Blu-ray using VideoByte BD-DVD Ripper Step 3 format selection
❗When you choose MKV as the output format, a pop-up window will prompt you to select a different format. Switch to another format such as MP4 in that case.
⚡I also noticed that VideoByte does not clearly list Google or Microsoft devices among its compatible output options. If your target device is not in the preset list, the video may fail to play or may not be detected at all.
How to rip Blu-ray using VideoByte BD-DVD Ripper Step 3 output settings
💡The "video enhancer" feature improves output quality by upscaling resolution, reducing noise, and adjusting brightness and contrast. It is most useful for older DVDs or standard Blu-ray sources. High-resolution upscaling takes longer to process and cannot recover detail that was not in the original recording.
In my test, this was one of VideoByte's more useful features because I did not need to move the converted video into a separate editor for basic adjustments.
Step 4: Back in the main interface, click Rip All to start the ripping process. A progress bar tracks the conversion status.
VideoByte BD-DVD Ripper Rating and User Feedback
💡 Rating: 4.4 / 5 (as of October 2026)
As of October 2026, VideoByte holds a 4.4 out of 5 overall rating on Trustpilot based on 322 reviews, up from 288 reviews when we last checked in June 2026. Recent feedback is mostly positive about disc ripping and support with license transfers or registration problems, although a smaller group of users still report missing activation codes or purchase-support issues.
User Feedback on VideoByte BD-DVD Ripper
Looking across Trustpilot reviews, recent positive feedback tends to focus on reliable ripping performance for standard DVD and Blu-ray titles once the software is installed and activated. Some users also note improved support response times compared to earlier periods.
VideoByte BD-DVD Ripper user feedback screenshot
Recent negative feedback is more mixed than before. A smaller group of reviewers still report missing activation codes, purchase-related support problems, or software that did not work as expected. Recent positive reviews also include users who received help resetting or transferring registration codes after changing computers.
VideoByte BD-DVD Ripper negative customer reviews
Some users have also flagged the subscription auto-renewal: the annual plan renews automatically, with an email notification sent one week before the next charge. You can cancel through the payment platform before the renewal date to avoid being billed again.
DVDFab: An Alternative to VideoByte BD-DVD Ripper
DVDFab DVD Ripper and DVDFab Blu-ray Ripper are two alternatives worth evaluating if you need a broader format library, faster conversion, or a larger device preset collection. Both run on Windows and macOS and can remove a wide range of copy protections including APS, CSS, and Sony DADC. For a standard encrypted DVD, ripping typically takes between 5 and 10 minutes depending on disc length and hardware.
Both tools support output up to 8K resolution with near-lossless copy profiles and can also convert ISO files and disc folders to standard file formats. Below is a summary of their key capabilities.
Highlights
  • Batch ripping queue processes multiple DVDs or Blu-ray discs automatically one after another.
  • Cloud-assisted decryption handles many protected discs; effectiveness varies by disc, region, and version. Use only with discs you own and follow local laws.
  • 1:1 or near-lossless copy profiles preserve original video and audio when the source and settings allow.
  • Outputs to over 1,000 formats including MP4, MKV, MOV, MP3, AAC, and M4A, with hundreds of device presets for broad compatibility.
  • Optional compression reduces file size; visual quality depends on the bitrate and profile selected.
  • Supports high-bitrate video, multichannel audio (e.g., AC-3 5.1), and output up to 4K; upscaling cannot add detail beyond the source.
  • Advanced controls for codec, bitrate, frame rate, resolution, and sample rate to balance quality against file size.
  • Built-in editor for basic tasks: trim, crop, merge, watermark, and brightness/contrast adjustments.
Step 1: Download DVDFab DVD Ripper. Once you have launched DVDFab 13, select the Ripper module and place the DVD disc into your system's optical drive.
How to rip DVDs using DVDFab DVD Ripper Step 1
Step 2: To use an ISO file or DVD folder as a source, click the Add option or drag and drop the file directly into the main interface.
Step 3: Go to Choose Other Profile and select your desired output format. You can also adjust audio track, resolution, subtitles, and other parameters to customize the output.
How to rip DVDs using DVDFab DVD Ripper Step 3
Step 4: Use the built-in editor if needed, then go to Folder, choose the output directory, and click Start to begin ripping.
How to rip DVDs using DVDFab DVD Ripper Step 4
VideoByte BD-DVD Ripper vs DVDFab: Which Should You Choose?
User Ratings: VideoByte and DVDFab on Trustpilot
💡We collected ratings from Trustpilot. The following statistics are based on publicly available review data.
As of October 2026, VideoByte has a 4.4 out of 5 Trustpilot rating from 322 reviews, with 72% of reviewers giving it five stars. DVDFab's dvdfab.cn profile has a 4.5 out of 5 rating from 712 reviews, with 80% five-star reviews. Both profiles remain positively rated overall, while VideoByte's recent reviews include both strong support experiences and a smaller number of activation or purchase complaints.
Head-to-Head Test: VideoByte BD-DVD Ripper vs DVDFab Blu-ray Ripper
Author
I tested VideoByte and DVDFab using the same Blu-ray title and aligned output settings (H.265/AAC, target video bitrate 3,000 kbps). Below are the observed results on my Windows 10 test rig.
SoftwareOutput FormatAudio & Video CodecBit RateOutput SizeConversion Time
DVDFab Blu-ray RipperMP4H265/AAC3000kbps3.74GB13m49s
VideoByte BD-DVD RipperMP4H265/AAC3000kbps4.58GB46m12s
Test Rig
Operating System: Windows 10 X64
System Memory: 16GB
Graphics Card: NVIDIA GeForce RTX 4060 Ti 8GB
Processor: Intel® Core™ i7-6700 CPU @ 3.40GHz
Source Video File Size (Main Movie): 33.43GB
Under these aligned settings on my hardware, DVDFab Blu-ray Ripper completed the task in 13 minutes and 49 seconds, while VideoByte required 46 minutes and 12 seconds. DVDFab also produced a smaller output file at the same target bitrate.
These numbers reflect one test on one hardware configuration. Conversion speed and file size vary based on CPU, GPU, hardware acceleration settings, and the specific source title. Both tools produce watchable output at the chosen bitrate; the practical question is whether the speed gap matters for the volume and frequency of discs you plan to rip.
⚡Faster Conversion Speed: Under these aligned settings, DVDFab completed the task in just 13 minutes and 49 seconds, significantly faster than VideoByte.
📂Smaller Output Size: With the same output parameters (MP4, H265/AAC, 3000kbps), DVDFab generated 3.74GB, while VideoByte's output was 4.58GB. The difference reflects how each tool's encoder handles the same target bitrate.
To compare both tools across additional dimensions, the table below covers their main features and technical specifications.
FeatureVideoByte BD-DVD RipperDVDFab DVD/Blu-ray Ripper
PlatformWindows, macOSWindows, macOS
DecryptionYesYes
Batch RippingYesYes
Format Support300+1,000+
Maximum ResolutionUp to 4K (upscaling)Up to 8K
Editing ToolsYesYes
Parameter CustomizationYesYes
Both tools share foundational capabilities including decryption, batch ripping, built-in editing, and output parameter control. The measurable differences are in format library size (300+ vs 1,000+), maximum resolution ceiling, and the conversion speed gap shown in the benchmark. For standard DVD or 1080p Blu-ray ripping to MP4 or MKV, both can handle the task. The format library and speed gap become relevant if you work with varied output requirements or a high disc volume.
Is it safe to use the VideoByte BD-DVD Ripper crack version?
No. A cracked installer may contain modified or malicious files, and using it also violates the software's license terms. Use the official trial if you want to evaluate VideoByte before purchasing.
Is VideoByte BD-DVD Ripper free?
No. VideoByte BD-DVD Ripper offers a limited trial rather than a fully free version. The trial converts up to 5 minutes from each DVD or Blu-ray; on Windows, DVD-to-folder and DVD-to-ISO output are limited to five discs within 30 days.
How much does VideoByte BD-DVD Ripper cost?
VideoByte BD-DVD Ripper currently costs $69.95 for a 1-year Windows subscription or $84.95 for a lifetime Windows license. The annual plan renews automatically and lists a 5-day money-back period, while the lifetime license is a one-time purchase with a 30-day money-back period. Prices may change during promotions.
Does VideoByte BD-DVD Ripper support 4K UHD Blu-ray discs?
Not directly. VideoByte can upscale output from standard DVD or 1080p Blu-ray sources, but it does not rip commercial 4K UHD Blu-ray discs. UHD discs require hardware and software designed specifically for UHD media.
Is VideoByte BD-DVD Ripper compatible with macOS 15 Sequoia?
Yes. VideoByte currently supports macOS 10.12 or later and both Intel and Apple Silicon processors, so macOS 15 Sequoia falls within its current system requirements. If an older build fails to launch after a macOS update, install the latest available version before testing again.
Where can I find my VideoByte BD-DVD Ripper registration code?
VideoByte sends the registration code to the email address used for the purchase. If it does not arrive, check the spam folder first; if the code is lost, use VideoByte's license retrieval service. Make sure the registration code matches the Windows or Mac version you purchased.
After testing both tools and reviewing current user feedback, the choice between VideoByte BD-DVD Ripper and DVDFab Blu-ray Ripper comes down to what you prioritize in a ripping workflow.
Choose VideoByte if you primarily work with standard DVDs and 1080p Blu-rays, value a simple setup process on macOS (no third-party library required), and do not need a large device preset library. It covers the core use cases for most home disc collections at a competitive price point.
Choose DVDFab if conversion speed matters for the volume of discs you rip, you need a broader output format library (1,000+ vs 300+), or you want a tool with a stronger Trustpilot track record. The benchmark gap is meaningful if you are working through a large collection.
Before purchasing either tool, use the trial with your own optical drive and a representative disc to confirm that the ripping speed, output, and activation process meet your needs.
