Convert VOB to MP4 with Top 4 VOB to MP4 Converters [2025 Updated]
Summary: Do you still have trouble searching for an appropriate VOB to MP4 converter? Or maybe you are worried about the complicated instructions of professional software? No worries. This passage will provide a detailed list of outstanding VOB to MP4 converters.
It is widely acknowledged that DVD is vulnerable to be damaged and large piles of DVD pose a challenge for storage room. To preserve your movies and free up shelf space, convert VOB to MP4—the most widely compatible format for Windows, Mac, iOS, and Android. This guide shares practical VOB to MP4 tips on quality, subtitles, and deinterlacing, and points you to the best VOB to MP4 converter options (from free tools like VLC to editor-first solutions like DVDFab) so you can store, stream, and edit your videos with ease.
VOB to MP4: Quality, Subtitles & Deinterlacing Tips
DVDs aren’t just "another video file"—they're discs that store video as VOB container files inside the VIDEO_TS folder (typically MPEG-2 video with multiple audio/subtitle tracks and sometimes menu data). They’re standard-definition, often interlaced, and frequently letterboxed, with legacy protections to boot. To turn VOB into a modern, great-looking MP4, focus on four things: deinterlacing, correct aspect ratio/cropping, subtitle strategy, and handling protected discs. The quick tips below show what to toggle in free tools like VLC and where DVDFab’s editor makes the process faster and cleaner.
📌Deinterlace old footage to remove combing
- DVDFab: apply Deinterlace in the built-in editor and preview before export; pair with light Sharpen if needed.
- VLC: when converting, open Profile → (wrench) → Video codec → Filters and enable Deinterlace (or Decomb).
📌Fix aspect ratio & black bars
- When to crop: If the DVD has hard letterboxing (black bars baked in), use Crop to remove them for true 16:9 playback.
- When to keep: If bars are part of the original framing or you need broadcast-safe borders, keep them.
- DVDFab: use Crop/AR controls with a frame preview to avoid cutting active picture.
📌Choose your subtitle workflow (burn-in vs. switchable)
- Burn-in: Always visible; best for platforms that ignore soft subs (some TVs/social).
- Switchable: Keep as a separate track for on/off control.
- DVDFab: supports importing SRT/ASS, burn-in, soft subs, and even SRT extraction from the disc when available.
- VLC: can burn in a chosen subtitle during conversion; styling controls are limited.
Top 2 Third-party Software to Convert VOB to MP4
DVDFab DVD Ripper
DVDFab DVD Ripper, as one of the most advanced VOB files to MP4 converters, had owned more than 80 million users around the world, and has been downloaded over 100 million times. It is able to convert any DVD to mp4 and the other video& audio format in 5 minutes. What’s more, it also could convert VOB to MP4 Mac and convert VOB to MP4 Windows 10.
Features of DVDFab DVD Ripper
- Handles new/complex discs with cloud-assisted decryption (use legally per your region).
- Built-in video editor: crop/trim/merge, add watermarks & subtitles, color tuning—finish your cut before exporting.
- 1,000+ formats & 260+ device profiles, from MP4/MKV to audio extractions—ready for phones, TVs, and consoles.
- Batch queue + GPU acceleration for efficient, large-volume conversions.
- Optional AI upscaling to 1080p when you need a cleaner, higher-resolution file.
How to Convert VOB to MP4
Step 1: Get DVDFab DVD Ripper free download on Windows or Mac.
Step 2: Open DVDFab DVD Ripper software and import the DVD source.
Launch DVDFab DVD Ripper and select the "Ripper" module. Insert your DVD into your computer's drive, and the software will automatically load the content, decrypting any embedded copy protection. If you have an ISO file or a folder, drag and drop the file into the application.
Step 3: Customize the DVD video output.
Then on the main interface, you can choose some titles or rip the whole DVD, select audio tracks and languages, extract DVD subtitles to SRT format, and add external subtitles. If you are curious about what kind of copy protection is embedded in your DVD, just click the option "Info" and find out.
Although you set the default profile in the previous step, you can also click the button "Choose Other Profile" - "Format" to select another MP4 profile as the output video format. You can also click "Device" to convert DVD to iPhone, Android, and other portable devices directly.
Click "Advanced Settings" to customize video, audio and subtitle parameters to meet your specific demands.
Then edit your DVD video by clicking the "Video Edit" or "Trim" button.
Step 4: Set the output destination and start to convert DVD to MP4.
At the bottom of the interface, click the "Folder" icon to save your output video: Mobile Device or Folder. Make a decision and then click the button "Start". DVDFab DVD Ripper will finish the conversion in just 3 to 5 minutes.
VLC Media Player
VLC Media Player is a free and open-source multimedia player developed by the VideoLAN project. Known for its lightweight design and robust codec support, VLC can play, stream, and convert almost any video or audio format, including DVDs and VOB files.
Though VLC is primarily a media player, it also includes a basic built-in video converter, making it a handy tool for users who need to convert formats like .vob to .mp4 without installing additional software.
- Supports almost all video/audio formats, including VOB, MP4, MKV, AVI, MOV, MP3, and FLAC.
- Works on Windows, macOS, Linux, and even mobile platforms.
- Completely free to use with no ads, watermarks, or trial limits.
- Lacks advanced output controls like bitrate limits, presets, or filters.
- If your movie is split across multiple VOB files, VLC won't join them automatically.
- No previewing or fine-tuning of output size/quality.
How to convert VOB to MP4 by VLC Media Player
Step 1: Open VLC and launch the software; Add the VOB file; Browse and select your .vob file from the VIDEO_TS folder of your DVD (e.g., VTS_01_1.VOB) and then click "Convert/Save".
Step 2: Choose conversion settings; choose where to save the output file and give it a name ending with .mp4.
💡Note: VLC can burn in a subtitle track during conversion; but it lacks advanced styling/timing controls compared with dedicated rippers.
Step 3: Start the conversion.
VLC's conversion behaves more like real-time recording and may be slow on lengthy discs.
The Best Two Tools to Convert VOB to MP4 Online
Restream VOB to MP4 Converter
Restream VOB to MP4 Converter Online is a free browser-based video conversion tool that allows users to convert VOB files (commonly found on DVDs) into MP4 format, which is more universally supported across modern devices and platforms. Hosted on the Restream Tools platform, this utility is designed for simplicity, speed, and accessibility—no software installation required.
Features of Restream VOB to MP4 Converter
- Simple Drag-and-Drop Interface: Upload your .vob files directly via the website—no account needed. Just drag and drop or click to browse your file.
- Fast Cloud-Based Conversion: The entire process is handled online using cloud infrastructure, reducing strain on your local machine and speeding up processing time.
- MP4 Output Format: Converts .vob files to .mp4, ensuring maximum compatibility with platforms like YouTube, Windows, macOS, iOS, Android, and media players.
- No Software Installation: Works entirely in your browser (Chrome, Firefox, Edge, etc.)—ideal for quick conversions on the go or using shared/public computers.
- Free to Use: As of now, the tool is free without hidden paywalls, which makes it accessible for everyday users and hobbyists.
How to Convert VOB to MP4 Online with Restream VOB to MP4 Converter
- Step 1: Open the tool via its official page (or search "Restream VOB to MP4").
- Step 2: Upload your VOB file by dragging it into the interface or clicking to browse.
- Step 3: Wait for the file to upload and convert (progress bar will be visible).
- Step 4: Download the MP4 file once the conversion is complete.
CloudConvert
CloudConvert is a powerful online file converter that supports nearly all kinds of audio, video, document, e-book, archive, image, spreadsheet, and presentation formats.
Features of Cloud Converter
- Ensure data security: CloudConvert is dedicated to protecting the privacy of users and promises that no one has the right to read or get your file. Since its founding in 2012, CloudConvert has gained the trust of users and customers.
- High-quality conversion with 200+popular formats: CloudConvert is a powerful yet convenient conversion tool that supports more than 200 formats without any quality loss.
- A simple interface makes your conversion easier: If you are not familiar with the conversion instruction or don’t know how to convert VOB to MP4, there is no need to worry. Because CloudConvert will automatically set the most appropriate parameters.
FAQs on VOB to MP4 Conversion
VOB is a video format from a DVD disc, typically stored in the VIDEO_TS folder. It contains most of the data which is stored in the disc, such as video, audio and subtitles. The VOB format is based on the MPEG stream format and is usually formatted as a MPEG-2 stream and can be opened by various video playback programs.
Compared with all the competitive products, DVDFab DVD Converter is the best DVD converter. Its excellent system, considerate design as well as powerful functions have gained the trust of a growing number of customers and users.
Can HandBrake Convert VOB to MP4?
Yes, HandBrake can convert VOB to MP4. By simply loading the VOB file into HandBrake, selecting MP4 as the output format, and customizing the settings if necessary, you can easily convert your video to the desired format.
This passage introduces two powerful software specialized in conversion between different formats, and two online converters featured by convenience and speed. Among these products, DVDFab DVD Ripper is regarded as the top priority, which is able to solve all the conversion-related problems. Besides, cooperating with other key products including Video Enhancer AI and UHD Copy, a cinema-like viewing experience is at the touch of your finger.
