2026 Tested VOB to MP4 Converters for Windows, Mac, and Online
Summary: Converting VOB to MP4 works best when the source is identified first. HandBrake is the strongest free local choice for ordinary VOB files and readable folders, VLC works for one quick file, and online converters suit only small, non-sensitive uploads. Full VIDEO_TS folders or DVD sources need title, audio, subtitle, and segment checks before encoding, while DVDFab DVD Ripper is useful when the disc structure must be read before output.
VOB to MP4 conversion looks simple until the source is a DVD folder instead of one file. I started with a standalone .vob, a numbered VIDEO_TS set, and a disc folder, then checked what each method actually opened. The main issue was not the MP4 format itself, but whether the converter read the complete title, audio track, and subtitles.
For this update, I kept the page focused on the common VOB to MP4 jobs shown in search results: HandBrake for a free local encode, VLC for one file, online tools for small uploads, FFmpeg for command control, and DVDFab DVD Ripper for disc, ISO, or VIDEO_TS sources.
Choose the Right VOB to MP4 Method
The source decides which method to use. Open one ordinary VOB in a file converter, open the complete folder when several segments form one title, and use a dedicated DVD to MP4 converter when title selection or disc structure matters.
Match the Method to Your Source
A standalone VOB can be opened directly in VLC, HandBrake, FFmpeg, or a small-file browser converter. If the movie is split into VTS_01_1.VOB, VTS_01_2.VOB, and later segments, selecting one file may create a short or incomplete MP4.
| Source | What to open | Recommended method | Main caution |
| One ordinary VOB file | The individual .vob file | VLC, HandBrake, FFmpeg, or an online converter | Check the selected audio and subtitle tracks |
| Several ordered VOB files | The full VIDEO_TS folder or an explicitly ordered file list | DVDFab DVD Ripper, HandBrake, or FFmpeg | Do not assume the largest segment is the complete movie |
| Complete DVD, ISO, or VIDEO_TS folder | The disc source, ISO, or full folder | DVDFab DVD Ripper | Choose the main title and tracks before output |
| Small, non-sensitive standalone VOB | The individual file | Restream or CloudConvert | Upload time, privacy, and output controls are limited by the service |
Settings That Preserve DVD Quality
Good VOB quality settings preserve the original frame shape, remove visible combing when needed, and retain the audio or subtitles you actually use. Upscaling cannot recreate detail that was not present on the DVD.
| Setting | What to check | Recommended action |
| Deinterlacing | Horizontal combing on motion | Use decomb or deinterlace only when the source is interlaced |
| Aspect ratio and crop | Stretched faces or black bars baked into the frame | Keep the source aspect ratio; crop only bars that are part of the encoded image |
| Audio | Language, commentary, and channel layout | Select the intended track before conversion and test the output |
| Subtitles | Forced, selectable, or burned-in text | Choose a selectable track when the player supports it; burn in only when visibility must be fixed |
| Frame rate | Jerky motion or audio drift | Keep a frame-rate mode that matches the source unless a target device requires a change |
Top VOB to MP4 Converters on Windows and Mac
Desktop software is the better choice for a large VOB file, private footage, repeated conversions, or a complete VIDEO_TS to MP4 job. The five-method comparison below separates simple file conversion from full-folder and disc processing.
| Item | DVDFab DVD Ripper | HandBrake | VLC Media Player | FFmpeg | Online converters |
| OS | Windows, macOS | Windows, macOS, Linux | Windows, macOS, Linux | Windows, macOS, Linux | Modern browsers |
| Best Source | Disc, ISO, VIDEO_TS | Ordinary VOB, readable VIDEO_TS | One ordinary VOB | Files or ordered inputs | Small standalone VOB |
| Single VOB | Yes | Yes | Yes | Yes | Yes |
| VIDEO_TS / Segments | Reads full title list | Scans readable folders | Does not rebuild segments | Supports explicit ordering | Usually not for VIDEO_TS |
| Complex Disc | Support complex disc structures | Limited disc-access scope | Limited for complex discs | Depends on source readability | Not for disc structure |
| Audio / Subtitles | Title, audio, subtitle selection | Track and subtitle review | Basic choices | Explicit stream mapping | Usually limited |
| Quality Controls | Editor, crop, trim, watermark, deinterlace, output settings | Presets, crop, decomb, frame rate, codec settings | Profile settings, deinterlace filters | Filters, codecs, frame rate, quality settings | Service-dependent presets |
| Best For | Full-disc sources, multiple tracks, queued tasks | Free local conversion with a graphical interface | Quick setup for one file | Command-line control and Linux conversion | One small, non-sensitive file |
DVDFab DVD Ripper
DVDFab DVD Ripper is a feature-rich desktop software that can convert VOB files to MP4 on both Windows and Mac. It can handle any copy-protected DVD disc, ISO, or VIDEO_TS folder and rip them to MP4, MKV, AVI, and other formats.
Before conversion, you can choose the main title, keep the audio tracks and subtitles you need, select an MP4 profile, and make basic edits such as trimming or cropping. Multiple VOB conversion jobs can also be added to the task queue, while GPU hardware acceleration can speed up processing. If your source contains several numbered VOB files, multiple titles, audio tracks, or subtitles, this tool is a good option.
Supported OS:
- Handles new discs with cloud-assisted decryption technology.
- Offers 1,000+ formats and 260+ device profiles for phones, TVs, and consoles.
- Built-in video editor: crop, trim, merge videos, add watermarks & subtitles, color tuning, etc.
- Batch processing with GPU acceleration:
- Handle large-volume conversions with fast speeds.
- No Linux version.
How to Convert VOB to MP4 with DVDFab DVD Ripper:
Step 1: Load the DVD VOB sourc. Open DVDFab, select the Ripper module, and load the DVD disc, ISO image, or VIDEO_TS folder containing the VOB files.
Step 2: Choose MP4 as the output. Click Choose Other Profile, open Format > Video, and select an MP4 profile that matches your playback needs.
Step 3: Customize the video. Choose the title, audio tracks, and subtitles to keep. Use Advanced Settings, Trim, or Video Edit to adjust the codec, resolution, quality, crop, or other settings.
Step 4: Start the conversion. Select an output folder and click Start to convert the DVD VOB content into an MP4 file.
HandBrake
HandBrake can convert VOB to MP4 as a free desktop transcoder for Windows, macOS, and Linux. It can open an ordinary VOB file or scan a readable VIDEO_TS folder, then export MP4, MKV, or WebM with title, audio, subtitle, crop, and decomb controls.
HandBrake is a good local choice when the source is already readable and you want a free graphical app. The main limit is source access: HandBrake does not handle copy protection, and it does not combine unrelated clips into one title.
- Free and open source on Windows, macOS, and Linux.
- Exports MP4 and provides presets, crop, decomb, audio, and subtitle controls.
- Can scan a readable VIDEO_TS folder and show available titles.
- Does not remove copy protection.
- A damaged or unusual folder may not scan as the expected title.
- Not meant to join unrelated VOB clips into one new edit.
How to Convert VOB to MP4 with HandBrake:
- Step 1: Launch HandBrake and open your VOB file.
- Step 2: Choose the title whose duration matches the program you want.
- Step 3: Select an MP4 preset, then review Dimensions and Filters for crop or decomb.
- Step 4: Open the Audio and Subtitles tabs and keep the tracks needed in the final file.
- Step 5: Choose the destination, start the encode, and inspect the complete output.
VLC Media Player
VLC Media Player is primarily a media player, but its Convert/Save feature can export a single VOB file as MP4. If VLC is already installed on your computer, this can be a convenient option. However, VLC does not automatically combine several ordered VOB segments into one complete DVD movie, and its track-selection controls are more limited than HandBrake or DVDFab.
- Opens ordinary VOB files and outputs MP4 through the Convert/Save panel.
- Available for Windows, macOS, and Linux desktop systems.
- Free and open source, with no conversion watermark.
- Output controls are less detailed than those in a dedicated transcoder.
- Several ordered VOB files are not joined into one complete title automatically.
- Complex audio, subtitle, and DVD title layouts require another method.
How to Convert VOB to MP4 with VLC:
- Step 1: Open VLC and choose Media, then Convert/Save.
- Step 2: Add the .vob file from the VIDEO_TS folder and select Convert/Save.
- Step 3: Choose an MP4-compatible profile, select the destination, and give the file an .MP4 extension.
- Step 4: Open the profile settings if deinterlacing or a specific audio choice is needed.
- Step 5: Start the conversion and check the finished duration and tracks.
FFmpeg
FFmpeg is a free command-line tool for converting VOB files to MP4 on Linux, Windows, and macOS. It can process a single VOB file directly, and also handle explicitly ordered inputs when you know which segments belong together.
It gives you control over file order, video settings, audio tracks, and stream mapping. However, an incorrect input order or a missing stream map can result in a shortened file, the wrong audio language, or missing subtitles, so it is better suited to users who are already comfortable with terminal commands.
- Free on Windows, macOS, and Linux.
- Works well for VOB to MP4 on Linux when a graphical app is not required.
- Gives direct control over input order, audio tracks, subtitles, and filters.
- Requires command-line use.
- Several VOB segments must be ordered correctly before conversion.
- Stream mapping mistakes can leave out the intended audio or subtitle track.
How to Convert VOB to MP4 with FFmpeg:
- Step 1: Inspect the source and identify the correct VOB order or complete readable input.
- Step 2: Probe the streams so the intended video, audio, and subtitle tracks are known.
- Step 3: Set an MP4-compatible video and audio output, adding deinterlacing only if the source shows combing.
- Step 4: Map the required streams explicitly and write the result to a new file.
- Step 5: Check duration, synchronization, and track availability before deleting temporary files.
For one ordinary VOB file, the basic command can be as simple as:
ffmpeg -i input.vob -c:v libx264 -c:a aac output.mp4
Online VOB to MP4 Converters for Small Files
If you need to process a large VOB file, a complete VIDEO_TS folder, private footage, or multiple files, use a local application because uploading takes extra time and requires transferring the source to an external server. However, if you have one small, non-sensitive VOB file and do not want to install software, an online VOB to MP4 converter may be convenient.
Restream VOB to MP4 Converter
Restream VOB to MP4 Converter is a free, browser-based tool that converts VOB files into MP4 without requiring software installation. It runs on the Restream Tools platform and is suitable for quick, occasional conversions on devices with a modern web browser.
Restream supports MP4 and WebM output and limits each upload to 2 GB. This makes it useful for a standalone VOB file, but less suitable for a complete VIDEO_TS folder, repeated conversions, or private footage that you would rather not upload to an external server.
- Runs in a browser and does not require local installation.
- Outputs MP4 for common playback needs.
- Suitable for one small, non-sensitive standalone VOB.
- Requires upload before conversion.
- Not intended for a full VIDEO_TS folder.
- Track and subtitle control is limited compared with local software.
How to Convert VOB to MP4 Online with Restream:
- Step 1: Open the Restream VOB converter in a modern browser.
- Step 2: Upload the standalone VOB file.
- Step 3: Wait for the upload and conversion to finish.
- Step 4: Download the MP4 and check its duration, picture, and sound.
CloudConvert VOB to MP4 Converter
CloudConvert has a VOB to MP4 browser converter for uploading one file and downloading an MP4. It is most relevant when you do not want to install software and the source is a standalone VOB rather than a disc folder.
Its converter page lists video options such as resolution, quality, and file size. The limits are the same as other upload-based tools: file sensitivity, upload time, service limits, and less control over DVD titles, audio streams, and subtitles.
- Converts an uploaded VOB file to MP4 in a browser.
- Offers online settings for resolution, quality, and file size.
- Useful for an occasional small file when local software is not needed.
- Requires uploading the source file.
- Not intended to read a complete VIDEO_TS folder as a DVD title.
- Audio and subtitle control is limited compared with desktop tools.
How to Convert VOB to MP4 Online with CloudConvert:
- Step 1: Open CloudConvert's VOB to MP4 converter.
- Step 3: Keep MP4 as the output format and adjust available settings only when needed.
- Step 4: Start the conversion, download the MP4, and check the duration and audio.
Troubleshoot Common VOB Conversion Problems
Most failed VOB conversions come from the wrong title, incomplete segment selection, missing stream mapping, or unsuitable interlacing settings. Check the source and tracks before increasing bitrate or changing codecs.
Fix Truncated or Misordered Output
Symptom: The MP4 is shorter than the movie, jumps between scenes, or starts in the middle.
Likely cause: One numbered VOB was selected, the wrong title was chosen, or segments were combined out of order.
- Open the complete VIDEO_TS folder and compare title durations.
- If using FFmpeg, confirm the file order before joining inputs.
- Check whether a dedicated DVD ripping tool identifies a complete main title.
Restore Missing Audio or Subtitles
Symptom: The MP4 has no sound, the wrong language, or no subtitles.
Likely cause: The converter selected a different stream, or the MP4 profile did not carry the intended subtitle type.
- Inspect all source audio and subtitle tracks before starting.
- Select the required language explicitly instead of accepting the first track.
- Choose between a selectable subtitle track and burned-in text based on the target player.
- With FFmpeg, map each required stream rather than relying on automatic defaults.
Reduce Combing, Blur, and Sync Errors
Symptom: Motion shows comb-like lines, the picture looks soft, or audio drifts.
Likely cause: Interlaced DVD video was encoded without a suitable filter, the frame-rate mode changed, or the wrong source segments were combined.
- Enable decomb or deinterlace only after confirming visible combing.
- Keep the original aspect ratio and avoid unnecessary resizing.
- Test a short section with motion before processing the complete title.
- If synchronization still fails, return to the complete source and recheck title and segment order.
What programs can open a VOB file without converting it?
VLC and several desktop media players can open a standalone VOB directly. For a movie split across several files, open the VIDEO_TS folder as a disc source when the player supports it; that gives a better chance of correct order, audio, subtitles, and navigation.
Can HandBrake convert VOB files from a copy-protected DVD?
HandBrake can transcode ordinary VOB files and VIDEO_TS folders it can read, but it does not provide the same access to difficult commercial-disc structures as a dedicated DVD reader. Use only content you own or are authorized to process, subject to local law.
Is MP4 better than VOB for editing and everyday playback?
MP4 is usually easier to play, share, stream, and edit across current devices. VOB remains useful when you need the original DVD folder structure or want to preserve the source before deciding how to encode it.
Can I convert VOB to MP4 on Linux?
Yes. HandBrake provides a graphical free VOB converter, while FFmpeg offers command-line control over file order and stream mapping. In either case, check audio and subtitle tracks before processing the complete source.
VOB to MP4 conversion works best when the source is identified before any settings are changed. Use VLC for one ordinary VOB, HandBrake for a free local conversion of readable files or folders, FFmpeg when exact input order and stream mapping are needed, and an online converter only for a small file that is safe to upload. DVDFab DVD Ripper is more relevant when the source is a disc, ISO, or VIDEO_TS folder that needs title, audio, and subtitle selection before MP4 output.
