YouTube to DVD Converter: 4 Ways to Burn a Playable Disc [2026]
Summary: Burning YouTube videos to DVD usually involves two main steps: saving the video as a local file and using DVD creator software to turn it into a playable DVD. A professional tool such as DVDFab DVD Creator is a better fit when you need DVD menus, ISO output, subtitles, and disc burning options, while DVDStyler and DVD Flick are free choices for users who only want basic DVD authoring.
YouTube is convenient for online viewing, but a DVD can still be useful when you want to play a video on a TV, share a disc with family, or keep an offline copy of a personal project. If you have a local YouTube video, burning it to DVD can make it easier to watch without relying on an internet connection or a streaming app.
To burn a YouTube video to DVD on Windows or Mac, first save a video you own or are authorized to use as a local file, then author that file as DVD-Video with desktop software. The methods below compare DVDFab DVD Creator, DVDStyler, DVD Flick, Freemake Video Converter, and an online converter, with the main differences being menu control, output type, operating-system support, and cost.
Before You Start: Save the YouTube Video Locally
A playable DVD-Video starts with a video file you are permitted to use, suitable blank media, and DVD authoring settings that match the player. A data DVD containing an MP4 may open on a computer but fail in a standard DVD player.
- Permission and source file: Save a YouTube video you own or are authorized to use as MP4 or another format accepted by your DVD authoring software.
- DVD writer and media: Use a working DVD burner with matching DVD-R or DVD+R media. Rewritable discs are useful for a first test when the player supports them.
- Working space: Leave room for the source file, temporary encoding files, and the finished ISO or VIDEO_TS folder.
- DVD-5 versus DVD-9: DVD-5 suits shorter projects or lower bitrates, while DVD-9 gives longer projects more room and can reduce the need for heavier compression.
- Preview before burning: Create an ISO first when the software allows it, check the menu, title order, audio, and subtitles, then burn one test disc.
How to Burn YouTube Videos to DVD on Windows and Mac
Desktop DVD authoring software turns a local YouTube video into a DVD structure, adds navigation, and writes a disc or image. The tools below differ most in operating-system support, menu control, setup effort, and whether they can produce a playable DVD-Video disc.
| Tool | Operating Systems | Input | DVD Output | Cost / Status |
| DVDFab DVD Creator | Windows; macOS | Local video files | Menus, DVD disc, folder, ISO | 30-day trial; DVDFab v13.0.6.5 was released on Jul 30 2026 |
| DVDStyler | Windows; macOS; Linux | Local video files | Menus and DVD authoring | Free; v3.2.1 stable, v3.3b3 beta |
| Freemake Video Converter | Windows | Local video files; separate downloader available | Basic menus and DVD output | Free output includes Freemake branding unless removed with a paid pack |
| Zamzar | Web browser | Small local files | No menu or DVD burning | 50 MB free file limit |
DVDFab combines menu templates, subtitle and audio selection, editing, and ISO or folder output in the same desktop application. DVDStyler covers the core DVD authoring task for free but requires more manual setup. Freemake can create simpler DVD projects, although its free output includes Freemake branding. Zamzar only converts files and cannot create the DVD-Video structure needed by a standard DVD player.
Method 1: Burn YouTube Videos to DVD with DVDFab DVD Creator
DVDFab DVD Creator turns local YouTube video files into standard DVD-Video and can write the result to a blank disc or save it as an ISO image or DVD folder. After saving a YouTube video you are authorized to use, you can import the file, choose a DVD menu template, select audio or subtitle options, and adjust the project before burning.
Compared with the free tools below, DVDFab places menu templates, multiple video titles, subtitle options, basic video editing, and ISO or folder output in the same application. This is useful when you want to preview a more complete DVD project before committing it to a blank disc.
Available on:
Key features:
- Create standard DVD-Video from 200+ supported local video formats.
- Save the finished project to DVD-5/DVD-9 media, an ISO image, or a DVD folder.
- Use GPU acceleration on supported hardware to reduce DVD encoding time.
- Crop or trim video, adjust brightness, contrast, and saturation, and add watermarks or external subtitles.
- Select and customize DVD menu templates, including backgrounds, thumbnails, text, and playback buttons.
How to burn YouTube videos to a DVD with DVDFab DVD Creator:
Step 1: Launch DVDFab DVD Creator, and load the source YouTube videos.
Launch DVDFab on Windows or Mac and select the "Creator" module and "DVD Creator" mode. Load the local YouTube video with the "Add" button or by dragging and dropping the file onto the main page.
Step 2: Customize the output DVD via "Advanced Settings", "Video Edit" and "Trim".
After loading your video, the interface displays the input and output information. Select the audio tracks and subtitles you want to include. If you load multiple videos, you can also arrange their playback order.
Click "Advanced Settings" to enter the DVD name and choose DVD-5 or DVD-9 according to the project size.
Step 3: Create DVD menu with "Menu Settings".
Click "Menu Settings" to select a menu template. You can change the text font, size, and color, replace thumbnails or backgrounds, and adjust the playback buttons and other visible menu elements.
Open "Video Edit" if you need to crop or rotate the frame, adjust saturation, brightness, or contrast, or add a watermark. Use the "Trim" module to remove unwanted sections before authoring the DVD.
Step 4: Set the output destination, and start to burn YouTube video to DVD.
Select a blank DVD disc as the destination, or save the project as a DVD folder or ISO file. Click "Start" in the lower-right corner to begin authoring the DVD.
Method 2: Burn YouTube Videos to DVD with DVDStyler
DVDStyler is a free choice if you already have a local YouTube video and want to create a playable DVD without buying DVD authoring software. This open-source program accepts common formats such as MP4, AVI, MOV, MPEG, and WMV, and provides built-in menu templates as well as controls for custom text, buttons, backgrounds, and navigation.
The current stable release is DVDStyler 3.2.1, while the project also offers a 3.3b3 beta build for Windows. DVDStyler focuses on DVD authoring and menu design rather than providing the broader editing tools found in a dedicated video editor.
Available on: Windows, macOS, and Linux
Key features:
- Author MP4, AVI, MOV, MPEG, WMV, and other supported video files as DVD-Video.
- Support both NTSC and PAL project settings.
- Select a built-in DVD menu template or create a custom menu layout.
- Add multiple subtitle and audio tracks to a DVD project.
How to convert YouTube videos to DVD using DVDStyler:
Step 1. Install DVDStyler from the official site. Save the YouTube video you are authorized to use to your local drive before starting the DVD project.
Step 2. Launch DVDStyler and select "Create a new project" in the welcome window. Set the disc label, video and audio bitrates, and choose DVD-5 or DVD-9.
Step 3. Select a menu template from the available presets. Use the "Add File..." button to import your local videos into DVDStyler.
Step 4. Open the DVD Options and Settings panel to adjust project settings such as menu behavior and video quality.
Step 5. Click the red "Burn" button to create the DVD project and write it to the selected destination.
Method 3: Burn YouTube Videos to DVD with DVD Flick
DVD Flick is a free and open-source DVD burner for Windows. It can combine multiple video files in one DVD project, add basic menus, include subtitles and extra audio tracks, and provide controls for target size, aspect ratio, and bitrate. Its interface and Windows support reflect an older generation of DVD authoring software, so it is mainly useful for simpler projects on compatible Windows systems.
Available on: Windows 2000 Professional, or any edition of Windows XP / Vista / 7
Key features:
- Convert multiple supported video types into a DVD project.
- Choose from pre-designed menu templates or create a basic custom menu.
How to Use DVD Flick for YouTube to DVD Conversion:
Step 1: Download and install DVD Flick on a compatible Windows computer. Open the program to start a new DVD project.
Step 2: Add your local YouTube video files by clicking the "Add title" button.
Step 3: Go to "Project settings" to define the target size, video format, and other project parameters.
Step 4: Select a basic menu style or turn the menu off from the Menu options tab.
Step 5: Click "Browse" to select the destination folder, then click "Create DVD" to begin encoding and authoring.
Method 4: Burn YouTube Videos to DVD with Freemake Video Converter
Freemake Video Converter is a Windows tool that supports 500+ input and output formats and can create simple DVD projects from local video files. Freemake also provides a separate video downloader, but you should only save a YouTube video when the service, the rights holder, or applicable law permits it. The free version of Freemake Video Converter adds Freemake branding to converted output unless you purchase the Remove Branding pack.
Key features:
- Add multiple videos and arrange their playback order.
- Support 500+ video, audio, and device formats.
- Provide a separate Freemake Video Downloader.
- Include basic video editing controls for supported projects.
How to burn YouTube videos to DVD with Freemake Video Converter:
Step 1: Save the authorized YouTube video locally, then launch Freemake Video Converter and click "+Video" to import the file into the project.
Step 2: Add extra audio tracks or subtitle files if required. Once the project is ready, click "to DVD" at the bottom of the screen.
Step 3: Use the pop-up settings window to enter the disc name, select a DVD menu, and choose the output path.
Step 4: Click “Burn” to begin writing the project to DVD.
What Online YouTube-to-DVD Converters Can Do
An online YouTube converter can change the format of a small local file, but it cannot author a playable DVD-Video, build a menu, create the full VIDEO_TS structure, or write a physical disc from the browser.
That makes an online tool a preprocessing step rather than a replacement for a DVD writer and desktop authoring software. Long videos are also a poor match for upload limits and browser transfers.
Zamzar Converts Files but Does Not Burn Discs
Zamzar accepts a local file and converts it to another file format. It does not create DVD navigation or burn a disc, so the converted file still needs to be imported into desktop DVD authoring software.
As of August 2026, Zamzar's free service accepts files up to 50 MB. Basic costs $12 per month with a 200 MB maximum file size, Pro costs $19 with a 400 MB limit, and Business costs $39 with a 2 GB limit. Free converted files are stored for a maximum of 24 hours.
- Upload the local file. Choose a short authorized video that fits the selected upload limit.
- Select the conversion format. Pick the needed intermediate file type and start the conversion.
- Download the result. Save the converted file before its retention window ends.
- Author the DVD on a computer. Import the result into DVDFab, DVDStyler, or another DVD creator, then create and test the disc.
Can I legally burn a YouTube video to DVD?
You may save and burn a video when you own it, have permission from YouTube and the applicable rights holder, or applicable law permits the use. YouTube's Terms generally restrict downloading or reproducing content unless the service authorizes it, permission has been granted, or the law allows it.
What source format should I use before DVD authoring?
Use a clean local video file that your DVD authoring software accepts. MP4 with H.264 video and AAC audio is a common input choice, but the authoring program will convert the source into DVD-Video format as needed when it builds the disc.
Is there a completely free YouTube-to-DVD creator?
DVDStyler is free and can author a permitted local video as DVD-Video with menus. It requires more manual project setup than the paid option covered above, but it does not require a paid license for the core DVD authoring task.
Can an online converter create a playable DVD?
No. A browser converter can change the file format, but you still need DVD authoring software to create the DVD-Video structure, menus, ISO or folder output, and a DVD writer if you want a physical disc.
Making a playable DVD from a YouTube video requires more than changing the file extension. First save a video you are authorized to use as a local file, then import it into DVD authoring software that can create the DVD-Video structure. An online converter can help with a small file-format change, but it does not replace DVD authoring software or a disc writer.
DVDFab DVD Creator provides menu templates, subtitle and audio selection, video editing, ISO or folder output, and physical disc burning in the same application. DVDStyler covers the core DVD authoring task for free if you are comfortable with more manual project settings. DVD Flick can still serve simple projects on older compatible Windows systems, while Freemake provides another Windows option but adds Freemake branding to free output.
![5 Top AVI to DVD Converters for Windows and Mac [2026]](https://images.dvdfab.cn/artifact/2026/10/19/HsCx2t8W3VyD6wHfogzkhte4XqgpBqdz/feature_cover.jpg)
