Quick comparison and a full guide to AVI vs MP4
Summary: There are a plethora of formats available for videos for the users. Some are apt for bigger screens as advertisements, whereas some are better for uploading videos to popular platforms such as YouTube. But which one is better in AVI vs MP4? Are you looking for quality or ease of use? Let us see which one you prefer in MP4 vs AVI.
Whenever we are talking about video formats, we know a lot of varieties that can work for us without even peeping into the technical aspect. Users are often confused about their use without proper knowledge about all the audio or video formats. However, the option of conversion is always open for most of the popular formats related to both videos and audio. Majorly, when rendering of video files is done by software available on your computers, it is easier to work with. But, if the video is generated using digital devices, it can create an issue.
Before getting into further details, we would like to tell you that AVI and MP4 formats are the most popular ones for videos. Be its compatibility with most devices, ease of use, or availability, AVI and MP4 can be seen almost everywhere. So, what do you think will win when comparing AVI vs MP4 or MP4 vs AVI? Let's see ahead in this article what you choose as your conversion buddy for your requirements.
What is AVI?
AVI is a popular video format developed by Microsoft in the year 1992. In this format, audio and videos are saved using multiple Codecs like XviD and DivX. Unlike other video formats such as MOV or MPEG, AVI uses less space without being compressed. It makes it a superb format to be used over time in a lossless condition, where multiple times opening or saving the file does not affect its quality. AVI format can be used as playback and does not need any codecs.
Pros |
Cons |
Uses |
High quality and audio fidelity. |
Non-compression leads to a larger size. |
Can put to use for playable DVDs. |
Lots of available codecs. |
Uses specific codecs for retrieving files. |
Can be used for running promos, Ads, short movies, etc. |
Does not need any particular software or hardware to run the file. |
Very large in size. |
Playable on major Microsoft as well as non-Microsoft systems. |
Excellent quality for master files. |
If compressed beyond a certain limit results in poor quality. |
Sharing of media can be done in lossless quality. |
Compression requires experimenting with codecs. |
Can be compressed to be apt for DV standard. |
Does not lends support to softsubs. |
What is MP4?
MP4 or MPEG-4 can be considered a common format for video files that assists the users in storing a plentiful of audio or video information but in a more compact size. It was first released in 2001 when Moving Pictures Experts Group introduced it. Inspired by the Quick time File format, mp4 was later developed by APPLE. The higher amount of compression allows the users to have a lot of space saved for any other files.
Pros |
Cons |
Uses |
Amazing compression capability. |
Sometimes the audio is not in sync with the video. |
Can be used on a variety of platforms. |
Supports metadata in the form of menus, user navigation options, 3D graphics. |
Creates issues with codecs. |
Used in Interaction features. |
Supported well by VLC. |
Requires more computing resources. |
Can be used on LINUX operating systems as well. |
Very versatile. |
Results in lossy format due to the smaller size and high compression. |
More portable and popular. |
AVI vs MP4- Which One is Better?
The following table will compare AVI formats vs mp4 so you can decide which one is better for your use.
Serial no. |
Basis |
AVI |
MP4 |
1 |
Developed by |
Microsoft |
MPEG |
2 |
Quality |
Offers excellent quality. |
Offers good quality. |
3 |
Introduced in |
1992, older than mp4 |
2001 so its younger than AVI |
4 |
Compression |
Uses less compression that offers lossless quality. |
Due to H.264 or MpEG-4 used as compression techniques, files do not result in lossless quality. |
5 |
File Size |
Larger file size. |
Smaller file size. |
6 |
Supported Codecs |
DivX and XviD codec |
H.264 or MPEG-4 AVC codec is supported along with MPEG-1, MPEG-2WMV, Real video, MVC, VP9, VP8, Theora. |
7 |
Device compatibility |
Provides support to lesser Apple devices including Gaming consoles, Microsoft devices |
Multiple devices are supported including Android, iPad, Mac, iPhone, PC, etc. |
8 |
Players support |
Supports players that are Windows-based. |
Supports a majority of media players. |
9 |
File Size |
Larger size. |
Smaller size. |
We would say AVI is better if you are looking for quality. However, if you are looking for a compact file, mp4 can be your option. Moreover, you can use MP4 for streaming on the internet and sharing purposes.
What is WMV?
WMV is a file format brought to the forefront by Microsoft to be used as a series of codecs for videos. WMV stands for Windows Media Video, built for use as a framework for Windows media. It is mostly used when selling video content is done online. Users can also use WMV through Blu-ray discs along with HD DVDs.
AVI vs WMV vs MP4
We have already seen a quick comparison table for MP4 vs AVI, so now it's time to compare them with WMV format. Based on AVI vs MP4 quality, let us see how WMV performs in comparison.
Be it AVI, MP4, or WMV, all of them are wrappers so that they can be worked out with codecs put inside them. However, MP4 works the best in all situations because of its common codec, H.264, which can be utilized almost everywhere.
The WMV format is better than AVI; however, the best one is MP4. Moreover, WMV does not respond well to MAC devices without using any extras.
Both AVI and MP4 can work with audio, but WMV contains only video files.
So, you can see WMV is a great file format. However, it may restrict you in particular situations, requiring you to work either with AVI or MP4 as per usability.
How to Convert AVI to MP4 and Vice Versa?
If you are not satisfied with AVI or MP4 format and wish to use it for multiple purposes, you can convert it to MP4 or AVI format. But you confused about which software to use for the purpose? Not anymore, as we got you covered with a fabulous video converter option.
DVDFab Video Converter
DVDFab video converter is loaded with features software that helps easily convert AVI to MP4 format and vice versa, along with the seamless conversion of more than 1000 audio and video formats. Even if you have a low-resolution input video, you can convert it to 4K without any loss in quality. Other than this, you can upscale any footage by 300%, providing sharpened details.
Features
- It provides easy conversion of videos from Avi to MP4 and vice versa, along with more than a thousand formats being available for modification for both audio and videos.
- Assists the users In cropping any unwanted portions and Trimming clips for merging them into one.
- Provides great adjustment for saturation brightness and contrast to enhance the video quality of any format, including mp4.
- The user interface is quite intuitive and simple, and it also provides multicore and a multi-threading facility.
- You can use its upscaling solution for AI-powered video to convert low-resolution 480p video to 1080 and take it up to 4K level.
Pros
- Intuitive user interface.
- Easy and simple to use.
- It comes with a 30 day of money-back guarantee.
- Available for both Windows and MAC devices.
Price: $29.99
Steps to convert AVI to MP4 Using DVDFab Video Converter
Following are the steps to be followed for the conversion:
Step 1: Launching the software and loading the AVI source
First, you need to click on the latest version of the DVDFab video converter and look for the converter module. It will be given in the options bar as soon as the software starts running on your PC. you need to proceed with dragging and dropping the AVI source file for loading in the main user interface. Alternatively, you can also add it by using the add buttons present on the screen.
Step 2: Choose any one profile and ho for customization of the output audio or video
Now you have to click on the Drop-down menu and proceed with using another profile from the same. As soon as you are done with this step, you will see the option of format and device given in the profile library. Here you need to select one device for design or your preference. If you have any higher requests regarding the resulting output video, you can always set the audio and video parameters by using the advanced settings. Moreover, you can also deeply customize the output video with the help of the video editor already built-in in the software.
As soon as you are done with customization, you need to move to the option of saving the video and then proceed with clicking on the folder icon. It will redirect you to the selection of the output directory. If you want, you can also share this video on YouTube directly by using the DVDFab video converter.
Step 3: Start the conversion from AVI to MP4.
Once you are done with step 2, you need to proceed with clicking the start button to start the faster conversion of video from AVI to MP4 format. As soon as you click the start button, this efficient software will immediately proceed with transforming the footage to your targeted MP4 profile.
Meanwhile, you will be able to check the detailed progress happening during the process. If you wish, you can cancel this task at any time; it will end the process there and then. Alternatively, you can also opt for automatic shutdown of your PC or hibernation and exit the program. If you do not wish to do any of these, you can sit back and relax and do nothing till the task gets completed.
Steps to convert MP4 to AVI
All the steps given above for conversion from AVI to MP4 will be used in the same way for converting MP4 to AVI. However, there will be a few exceptions:
- AVI will be the loading source.
- MP4 will be the output format of the file.
Can I use the AVI format for YouTube?
YouTube generally uses MP4 format, whereas AVI is too much to handle for the platform because of its high video quality.
Can I convert my video from AVI to MP4 format?
Using a DVDFab video converter, you can convert AVI to MP4 and vice versa effortlessly and quickly.
In .avi vs. mp4, which format wins and stands out?
Depending on your use, you can choose either .avi or .mp4 like, whether you wish the content to be high or low quality, etc.
As we have discussed above, both MP4 and AVI are popular formats that users can use as per their requirements. If we consider AVI vs MP4, greater quality can be achieved through AVI. However, if you wish to upload a video on YouTube, MP4 can be better than AVI. We have also seen that in a discussion of MP4 vs AVI, we compared them to WMV format.
Here we saw that WMV can be a better choice when considering videos that are smaller in size but still higher in quality. Moreover, as far as conversion of AVI to Mp4 and vice versa is concerned, we suggested the DVDFab video converter as a great choice for the task. So, now the option is yours to decide which format suits your needs well.
