How to Convert to MP4 Free & Easily 2024
Summary: Are you looking for a MOV to MP4 converter free to convert MOV to MP4 for smooth play on various mobile devices or for better share on social platforms? You are on the right page. This article revolves around how to convert MOV to MP4 via different .mov to mp4 converters.
Should I convert MOV to MP4? How do I convert MOV to MP4? MOV file format is a proprietary Video File format used by Apple to play videos on its built-in media player Quicktime. However, Mac laptops or computers are not used by a vast majority of computer users, making it a pain for users of other operating systems who get such files online or through friends. The main reason for converting MOV to MP4 is that MP4 has greater compatibility options and smaller file sizes, which will provide you with the greatest flexibility to use or view the file.
Luckily, there is a simple solution to solve this problem. Convert MOV to MP4 by making use of some easy to use tools that offer MOV to MP4 conversion. In this article, we will be looking at the fastest ways to convert MOV to MP4 using software that makes the task of converting MOV to MP4 a child’s play. We will be listing the best software to convert MOV to MP4 at first and then go down in the next best order.
Among all MOV to MP4 conversion programs on the market, there are the top 5 best MP4 to MOV converters that are worth your consideration. They are selected based on feature highlights, cost performance, and user experience. Check them right now. Let’s take a look at how to convert MOV to MP4 with the selected MOV to MP4 converters.
DVDFab Video Converter Pro [Best Recommended]
On top of the list, DVDFab Video Converter Pro ranks first due to its outstanding features and customized options. It is a versatile yet professional video converter that enables you to convert videos or audios while finish video editing via personalized options.
Available on: Windows
Pricing: Free trial, $59.99
Flagship features:
- Convert videos & audios into other popular formats playable on various devices
- Edit videos or audios via versatile tools & creative effects
- Customize quality output via parameter settings
- GPU acceleration to quicken the conversion process
- Work with Enlarger AI to upscale low-res videos to 4K
- Intuitive interface, perfect for personal and professional use
Note that DVDFab Video Converter Pro contains three modules, namely, Video Converter, Video Editor, and Toolkit. Among the three bundled programs, the first two can be used to change MOV to MP4. If you wonder how to convert MOV to MP4 Windows 10 or Mac, then Video Converter will meet your needs since it is compatible with Windows and macOS.
DVDFab Video Converter Pro is my top pick in the list of tools for converting MOV to MP4, both for the ease of use as well as the short .mov to mp4 conversion time it takes. All it takes is 2 clicks to get convert MOV file to MP4.
1) Launch DVDFab Video Converter Pro and select the Converter tab when the program runs. Drag and drop the MOV file to the main screen or click on the Add button to locate the file which needs MOV to MP4 conversion. This mov to mp4 converter free supports batch conversion, so you can add several different MOV files to convert.
2) By default as visible in the image above, the conversion output format is selected as MP4. If not, click on the Profile Switcher (MP4 button in the image above) and select MP4 output in the Format section.
Warm tips: When you are trying to convert MOV to MP4 with Video Converter, you can tab the Enlarger AI icon and select MP4. AI as output. This AI video upscaling program can be applied to ai upscale video from 480p to 1080p, or from 1080p to 4K.
3) Once the output format is selected you can click the Advanced Settings (Wrench icon) to set parameters for output video and audio.
Meanwhile, do some video editing to improve video quality. You can crop, trim, or rotate video, add watermark and subtitles to video, adjust video brightness or contrast. There is a merge feature inside this .mov to mp4 converter, so you even can merge several MOV files into one.
4) There is a default directory selected for the output file from converting .MOV to .MP4. You can change it if you like.
5) Click on the Start button to start the conversion process from MOV to MP4 file. DVDFab Video Converter will immediately start the conversion process and will show you the progress in percentage terms. You can also use its mobile app to monitor the progress of the conversion. You can pause or cancel the task anytime and also set what to do after the conversion process is complete – close program, shutdown, hibernate or do nothing once it has converted the MOV file to MP4.
Of course, if you want more options for video editing while converting MOV to MP4, then Video Editor will be more useful to you. Video Editor is a professional yet versatile video editor skilled in editing videos or audios with handy tools and ample creative effects. As for how to use Video Editor, click this link for detailed information.
Movavi Video Converter
In our list of software to change MOV to MP4 the second entry is on Movavi Video Converter. Movavi deserves a mention in this list because of the one screen interface it offers for the whole conversion process. Let’s see how to convert .MOV to MP4 using the Movavi video converter.
1) Install and start the .mov to .mp4 converter. On the home screen can drag and drop the MOV file or click on the File icon to import a file. You can even import a whole folder if you want to add multiple files for MOV to MP4 conversion.
2) Once you have added the files for conversion from MOV to MP4, you just need to select the output format from the list of formats below, select the output file location and click on the Convert button to start converting MOV to MP4.
3) Just like DVDFab Video Converter, you have similar video editing tools that allow you to manage subtitles, trim the video, add a watermark, and do other adjustments. Movavi also has the feature to merge two or more input video files into one converted MP4 file.
Online-Convert.com
The next tool to convert MOV to MP4 online is Online-Convert.com. This one-page tool lets you convert mov to mp4 free without the need to install any software or pay any charges. All you need to do is to upload the file, do any optional settings if required, and hit the Convert file button. The Optional settings while converting MOV to MP4 offer you some of the same functionality as the above 2 tools in Advanced Settings and Video editing options. If your conversion task very straightforward then you can look at this website to convert MOV to MP4.
VLC player
No, there is no mistake on my end and you are reading it correctly. Your favorite VLC media player has a lot of capabilities and one of them is to convert MOV file to MP4. Let’s see how you can do it too in a few simple steps.
1) Open your VLC media player, click on the Media button in the Menu bar, and select the Convert / Save option.
2) In the next screen either drag and drop the MOV file or click on the Add button to locate the file for conversion from MOV to MP4. Now select the destination file folder and click on the Start button.
3) VLC media player converter features are not as fancy as those of the above-listed tools but it gets the task done if you don’t plan to do any video editing or changes in the output file other than the default.
Though it doesn’t have many features, it gets listed in our list of tools to convert MOV to MP4 because it is already used by a number of people and therefore it makes it a tool that people already have installed on their computers.
Wondershare Video Converter
Our last entry in the list, Wondershare Video Converter is a known name in the Video converter community. Let us see how to convert MOV to MP4 using Wondershare Video Converter.
1) Launch Wondershare Video Converter and then click on Add Files to add MOV files for MP4 conversion. You can also drag and drop the files to the home screen of the converter. It also supports batch conversion of files so you can even drag and drop a whole folder of MOV files.
2) Once you have loaded the files you can preview the details of the output file like its size, resolution, length, and output file type. From the same screen, you add effects to the video, trim, and crop parts of it. You can choose to Merge All Videos if you are doing a batch conversion and more. Once you have bought the tool you get access to even more powerful features like High-Speed conversion. You can also define what to do after the conversion process is complete – Do Nothing, Shutdown, Hibernate, etc.
Wrap up
If you are an Apple device user and deal with a lot of MOV files regularly, having a tool to convert MOV files to MP4 is a must-have. If you are looking for a professional solution, DVDFab Video Converter is the first tool you should consider to change MOV file to MP4. With its quick performance, batch conversion facility, lot of video editing features, and professional quality Advanced features it is a no-brainer that you should consider when thinking about how to convert MOV file to MP4. However, if your need for a MOV to MP4 conversion is one-off then you can consider VLC or Online-Convert.com. If you prefer to use an online video converter, please click Top 8 Best Online Video Converters to learn more.
