How to Burn DVD from iMovie: Export, Author, and Play on DVD Players
Summary: Learn how to turn an iMovie project into a playable DVD-Video disc instead of simply copying a video file to a data DVD. This guide covers the full workflow for exporting iMovie videos, explains why iDVD only works as a legacy option on older Macs, and shows how DVDFab DVD Creator can author DVDs with menus, ISO files, folders, and physical disc output.
iMovie is a free video editing software developed by Apple for macOS and iOS devices. It comes pre-installed on most Macs and iPhones, allowing users to easily import photos and clips, add titles, music, filters, and transitions, and quickly create high-quality home movies or short videos. iMovie can edit and export your movie, but it does not create DVD menus or write DVD-Video structures by itself.
This guide explains the practical workflow for the US market: how to export an iMovie project, when the old iDVD method still applies, and how to convert iMovie to DVD with DVDFab when you need a disc that can play on a home DVD player.
Before You Burn iMovie to DVD
There are two different things people often call DVD burning. A data DVD stores your exported MP4 or MOV file like a USB drive. A DVD-Video disc uses a specific DVD structure so a standalone DVD player can read menus, titles, and playback controls. If your goal is to watch the movie on a living-room DVD player, you need DVD authoring, not just file copying.
Most recent Macs also do not include an internal optical drive. You will need an external DVD burner and a blank writable disc such as DVD-R, DVD+R, or DVD-RW. For the broadest playback compatibility, DVD-R is usually a safe starting point, but the final result still depends on the burner, blank media quality, and the DVD player you use for testing.
- Use iMovie to edit and export the finished project.
- Use DVD authoring software to create DVD-Video structure and menus.
- Use an external DVD burner if your Mac has no built-in optical drive.
- Test the burned disc on both a computer and a standalone DVD player.
How to Export iMovie Project for DVD Burning
Step 1: Open and Select Your iMovie Video
Open iMovie on your Mac and select the project you want to burn. Review the timeline first, especially if the project includes titles, transitions, background music, or voiceover tracks. The exported file should represent the exact version you want on the disc.
Step 2: Export the Project to a Local File
Choose File > Share > File from the top menu. In the export window, select a resolution and quality setting that fits your source video. For most home movies, 1080p with High quality is suitable before DVD conversion, even though standard DVD output will be encoded at DVD resolution later.
Step 3: Save the Exported Video
Save the exported file to a folder you can find easily, such as Movies or Desktop. iMovie usually exports to a Mac-friendly video format such as MP4 or MOV. After export, play the file once in QuickTime Player or another media player to confirm that the audio, titles, and ending are correct before you start DVD authoring.
How to Burn iMovie to DVD on Mac Using iDVD
iDVD is only relevant if you are working on an older Mac that already has iDVD installed. It was part of Apple's iLife suite and has been discontinued for years. Since macOS Catalina 10.15, 32-bit apps are no longer compatible with macOS, so iDVD is not a realistic option for current Macs.
If you still maintain an older Mac with iDVD and a compatible DVD burner, you can use it as a legacy method. This is useful for restoring old projects, but it should not be the primary workflow for a new Mac setup.
Step 1: Export the iMovie Project
Export your iMovie project as a local video file first. Use the File sharing option in iMovie and save the finished movie to your Mac. Avoid editing the project further after export unless you plan to export a new file.
Step 2: Import the Video into iDVD
Open iDVD, create a new DVD project, and import the exported iMovie video. Choose a theme, adjust the menu text, and preview the DVD navigation before burning. Older iDVD workflows may also include direct iMovie integration, but this depends on the iMovie and iDVD versions installed on that Mac.
Step 3: Burn and Test the Disc
Insert a blank writable DVD into your computer or external burner, then start to burn a DVD on Mac in iDVD. After burning, test the disc in a standalone DVD player if that is your target device. A disc that plays on the Mac is not always guaranteed to work on every older DVD player.
Burn DVD from iMovie Using DVDFab DVD Creator
For newer Macs and Windows PCs, DVDFab DVD Creator provides a maintained way to convert exported iMovie videos into DVD disc, ISO, or folder output. It supports common video formats such as MP4, MOV, AVI, MKV, M2TS, and VOB, which makes it suitable when your iMovie project has already been exported as a normal video file.
The key benefit is that DVDFab DVD Creator performs DVD authoring, not just file burning. That means it can create a DVD structure with menus, subtitles, audio tracks, and disc output options for playback on DVD players or media software.
Features of this tool:
- Burn any video to DVD blank disc or save as ISO/Folder
- Supports more than 200 video formats including AVI, MP4, MKV, M2TS, etc
- Personalize DVD movies via free menu templates
- GPU acceleration with 50x faster DVD burning speed
- Customize menu templates with your own style
- Use built-in editor to crop, trim, adjust color and add watermarks, etc.
How to burn iMovie to DVD on Mac with DVDFab DVD Creator
Download and install DVDFab on your PC
Launch the tool and select Creator from the option bar present at the top. Upload the source video or you can also do this by drag and drop function.
Customize your DVD with built-in templates
After loading the source video, click "Advanced Settings" and choose the output size and quality you prefer. You can also click the "Menu Settings" icon to customize your menu.
If you want to crop, rotate, trim, adjust color saturation and brightness, add watermarks, you can click "Video edit" and "Trim" to edit your DVD as your own will.
You can also customize your videos with "Editing" function before the conversion.
Start burning your DVD
Choose the output folder in Save to Path, and tap the Start option to burn AVI to DVD.
Comparison: Which Is Better for Burning iMovie to DVD
The right tool depends mainly on your Mac version and whether you need a maintained DVD authoring workflow. Use the table below to compare practical factors that affect an iMovie to DVD project.
| Feature | DVDFab DVD Creator | iDVD |
| Best use case | Creating DVD disc, ISO, or folder from exported video files | Legacy DVD projects on older Macs with iDVD already installed |
| Burn video to DVD, folder, or ISO | YES | YES |
| Supported input formats | Wide range | Limited |
| Preview DVD video | YES | NO |
| Select audio tracks and subtitles | YES | NO |
| Design disc menu | Yes | Yes |
| Platform compatibility | Windows & Mac | Mac only (up to macOS 10.6) |
| Customer support | YES | NO |
Is iDVD still available for Mac?
No. iDVD is discontinued and is not a normal option for current Macs. It may still exist on older systems that already had iLife installed, but it is not compatible with macOS Catalina 10.15 or later because Apple ended support for 32-bit apps in that macOS release. For a new iMovie to DVD workflow, use maintained DVD authoring software instead of trying to rebuild an old iDVD setup.
ACan I burn a playable DVD from iMovie with Finder?
Finder can copy an exported MP4 or MOV file to a blank DVD as data, but that is not the same as creating a playable DVD-Video disc. Some computers may read the file, while many standalone DVD players expect a proper DVD structure. If playback on a TV DVD player matters, export from iMovie first and then use DVD authoring software.
AIWhat export settings should I use before burning iMovie to DVD?
Export the finished iMovie project as a high-quality MP4 or MOV file. For most projects, 1080p and High quality are suitable source settings before DVD conversion. Standard DVD output will be encoded to DVD resolution, so exporting a clean source file matters more than forcing an oversized export. Always play the exported file once before adding it to a DVD creator.
AConclusion
To burn DVD from iMovie, the first step is exporting your project properly. Although iDVD was formerly a native solution, its discontinuation renders it an unstable choice. A dependable alternative with advanced capabilities like menu design and subtitle support is provided by DVDFab DVD Creator. It's a smart choice for turning iMovie projects into playable DVDs.
![How to Convert MKV to DVD with Stylish Menu? [2026 Updated]](https://r3.dvdfab.cn/upload/resource/mkv-to-dvd-yO3k.jpeg)
