How to Burn a DVD on Mac in 2026: Video, Data, Photos & ISO
Summary: To burn a DVD on Mac, choose the method based on the finished disc you need. Use DVDFab DVD Creator for a playable DVD-Video disc, Finder for files or supported disk images, Photos or iMovie to export videos before DVD authoring, and Music for Audio CDs, MP3 CDs, or data discs. Current Macs also require a writable external optical drive.
When I burn a DVD on my Mac, I first decide what I need the finished disc to do. A disc that only stores photos or MP4 files is a data DVD, while a movie disc for a standalone player needs DVD-Video authoring. That distinction determines whether Finder is enough or dedicated authoring software is required.
I tested the main DVD burning methods on macOS Sequoia 15, including Finder data burning, disk-image burning, the Music app, and DVD-Video authoring with DVDFab DVD Creator. I also verified the current system requirements and output options so that each method matches the source and intended playback device.
Quick Answer: Choose the Right Way to Burn a DVD on Mac
The method depends on what you want the finished disc to do. Finder can burn files for storage and write supported disk images, but it does not convert an ordinary MP4 or MOV into the DVD-Video structure expected by a standalone DVD player.
What You Need to Burn a DVD on Mac
- A writable optical drive: Most current Macs do not include an internal DVD drive, so you will normally need an external DVD writer. Check that the drive supports writing the type of blank disc you plan to use.
- The correct blank media: DVD-R and DVD+R are write-once formats. DVD-RW and DVD+RW are rewritable. DVD-5 has a nominal capacity of 4.7 GB, while dual-layer DVD-9 has a nominal capacity of 8.5 GB.
- The source: This may be a video file, a collection of photos, an iMovie project, an ISO or DMG image, music files, or another DVD.
- The playback goal: A disc used for file storage is not the same as a DVD-Video disc intended for a television or standalone DVD player.
| What You Want to Create | Method | Finished Result | Important Limit |
| Playable movie DVD | DVDFab DVD Creator | DVD-Video | Requires DVD authoring. Finder alone does not convert video files into DVD-Video. |
| Photos, videos, documents, or other files for storage | Finder | Data DVD | The files remain ordinary data and may not play in a standalone DVD player. |
| Existing ISO or DMG disk image | Finder | Disc written from the existing image | This writes the image as it already exists. It does not author ordinary video files into DVD-Video. |
| Photo or iMovie slideshow for TV playback | Export a video first, then use DVD authoring software | DVD-Video | Photos and iMovie create or export the video; another application completes DVD-Video authoring. |
| Audio CD, MP3 CD, or playlist-based data disc | Music | Audio CD, MP3 CD, or data CD/DVD | Music does not create DVD-Video movie discs. |
If Your Source Is Another DVD
If your starting point is another DVD, copying or ripping is a separate step from authoring video files. To rip and burn a DVD on Mac, first create the video file you are permitted to use, then author that file as DVD-Video if the new disc needs to play in a standalone player.
If you want to copy and burn a DVD on Mac while retaining the original disc structure, see the separate guide on how to copy a DVD on Mac. For commercial or protected material, use only content you own or have permission to copy and follow applicable local law.
How to Burn a Playable DVD on Mac
A playable movie DVD needs DVD-Video authoring. The authoring software converts your source video into the disc structure used by DVD players and can also add a menu, chapters, audio tracks, or subtitles.
DVDFab DVD Creator can burn MP4, MOV, MKV, AVI, and other 200+ video formats into a playable DVD-Video disc on Mac. After loading the video, you can choose DVD-5 or DVD-9, set the TV standard and aspect ratio, organize chapters, add audio or subtitle tracks, and create a navigation menu before burning. The finished project can be written directly to a blank DVD for playback on a standalone DVD player, or saved as an ISO image or DVD folder first.
Its menu editor is particularly useful when the disc contains several videos or chapters. You can choose a template, change the background, text, thumbnails, and playback buttons, then preview the navigation before writing the disc. This lets you check the DVD structure and playback settings before committing the project to physical media.
Mac requirements: macOS 12 or newer; Intel Core i5 or Apple silicon.
Free Download macOS 12 or newer
- Accepts 200+ input formats, including MOV, MP4, MKV, AVI, M2TS, and WebM
- Includes menu templates with editable backgrounds, music, buttons, chapters, and thumbnails
- Creates DVD-5, DVD-9, ISO, and VIDEO_TS output
- Uses NVIDIA, AMD, Intel, or Apple Silicon acceleration on supported hardware
- Imports SRT, ASS, or SSA subtitles and supports multiple audio tracks
- Provides a 30-day trial with no video-length cap for DVD Creator
- Includes trimming, cropping, aspect-ratio, color, watermark, rotation, and merge tools
Step 1: Open DVDFab DVD Creator and Load the Video
Launch DVDFab and select Creator > DVD Creator. Click Add or drag the video files into the main window. Add multiple videos if you want more than one title on the same DVD.
Step 2: Set DVD Size, Menu, Chapters, and Subtitles
Open Advanced Settings and select DVD-5 or DVD-9 to match the blank disc. Check the aspect ratio and video standard required by your target player. You can also select audio and subtitle tracks and adjust chapter settings.
Open Menu Settings if the DVD needs a navigation menu. Select a template, change the background or title text, and preview the menu before writing the disc.
If the source needs a final crop, trim, watermark, or subtitle adjustment, open the built-in editor before starting the DVD creation task. Skip this step when the source video is already ready to burn.
Step 3: Choose Disc, ISO, or DVD Folder and Start Burning the DVD on Your Mac
Insert a writable DVD and select the optical drive as the destination when you want a physical disc. You can instead save an ISO image or DVD folder when you want to keep the authored DVD structure and burn it later. Review the project, click Start, and test the finished disc on the player where you plan to use it.
How to Burn a Data DVD on Mac for Free
A Finder data DVD stores files without creating DVD-Video. It is the free choice for documents, photos, project backups, or videos meant to open on a computer.
Step 1: Open the Blank Disc in Finder
Insert a blank disc and choose Open in Finder if macOS displays an action dialog. The disc should appear under Locations in the Finder sidebar.
Step 2: Add Data Files to the Disc
Open the blank disc in Finder and drag the required files and folders into its window. The staged items are aliases until the burn begins, so keep the source files in place.
Step 3: Burn the Data to DVD in Finder
Choose File > Burn “Untitled DVD” to Disc, enter a disc name, select a conservative write speed if reliability has been poor, and click Burn. Let Finder finish and eject the disc before disconnecting the drive.
How to Burn a Disk Image to DVD on Mac
Current versions of macOS can write an existing DMG or ISO image from Finder. Do not look for the retired Disk Utility toolbar command described in older tutorials.
Burn a DMG or ISO in Finder
Step 1: Insert compatible blank media. Wait until macOS recognizes the external writer.
Step 2: Select the image in Finder. Click the DMG or ISO file once; do not mount it first.
Step 3: Choose the burn command. Open File > Burn Disk Image “[name]” to Disc, select the writer and speed, then start the burn.
Step 4: Let the verification finish. Keep the drive connected until Finder completes the burn and ejects the disc.
How to Burn Pictures or iMovie Videos to DVD on Mac
To burn pictures to a DVD on Mac, decide first whether you want a file backup or a slideshow that plays through a television and standalone DVD player.
For Photo or File Backup: Use Finder
If the DVD is only an archive of JPG, HEIC, PNG, MOV, or other files, use Finder to create a data DVD. The original files stay intact and can be opened from a computer, but the disc does not become a DVD-Video slideshow.
For a Photo Slideshow That Plays on a TV
Photos can create a slideshow project and export it as a video file. In Photos, create the slideshow, then select the project and use File > Export > Export Slideshow. Save the resulting video, then import that file into DVD authoring software such as DVDFab DVD Creator.
This separates the two jobs correctly: Photos creates the slideshow video, while the DVD authoring application builds the DVD-Video structure required for disc playback.
For an iMovie Project
Finish the project in iMovie, then choose File > Share > File to export it as a video file. Import that exported video into DVD authoring software when the finished disc needs to work as DVD-Video.
If the iMovie export only needs to be stored on a disc for later computer access, burn the exported file as a data DVD with Finder instead. You do not need DVD authoring for that use case.
How to Burn an Audio CD on Mac with Music
The Music app can burn music to disc as a standard audio CD. Use blank CD-R media, not a DVD, when the target is a car stereo or CD player.
Burn a Playlist with the Music App
A standard CD-R holds about 80 minutes in Audio CD format. Music prompts you to divide a longer playlist across discs. MP3 CDs hold more tracks, but the player must support MP3 discs.
The Mac steps use Music; if you move the same playlist to a PC, Windows follows a separate process to burn CDs on Windows 10.
Why Is "Burn to Disc" Missing on My Mac?
Check that a writable external optical drive is connected and appears under System Settings > General > About > System Report > Disc Burning. Finder may not show disc-burning commands when a writable drive is unavailable or when the selected item cannot be burned that way.
Do I Need an External DVD Drive on a Mac?
Yes. Current Macs need a compatible external optical writer. Connect it directly or use a powered hub, and confirm that the drive can write the DVD-R, DVD+R, rewritable, or dual-layer media you plan to use.
Does DVD Burning Work on Apple Silicon Macs?
Yes, with compatible hardware and software. Finder and Music are built into macOS on Apple silicon. DVDFab supports macOS 12 or newer on both Intel and Apple silicon Macs, with VideoToolbox acceleration available on M1, M2, M3, and M4 systems.
Can I Burn an iMovie Project to DVD?
Export the finished iMovie project as MOV or MP4, then use DVD-Video authoring software to create a playable disc. Finder can store the exported file on a data DVD, but that disc is not the same as DVD-Video.
Why Won't My Mac Recognize a Blank DVD?
Connect the drive directly or through a powered hub, try known-good media, and confirm that the writer supports the inserted format. If macOS sees the drive but not the disc, test another blank disc before changing software.
Final Thoughts
Choose the tool based on the disc you need. Finder is enough for files and existing images, while Music handles audio CDs. For menus and standalone playback, use DVD-Video authoring software such as DVDFab DVD Creator and make sure your Mac meets the app's stated system requirements.
Before a full burn, check the drive connection, media type, project size, video standard, and menu preview. A short test on rewritable media can expose a power, disc, or player problem before you commit the final DVD-R.
![18 Best Free DVD Burner Software for Windows [2026 Review]](https://images.dvdfab.cn/media/Best_Free_DVD_Burner_Software_for_Windows_16sgci.png/public)
