How to Burn DVD with Subtitles: Add SRT/ASS or Hardcode Captions
Summary: To burn a DVD with subtitles, use DVDFab DVD Creator to add SRT or ASS files as subtitles and create a DVD disc, ISO, or folder. For a free option, DVDStyler can author DVDs with multiple subtitle tracks. If the subtitles must always stay visible or preserve complex ASS styling, use FFmpeg to hardcode them into the video first, then author the video with DVDFab DVD Creator or DVDStyler.
When I need to burn a DVD with subtitles, the first choice is not the burner itself but the subtitle behavior I want after authoring. A selectable subtitle track can be turned on or off, while hardcoded subtitles stay in the picture. External SRT or ASS files also need to be added during DVD authoring; copying a subtitle file beside the video does not create a playable DVD subtitle track.
I checked the current SRT/ASS authoring options, a free DVD authoring method, and subtitle-rendering tools to separate cases where subtitles should stay selectable from those where hardcoding works better. The sections below explain how to burn a DVD with subtitles and check the result before writing a physical disc.
Before You Burn: Selectable vs. Hardcoded Subtitles
An SRT or ASS file is not the same thing as a DVD subtitle track. SRT mainly stores subtitle text and timing, while ASS can also contain fonts, colors, positioning, and other styling. During DVD authoring, the subtitle content must be converted into a form the DVD-Video structure and player can use.
The first decision is whether viewers should be able to turn the subtitles off. Selectable subtitles stay separate from the video image. Hardcoded subtitles are rendered into the video itself, so they remain visible during playback and cannot be switched off.
| What you need | Better choice |
| Viewers can turn subtitles on or off | Selectable subtitle track |
| Subtitles must always stay visible | Hardcoded subtitles |
| Several subtitle languages on one DVD | Separate subtitle tracks |
| Complex ASS positioning or effects must remain visible | Hardcode before DVD authoring |
| A standalone player does not display the subtitle track correctly | Test another authored output or hardcode the subtitles |
SRT is usually the simpler source for a DVD project because it focuses on text and timing. ASS is useful when the source includes styling, but DVD authoring may not reproduce every ASS effect exactly. If the appearance matters, preview the authored output before using a blank disc.
- Save text subtitles as UTF-8 when they contain accented or non-English characters.
- Play the source video with the subtitle file first and confirm that the timing matches the exact video version.
- Use video and subtitle material you own or have permission to reproduce.
- Create a test output before making multiple physical discs.
How to Burn DVD with Subtitles Using DVDFab DVD Creator
DVDFab DVD Creator can author common video files into a DVD disc, ISO image, or DVD folder and lets you add external SRT or ASS subtitles before creation. It keeps subtitle settings, DVD format, menu design, and disc output in the same application.
Key Features:
- Add external SRT or ASS subtitles before creating the DVD.
- Adjust subtitle font, position, character code, and delay.
- Create a DVD disc, ISO image, or DVD folder for testing and playback.
- Customize DVD menus for easier playback navigation.
- Edit the video with the built-in video editor.
- Preview the project before writing to a blank DVD.
Supported OS:
Free Download macOS 12 or newer
- Styled ASS subtitles may not keep every advanced effect after DVD authoring.
- Correct a badly timed subtitle file before or during authoring.
- Preview the subtitle track before making several physical copies.
Prepare the source video and subtitle file before opening the project. Keeping them in the same folder with clear filenames is optional, but it makes it easier to avoid importing the wrong subtitle when several languages or video versions are involved.
Step 1: Open the DVD Creator Module
Download and install DVDFab on your Windows or Mac computer. Launch the program and select Creator > DVD Creator.
Step 2: Load the Video and Add the Subtitle File
Click Add to import the video you want to burn. The source can be a common video format such as MP4, MOV, MKV, or AVI. If your footage comes from a camcorder, you can also convert MTS to DVD and add an external subtitle before authoring the disc.
Open the subtitle control for the loaded title and choose Add External Subtitles when the video does not already contain the subtitle you need. Select the SRT or ASS file and check that the correct language and subtitle version have been imported.
Step 3: Adjust Subtitle Timing, Encoding, and Position
After you add the external subtitle, open its settings to adjust the available font, language, character code, position, edge, and subtitle delay options.
Pay particular attention to character encoding when the subtitles contain accented letters or non-Latin scripts. Preview the opening, middle, and end of the video rather than checking only one scene.
Step 4: Set the DVD Format and Menu
Open Advanced Settings to choose the output size, video quality, aspect ratio, TV standard, volume label, and playback mode. Use DVD-5 for a single-layer project or DVD-9 when the content needs the larger capacity. Choose NTSC or PAL according to the playback equipment for which you are preparing the disc.
Open Menu Settings if the DVD needs navigation or contains several titles or languages. For a multi-language project, keep the menu and subtitle options easy to identify. Cropping, filters, watermarks, and other visual edits are optional and do not need to be changed simply because you are adding subtitles.
Step 5: Preview the DVD Before You Burn It
For an important subtitle project, create an ISO image or DVD folder first instead of using the first blank disc as your test. Play the authored output in DVD-capable software and check the beginning, middle, and end of the video.
- Confirm that the subtitle track appears and can be selected as expected.
- Check that accented and non-English characters display correctly.
- Verify that subtitle timing remains synchronized throughout the video.
- Check that the menu opens the correct title and subtitle option.
Once the test output works as expected, select the DVD drive as the output destination, insert a blank disc, and click Start. If the disc will be shared with other people, test one physical copy on the type of standalone DVD player they are likely to use before making additional copies.
How to Burn a DVD with Subtitles for Free Using DVDStyler
DVDStyler is a free, open-source DVD authoring application that can create playable DVD-Video projects with menus and multiple subtitle tracks. It is an option when you need basic DVD authoring without paying for a commercial creator.
Step 1: Create the DVD Project
Open DVDStyler and create a new project. Select 4.7 GB for a single-layer DVD or 8.5 GB for a double-layer disc, then choose NTSC or PAL according to the target playback system.
Step 2: Add the Video and Subtitle Track
Open the File Browser and drag the video into the Titleset Manager. Open the title properties and add the external subtitle as a subtitle track. Repeat the process for each additional language when needed.
Step 3: Set Up the Menu if Needed
A menu is optional for a simple one-video disc, but it becomes more useful when the DVD contains several titles or subtitle languages. Keep the Play and subtitle selections easy to identify instead of filling the menu with unnecessary buttons.
Step 4: Preview and Burn the DVD
Click Burn and enable Preview before writing the disc. DVDStyler creates the DVD structure first and can open the preview before physical burning starts. Check the subtitle timing, language selection, and menu navigation, then continue with the blank disc if the project is correct.
DVDStyler covers the task for free if you are comfortable setting up the DVD project manually. DVDFab keeps external subtitle settings, menu setup, ISO or folder output, and disc creation inside the same application.
How to Hardcode Subtitles Before Burning a DVD
Hardcode the subtitles first when they must remain visible all the time, or when preserving their appearance matters more than letting viewers switch them off. Hardcoding renders the subtitle into the video image itself, so the text cannot be removed during DVD playback.
Hardcode SRT or ASS with FFmpeg
FFmpeg can render a subtitle file onto a video before DVD authoring. The subtitles filter requires an FFmpeg build with libass enabled. If the video and SRT file are in the same folder, a basic command is:
ffmpeg -i input.mp4 -vf "subtitles=subtitles.srt" -c:v libx264 -c:a aac output-subbed.mp4The subtitles=subtitles.srt filter draws the subtitle into the image, so the video must be encoded again. If you use an ASS file instead, replace the filter with ass=subtitles.ass. Make sure any fonts required by the ASS styling are available to the subtitle renderer.
The MP4 produced here is an intermediate video, not the final DVD-Video structure. When you add it to DVD authoring software, the authoring program will convert the video to the DVD-Video format as needed.
Author the Hardcoded Video as DVD-Video
Add the hardcoded video to DVDFab DVD Creator, DVDStyler, or another DVD authoring application. You do not need to add the same SRT or ASS file again unless you also want a separate selectable subtitle track.
FFmpeg performs the subtitle rendering in this method. The DVD authoring application creates the playable DVD structure, menu if needed, and physical disc.
Fix Subtitle Problems Before Burning the DVD
Subtitles Do Not Appear
Confirm that the subtitle was added to the title as an actual subtitle track rather than simply stored in the same folder as the video. If the DVD uses selectable subtitles, open the subtitle control in the preview player and select the track manually.
If the subtitle works in the authored preview but not on a standalone player, test the same disc on another player before changing the subtitle file. This helps separate an authoring problem from a playback-device issue.
Subtitle Characters Are Garbled or Missing
Save the SRT file as UTF-8 and check the character-code setting in the authoring software. This is especially important with accented characters and non-Latin scripts. If only certain characters fail, inspect the subtitle text and font before changing the DVD format.
Every Subtitle Appears Too Early or Too Late
A nearly constant timing error can usually be corrected with subtitle delay. Measure the offset at several places in the video first. If the subtitles remain about the same amount early or late from beginning to end, apply the corresponding adjustment.
Subtitle Sync Gets Worse During Playback
Do not keep increasing the delay when the gap grows throughout the movie. The subtitle file may have been timed for a different cut, frame rate, or opening sequence. Retime it against the exact source video and import the corrected subtitle into the DVD project again.
ASS Styling Looks Different on the DVD
ASS can contain custom fonts, positioning, colors, and effects that do not translate directly into DVD subtitle presentation. If keeping that appearance is more important than turning the subtitles off, render the ASS subtitle into the video before DVD authoring.
Can I burn an SRT file directly to a DVD?
You can copy an SRT file onto a data DVD, but that alone does not create a DVD-Video subtitle track. For a playable movie DVD with selectable subtitles, import the SRT file into DVD authoring software and create the DVD-Video structure.
Do the video and SRT file need the same filename?
No. DVD authoring software that lets you import an external subtitle does not normally require identical filenames. Matching names are still useful when you manage several videos or subtitle languages.
Can I add multiple subtitle languages to one DVD?
Yes, if the DVD authoring software supports multiple subtitle tracks. Add each language separately and verify the subtitle selection before burning the physical disc.
Can I add subtitles to an already-burned DVD?
Not by simply adding an SRT file to a finalized DVD-Video disc. Normally you need to return to the source project, add the subtitle, author the DVD again, and burn a new disc.
Can FFmpeg create a playable DVD with subtitles by itself?
FFmpeg can render subtitles into the video and prepare encoded streams, but a DVD authoring application is the simpler way to build the complete DVD-Video structure, navigation, and physical disc.
To burn a DVD with subtitles, decide first whether the subtitles should remain selectable or always stay on screen. Add SRT or ASS during DVD authoring when viewers need subtitle control; hardcode the subtitles first when permanent display or complex styling matters more. DVDFab DVD Creator provides an integrated authoring option, while DVDStyler covers the basic task for free.
Whichever method you use, check the subtitle timing, characters, selection, and playback behavior before writing several discs. Creating and previewing the DVD structure first is easier than discovering a subtitle problem after the physical copies have already been burned. If you need to do the reverse task, see how to extract subtitles from DVD.
![5 Top AVI to DVD Converters for Windows and Mac [2026]](https://images.dvdfab.cn/artifact/2026/10/19/HsCx2t8W3VyD6wHfogzkhte4XqgpBqdz/feature_cover.jpg)
![Convert Video to DVD: 5 Free & Paid Video to DVD Converters [2026]](https://images.dvdfab.cn/media/convert_vidoe_to_dvd_dza0f3.png/public)
