iMovie can export your finished movie, but it cannot create a DVD-Video disc for a standard DVD player. Export the project as a high-quality local video file, then use DVD authoring software such as DVDFab DVD Creator or the free DVDStyler to create the disc. Finder is enough only when you want a data DVD that stores the video file rather than a playable movie DVD.
By Wenny Yan - Nov 23, 2026
WinX DVD Copy Pro remains an active Windows utility for disc-to-disc copies, ISO and VIDEO_TS backups, and MPEG-2 extraction. This review checks its documented scope, licensing, workflow, user feedback, and evidence limits, then compares it with DVDFab DVD Copy for readers who need Mac support, compression, or queued tasks.
By Wenny Yan - Nov 20, 2026
To convert DVD to USB, you can choose from three ways. The first is using a professional ripper like DVDFab to bypass encryption and convert movies into MP4 files for Smart TVs or cars playback. The second is a direct copy and paste for unprotected data or home movies to USB. The third is hiring local DVD to USB transfer services if you lack a computer or a disc drive.
By Diana Smith - Nov 20, 2026
DVD Flick remains a free Windows DVD authoring tool for turning common video files into playable DVDs, VIDEO_TS folders, or ISO images with basic menus and subtitle support. Its value is zero cost, no ads, and broad import support, but the 2009 build is slow to encode and may run into audio sync, import, or Windows 10/11 compatibility issues. Download it from the official site or SourceForge, and choose maintained software like DVDFab for repeated DVD projects.
To copy a DVD on Windows 10/11/8/7, first check your disc type and preferred output. For protected commercial discs, use specialized software such as DVDFab DVD Copy, DVDFab DVD Ripper, or HandBrake to copy the DVD to another disc, ISO, VIDEO_TS folder, or MP4/MKV file on your computer. For homemade or data DVDs, Windows File Explorer may be enough.
By Wenny Yan - Nov 18, 2026
To convert DVD to MP3, use VLC for an unprotected or home-authored disc, DVD Audio Extractor when you want chapter-separated tracks and metadata, or DVDFab DVD Ripper when you need to load a protected disc, ISO, or VIDEO_TS folder and select its title and audio stream. HandBrake cannot create a standalone MP3 by itself, while Zamzar only converts an existing VOB file and limits free uploads to 50 MB. The right method depends on your source, disc accessibility, and desired track layout.
DVD/VCR combo production ended in 2016, so today's buying decision is mainly about finding a tested refurbished unit with HDMI, a working tape transport, and the original remote. This guide compares five sought-after models, explains realistic used-market expectations, and shows how to digitize VHS recordings and DVDs for easier playback.
By Wenny Yan - Nov 16, 2026
The sudden shutdown of the official RedFox website has left users unable to access or purchase its software, including CloneCD. This article explains the current status of CloneCD and introduces practical alternatives: DVDFab DVD Copy for decrypting and backing up DVDs, and CDBurnerXP for everyday CD copying tasks.
