How to Copy a DVD to My Computer: 16 Free Dvd Bacup Software 2023
Summary: DVD copy software automatically downloads and updates album and artist information from music databases. This list of Top DVDs Copy Software includes popular software and their features. The list consists of both free and paid open-source software.
A DVD ripper or a DVD Bacup is a computer program that copies DVD or Blu-Ray movies into another file format, most often ISO. It's used to convert audio and video material from DVDs to different formats so they may be edited or backed up. It also allows you to convert a DVD movie for viewing on various media players and mobile devices.
DVD ripping software automatically downloads and updates album and artist information from music databases. It can also convert DVDs to various internet video formats. This list of Top DVD ripping Software includes popular software and their features. The list consists of both free and paid open-source software.
16 Best & Free DVD Bacup Software 2022
1. DVDFab DVD Ripper
DVDFab DVD Ripper allows you to transfer DVDs to PC in standard digital formats. So, if you want the video or audio from a film or TV show, DVDFab can effortlessly rip it for you.
Features
- Multi-core CPUs and Intel Quick Sync provide batch conversion, allowing you to improve the quality of your output movies dramatically.
- Conversion profiles for 4K/H.265 are available.
- It's possible to rip DVDs with several VTS safeguards.
- It's one of the greatest free DVD copy software with audio and video effects.
- It allows you to retrieve detailed information from the music database automatically.
- It can remove DVD copying protection.
2. Ashampoo
Ashampoo is multimedia-burning software that can burn, backup, and rip DVDs. It has built-in normalization to smooth out loudness variations. The software also has a built-in audio player to listen to music before burning. It is one of the best DVD copy applications to copy data.
Features
- Produces excellent video quality. It is equipped with a contemporary H.265 decoder.
- It aids in the creation and burning of music CDs with covers.
- Moreover, it assists you in organizing tunes most appropriately for your vehicle radio.
- The software has a reliable data backup system.
3. Wondershare
Wondershare DVD Copy allows you to copy DVDs in up to 150 formats. It's simple to burn music to CD or DVD. A DVD project file may be created for easy editing.
Features
- Burn DVDs with a single click, making it simple for anybody to do so.
- It enables you to burn several videos in various formats to a DVD.
- It has a CD ripper capability that allows you to rip CDs effortlessly.
4. WinX DVD Ripper
WinX DVD digitizes DVDs for convenient backup, editing, and sharing. It can copy DVDs in ASF, DAT, MPEG, and MP4 formats. It also plays copy-protected DVDs.
Features
- The WinX DVD player can play both advertisements and homemade DVDs.
- Music in MP3, WMA, RMA, and other ISO formats may be played.
- It's one of Mac's greatest free DVD copiers since you can choose the playing speed.
- You may copy a DVD to an MPEG2 file using WinX DVD Copy Pro.
- It's one of the best Mac DVD copiers, featuring a high-quality engine and de-interlacing.
5. Wonderfox
Wonderfox DVD is a DVD copy application that allows you to choose your output format and start copying DVDs. This utility copies DVDs in 5 minutes.
Features
- It's one of the best free copy DVD software for Windows, with basic editing capabilities.
- It allows you to backup DVDs in as little as five minutes.
6. AVS4YOU
To burn video files from your hard drive straight onto a DVD, use AVS4YOU. It can also write data to Blu-ray discs.
Features
- Burn video files directly from a hard drive to a DVD: DVD+/-R, DVD+/-RW, DVD-RAM, Double/Dual Layer DVD, etc.
- With a BD data capacity of 25 or 50 GB per disc, you may keep your files in the finest quality possible.
- It allows you to generate audio CDs in MP3 and WMA audio formats and an identical clone of the source disc with just one click.
7. BurnAware
BurnAware can copy DVDs and Blu-ray discs to make MP3, audio, and video CDs. It features a simple User experience.
Features
- You can burn CDs, DVDs, and Blu-ray discs with it.
- Multi-Session CDs can be added to or updated.
- It aids in the creation of bootable and multi-session CDs and DVDs.
- Assists with file extraction from multi-session and allow you to create both regular and boot disc images.
- It can store data on optical discs such as CDs, DVDs, Blu-ray discs, double-layer discs, M-Discs, etc.
8. Opencloner
Opencloner allows you to clone DVDs without image loss. It can decrypt DVDs and then copy them to a blank DVD. Moreover, it can also burn data and video files to blank DVD or Blu-ray discs.
Features
- Copy DVDs to different disc formats or decrypt DVDs for usage on a hard disc.
- Convert Blu-ray/UHD movies to MKV for easier storage.
- It aids in the cloning and writing of Blu-Ray discs.
9. MakeMKV
MakeMKV is a freeware/shareware DVD copying utility. This copying DVD freeware program opens, reads, and writes DVD and Blu-ray discs for free.
Features
- Capable of reading DVD and Blu-ray discs.
- It keeps track of the chapters.
- It's one of the best copy DVD to Mac software which comes with converting and decryption options.
10. Roxio
Using Roxio, you may burn CDs and DVDs straight on your desktop computer. Drag and drop capability makes it easy to create bespoke CDs and DVDs. LPS and cassettes may be turned into MP3s.
Features
- You may import and modify films before burning them on a DVD for viewing and archival purposes.
- You may use it to burn CDs, edit audio, and convert it.
- Discs may be erased or finalized with ease.
- It includes chapters and menus on author DVDs.
- It facilitates creating or burning a DVD from an ISO image file.
- Makes it possible to back up and archive data on a disc.
11. Nero
Nero Burning ROM is a popular DVD burner for burning CDs, DVDs, Blu-rays, and other media. You can burn HD video and photos to CDs, DVDs, Blu-ray discs, and other media.
Features
- Includes a built-in media center to make CDs and DVDs at various speeds.
- It comes with a straightforward toolkit for handling each disc authoring task.
- Nero makes it simple to erase rewritable CDs.
- It is compatible with all current versions of Windows.
12. Leawo DVD Ripper
Leawo DVD Ripper for Windows 10 rips DVDs. This DVD copy program also downloads videos from YouTube and converts them. With it, you can quickly rip and convert DVDs.
Features
- It can convert your DVD to audio or video in over 180 formats.
- You may upload videos from YouTube and other video-sharing websites.
- It includes a video editor and a 3D movie DVD producer, allowing you to personalize video files.
- It is one of the best free DVD copy software that allows you to select subtitles for output videos from source DVD movies.
13. iSkysoft
Make Blu-ray discs of your videos. iSkysoft is a DVD copy program that copies DVDs to ISO or DVD folders. It also lets you make magnificent DVD picture slideshows with music to tell tales with your photos.
Features
- It can burn films on all common disc types, including DVD 5, DVD 9, BD-50, BD-100, etc.
- You can back up your files by burning them on data CDs.
- It has a built-in video editor that allows you to customize DVD movies.
- It can convert DVDs to MP4, AVI, MKV, and more formats.
14. Aimersoft DVD Ripper
Aimersoft DVD Copier is a great DVD ripping program. It supports over 200 SD and HD video formats.
Features
- It Converts DVD audio to MP3, M4A, and other popular file formats.
- It allows you to convert a DVD to a format that can be viewed online.
- It's one of the best DVD copiers for Windows 10, and it works with various DVD formats.
- You can sync ripped DVD movies with the iTunes Library.
- You can include movie information while converting DVD movies.
15. VidCoder
VidCoder is a DVD ripper and transcoder. It is great for configuring the encoding of existing video files.
Features
- There are several configuration choices.
- It's one of the greatest free DVD ripper programs available, including hardware acceleration.
- It has options for the queue, resume, and pause encoding.
- It consists of a fully integrated encoding pipeline.
- The program allows you to specify a video's target bitrate, size, or quality.
- It's one of the best DVD copy software for Windows 10, with batch encoding capabilities.
- Real-time source previews are available
- It produces short preview clips that have been encoded.
16. Freemake DVD Ripping Software
Freemake is one of the greatest DVD copy software that allows you to merge many video files into one. It can rip DVD to MP4, MKV, AVI, WMV, and WebM formats. You can convert movies to Flash, HTML5, and MP3.
Features
- This program extracts original files from all sorts of discs.
- Allows you to pick and save only the DVD titles or chapters you wish to back up as digital files from the disc.
- It's one of the most excellent DVD ripping programs available, and it keeps the original quality.
- It allows you to digitize DVD movies that have subtitles built-in.
- Allows you to post a DVD video to YouTube or share it on your website directly.
- It's one of the top DVD copy software for Windows 10, and it can help you shrink DVD films for easy writing and sharing.
Finding the best DVD ripping software isn't simple because the market has so many possibilities. One thing is sure: having roundups like this one available will make your whole experience much, much simpler.
We have evaluated every accessible application and identified some fantastic solutions. This makes it easy for our readers as they won't have to go through many possibilities to locate the correct one. Here's hope your whole experience is simple enough to pick the best option for you.
