How to Convert DVD to AVI Free: 3 Current Options [2026]
Summary: This guide compares three current ways to convert DVD to AVI: DVDFab DVD Ripper for authorized commercial discs, and VLC or XMedia Recode for unprotected sources. It also explains AVI codec choices for older players, when MP4 is the better format, and how to preserve audio and subtitles.
I remember trying to load some movies onto a flash drive for my parents' old player, only to find it refused to play the modern MP4 files. It turned out that while most devices have moved on, legacy hardware like older car stereos and set-top boxes still lives and dies by the AVI format. If you want to keep these older devices useful, you do not need the latest technology. You need specific and reliable compatibility with DivX or Xvid codecs.
I spent days testing over a dozen DVD to AVI converters to see which ones could handle these older standards without causing audio sync issues. I focus on what changes playback: whether the app can open the source, which AVI video and audio codecs the device accepts, and where the finished file will play. The quick path has three parts:
- Load the DVD, ISO, or VIDEO_TS folder into a tool that supports that source.
- Choose AVI with a video and audio codec the target device recognizes.
- Export one short section and play it on the target device before converting the full title.
![How to Convert DVD to AVI Free: 3 Current Options [2026]](https://images.dvdfab.cn/artifact/2026/09/17/2HqH4KgGwIXxwkHdUUZtp0D98DCpL4gS/feature_cover.jpg)
How to Convert DVD to AVI with DVDFab DVD Ripper
💻Supported OS: Windows 11/10/8.1/8/7 & macOS 12 or newer
DVDFab DVD Ripper is a dedicated DVD-to-AVI converter designed for digitizing commercial, copy-protected DVDs that free tools often fail to read. It can convert DVD collections to AVI for legacy hardware such as older car stereos, DVD players, and set-top boxes. GPU acceleration is also available on compatible hardware. I would choose DVDFab for an authorized commercial disc, old or lightly damaged media, a batch job, or a legacy-device preset.
💡You can follow the video or detailed steps.
Step 1: Open DVDFab DVD Ripper and Load Source
Launch DVDFab 13.0.6.8 and select the Ripper module. Insert your DVD disc into the drive, or drag an ISO/Folder to the center. DVDFab analyzes the Source Info after loading and can read supported protected DVDs.
Free Download macOS 12 or newer
Step 2: Select the AVI Profile
After loading your DVD, you will see all information on the main interface. Now you can select video titles, chapters, audio tracks and subtitles you want to rip, or even add external subtitles.
Then click "Choose Other Profile". Here you can click "Format" - "Video" to select the AVI format directly. Or click "Device" to select your preferred playback device.
Step 3: Personalize Your Video
These settings let you fine-tune the video before conversion.
💡(Optional): If your disc lacks the native language, use the Subtitle Generator AI. It uses vocal separation technology to generate accurate subtitles from the audio track.
Also, you can click the Video Edit icon to crop black bars, remove opening adverts, and adjust the Resolution, Frame Rate, and Bit Rate through Advanced Settings.
Step 4: Start Ripping with GPU Acceleration
Once customized, select your output folder at the bottom. Click the "Start" button for DVD to AVI conversion. Hardware acceleration is available for supported profiles on compatible hardware.
How to Convert DVD to AVI with VLC Media Player
💻Supported OS: Windows, macOS, and Linux
VLC Media Player is an open-source multimedia player developed by the VideoLAN project. While known for playback, it features a hidden "Convert / Save" tool that allows you to convert DVD to AVI for free without installing extra plugins. It is an excellent choice for digitizing unencrypted home discs directly on Windows, macOS, and Linux. It does not provide the protected-disc handling, device presets, subtitle controls, or batch management of a dedicated DVD ripper.
Step 1: Open VLC and Add your Disc
Launch VLC and navigate to Media > Convert / Save. Switch to the Disc tab.
Disc Selection: Ensure DVD is selected. Choose your optical drive under "Disc Device". VLC allows you to choose specific Titles and Chapters. If you are ripping a movie, select the title whose runtime matches the movie to avoid converting a DVD menu loop or bonus content.
Step 2: Create a Custom AVI Profile
Since VLC often lacks a default AVI preset, you must create one manually to ensure compatibility.
- Click the Create a new profile button next to the profile dropdown.
- In the "Profile edition" window, type a profile name. Then, navigate to the Encapsulation tab and strictly select AVI.
- Switch to the Video codec tab. Check the "Video" box and set the codec to MPEG-4 or DivX.
Car stereos and DivX-certified players may require Xvid or DivX video paired with MP3 audio. H.264 inside an AVI container is technically valid but may not be supported by older hardware, which is why selecting MPEG-4 here can improve playback compatibility.
Step 3: Start Conversion
Click Browse to choose a save location. You must manually type the .avi extension at the end of your filename, or VLC might save it without an extension.
Click Start to begin the DVD to AVI conversion. VLC plays the disc in the background as it converts. The time taken depends on the length and complexity of the DVD content.
How to Rip DVD to AVI for Free with XMedia-Recode
💻Supported OS: Windows 11, 10, 8, 8.1, 7
XMedia Recode is a free DVD to AVI converter for Windows that can rip unprotected home DVDs and video files into AVI, MKV, or MP4 formats. It gives you manual codec and bitrate control, which is useful when a DVD rip to AVI must match a specific older player. It also supports NVIDIA, AMD, and Intel hardware acceleration on compatible systems.
Choose XMedia Recode when you want detailed control over AVI video, audio, bitrate, frame rate, and subtitles. It is not the choice for a protected commercial disc, and there is no macOS or Linux build.
Step 1: Download and Install XMedia Recode
Download and install XMedia Recode 3.6.4.1, released on September 26, 2026. This version includes updated FFmpeg, AOM AV1, and libbluray components, along with minor bug fixes.
Step 2: Load Unprotected DVD
Click Open Disc to load your DVD drive. Click Open Disk and insert the DVD. For VIDEO_TS folder conversion, click Open File. Then choose the main movie title from the list.
Step 3: Configure AVI Video and Audio Settings
Under the Format tab, select AVI. Then switch to the Video tab and choose MPEG-4 (Xvid) as the codec for compatibility with older players.
Adjust bitrate and frame rate as needed. In Video, set the FourCC for AVI compatibility and codec matching. Choose an audio codec (MP3 or AC3). If needed, add soft subtitles or burn them in with the Subtitle filter.
If your old home videos look washed out, navigate to the Filters/Preview tab. The "RGB normalization" filter is available for correcting color imbalances before encoding.
Step 4: Start to convert DVD to AVI
After configuring all settings, click Browse to set the output path. Then select the title you want to convert and click Add the job to the queue (the blue plus icon on the navigation bar). Finally, click Encode to start ripping DVD to AVI for free.
Rip DVD to AVI with Icepine Free DVD to AVI Converter (Legacy)
💻Supported OS: Windows XP/Vista/7
Icepine Free DVD to AVI Converter is a classic and lightweight Windows utility. It converts DVDs to AVI files with Xvid, DivX, or H.264 video and MP3 audio. Icepine converts on the fly, so it does not create large temporary files. You can pick titles or chapters, trim clips, and burn in subtitles. While it supports essential codecs, you should be aware that it is a legacy software (v2.0.2) designed for the Windows 7 era, so it may require Compatibility Mode to run on Windows 10 or 11.
Steps to Rip DVD to AVI with Icepine
Step 1: Download and install Icepine Free DVD to AVI Converter (v2.0.2) on your computer. Please note that it targets Windows XP/Vista/7 and does not remove DVD copy protection.
Step 2: Insert the DVD you want to convert, and then click Add to load your disc to the software. You can also add a VIDEO_TS folder to the software.
After displaying the information of titles and size, pick the main movie title (usually the longest one) or specific chapters to convert. Make sure you also select the audio and subtitle tracks you want. If you want to merge chapters, use Join titles and chapters function.
Step 3: Set AVI as the container. Choose Xvid, DivX, or H.264 for video and MP3 for audio. Trim, adjust bitrate, resolution, and frame rate as needed.
Step 4: Click Browse to select output directory, then start the job. Icepine encodes on the fly without large interim files.
Comparison of the Top 4 DVD to AVI Converters
Now that you have seen the steps for each method, the choice comes down to your specific constraints: do you need to handle complex DVD copy protections, or is a simple, free conversion for a home video sufficient? The table below breaks down the critical performance metrics to help you make that final decision.
| DVD to AVI Converter | DVDFab DVD Ripper | VLC Media Player | XMedia Recode | Icepine Free |
| Third-party Rating | 4.4/5 From Trustpilot | 4.5/5 From TechRadar | 4/5 (Tools) From TechRadar | N/A |
| Decryption for Legal Use | CSS, APS, RC, Sony DADC, and more | ❌ | ❌ | ❌ |
| GPU Acceleration | ✔️ | ❌ | ✔️ | ❌ |
| Input Formats | DVD disc/ISO/Folder | DVD disc/Folder/ISO | DVD disc/Folder | DVD disc/Folder |
| Output Formats | 1000+ video/audio | 10+ video/audio | AVI/MP4/MKV… | AVI |
| Preset Devices | 260+ | 10+ | Basic | ❌ |
| Video Editor | Yes | Basic | Basic | Basic |
Which Tool Should You Choose
- For Commercial DVDs: DVDFab DVD Ripper
It is the only DVD to AVI converter on the list that supports newly released encrypted discs. If a commercial DVD cannot be read by the free tools, DVDFab is a professional option for converting it to AVI.
- For Free Windows Conversion: XMedia Recode
It supports GPU acceleration on compatible systems and provides detailed AVI settings. However, it cannot handle copy-protected movies.
- For Cross-Platform Conversion: VLC Media Player
VLC works on macOS and Linux as well as Windows and can convert readable home DVDs without paid software. It lacks advanced editing features and built-in support for protected commercial DVDs.
- For Old Computers: Icepine Free DVD to AVI Converter
Designed for legacy machines such as Windows 7/XP systems. It converts on-the-fly without creating large temporary files, but it lacks updates and support for modern copy protections.
NOTE:
AVI playback depends on the codecs inside the container, not just the .avi extension. If an older player specifically supports DivX or Xvid, match the video and audio codecs to its manual. If the target phone or TV does not require AVI, converting the DVD to MP4 with H.264 and AAC is often a more compatible choice for current devices.
Is it legal to rip DVDs to AVI files?
Laws on copying DVD to digital and bypassing copy protection vary by country and region. Use these tools only for discs you own or have permission to copy, and follow the laws that apply where you live.
Why is there no sound in my converted AVI file?
This is a common issue when the AVI container holds an unsupported audio codec (like AAC, which old players cannot decode). Legacy AVI players usually require the audio track to be in MP3 or AC3 format. When using tools like VLC or DVDFab, select MP3 in the audio settings when required by the target player.
Can HandBrake convert a DVD directly to AVI?
No, HandBrake officially dropped AVI support starting from version 0.9.4. Modern versions of HandBrake only output MP4, MKV, and WebM formats. If you strictly need the AVI format for older hardware, we recommend using DVDFab DVD Ripper or XMedia Recode. We advise against downloading ancient versions of HandBrake from third-party sites as they may pose security risks.
Can I convert a DVD to AVI online?
Not directly from the DVD in your optical drive. Online converters can process uploaded files such as an extracted VOB file, but they do not directly read a DVD disc or protected DVD structure.
A dependable DVD to AVI result comes from two decisions: select a tool that can read the source, then choose codecs the playback device supports. DVDFab covers authorized commercial discs; VLC and XMedia Recode remain free choices for unprotected sources.
I would convert one chapter and play it on the target device before committing the full disc. For older DivX hardware, use Xvid or DivX video with MP3 or AC3 audio; for current devices, MP4 with H.264 and AAC is usually the cleaner choice.
