Rip DVD to MP4/MKV, or other digital formats with the best DVD ripper, so that you can save much space for your drawer. Converting DVD to digital also makes it easy to enjoy your favorite DVD videos and audio. Most importantly, contents in scratched DVDs can be transferred to mobile devices with the help of video rippers instead of being unreadable on a disc. Now, let's learn how to digitize a disc with the best DVD ripping software.
1. What Could A DVD Ripper Do?
A DVD Ripper is a software application that is used to rip the content of a copyrighted or protected DVD onto a hard disk or rip it to any video format. Here in this article, we are going to discuss the top 5 high-quality DVD ripper software available on the market. Have a look together and choose the best DVD ripper as your lifetime ripping tool.
2. Top 5 Best DVD Ripping Software 2023
Here is the best DVD ripping software 2023 recommended to help you with DVD to MP4, MKV, or AVI conversion. Of course, the exported DVD to digital formats are more than that. Learn the details about each of the best programs to rip DVDs and make a decision based on your operating systems and other demands.
(1) DVDFab DVD Ripper: Best Recommended
DVDFab DVD Ripper.
DVDFab DVD Ripper
Convert any DVD to any video & audio format in 5 minutes and get seamless playback on any device, media player or home theater.
Features:
  • Remove DVD Copy, VTS, and the newest protections
  • Support 8K/4K/H.265 conversion profiles and 260+ presets device
  • Hardware (GPU) Acceleration to quicken the DVD ripping process
  • Upscale video from DVDs to Blu-rays, from 480p to 1080p
  • Provides 30 days free trial for its full function
  • Build-in video editor makes your video outstanding
Win Download
100% safe&clean
Mac Download
100% safe&clean
In brief, it deserves the title of the best DVD conversion software to rip DVDs to digital files for mobile playback. Act right now to convert DVD to MP4 for playback on your mobile when in transit or on the tour!
(2) Aimersoft DVD Ripper
  • Available OS: Windows, Mac
  • Convert DVD to video formats
  • Extract DVD audio to MP3, M4A
  • Convert DVD to multiple devices
  • Rip home-made and encrypted DVD
  • Can’t rip DVD to ISO or folder
The best dvd ripper software
Aimersoft DVD ripper ranks 2nd in the top list of best DVD backup software. As one of the best DVD ripping software, it enables you to rip files from your DVD to any format which can be played on a mobile device or a gaming console. Usage of the application is simple and with very minimal options, which makes the DVD ripper a good choice for newbies. This DVD ripper also gives customization options for output as well as advanced settings.
That being said, the cons of this software is that it cannot direct rip raw DVD files as ISO or the video_TS folder. And it is not optimized for performance based on the hardware available. Also, the codec support is low. Installation is pretty simple, but as the trial version is not available, so you need to purchase it to try it. Still, it is worth giving it a try if all you need is to convert files from DVD into any compatible media format, to be used on any device.
(3) WinX DVD Ripper
  • Auto-Detect & Choose Hardware Accelerator
  • Edit video before ripping
  • Convert DVD to various video formats
Best software to convert DVDs
WinX DVD Ripper, as an efficient DVD ripper software in its class, has got a very huge library of customized output files. This DVD ripper is simple to operate, but it doesn’t offer a trial period. It does have a free version of the software, but the functions are limited as well. You can check for features before making a purchase. The installation and usage of this DVD ripper software are pretty simple like others, but it gives very limited options for customization in the output file.
As for advanced settings, it allows users to add subtitles, expand or crop video, but it lacks a very important aspect that it cannot add watermarks, and does not support contrast and brightness adjustments. Therefore, it is worth a try but the overall ratings for this software are medium, some people like it and some do not. Hope that our piece of information will help you in deciding the software you can go with. We have tried to cover every aspect and highlight only those points which are necessary for deciding. Ok, scroll down for the next best DVD ripper software.
(4) Wonderfox DVD Ripper
  • Decrypt and rip DVDs with copy protections
  • Fix your scratched DVDs
  • Add or remove subtitles
  • Hardware acceleration (Nvidia NVENC, CUDA).
  • 1:1 quick copy DVD to ISO image and DVD folder
Top dvd ripper software wonderfox
Wonderfox DVD Ripper is indeed marketed as free best DVD ripper software, but the free version has only limited functions to offer. If you’d like a full-function version, you could make a purchase after understanding the features of this DVD ripper software. It could achieve a fast speed in the DVD ripping process like 5 to 10 minutes while preserving the quality. The operation steps are quite simple as well, you load the DVD, select a custom setting, and click on convert, and that’s it. Pretty straightforward.
Also, among DVD ripper software, there is a trend to leverage the hardware such as the CPU, the GPU, or both in some cases. Wonderfox DVD Ripper is also capable of ripping protected videos, which is a sure-shot selling point in terms of popularity. The removable copy protections of this tool are CSS, DRM, RCE, Sony's proprietary ARccOS as well as Disney’s protection standards. Thus, you can be sure of ripping any DVD, yes, just about any DVD you can pick off the shelf of any store. However, there is also a point about repairing your scratched DVDs, which is not completely feasible since it is a hardware issue, but probably it tries to imply that it can rip DVDs with scratches as well.
(5) Leawo DVD Ripper
  • The instinctive UIs make it easy to use
  • Convert DVD to video/audio in 180+ popular formats
  • Convert DVD for multiple devices
  • Customize video with a built-in video editor and 3D movie creator
  • Select subtitles from source DVD for output
Top dvd ripper leawo
Leawo DVD Ripper is a valuable DVD ripper software that allows users to rip DVD to video in many video and audio formats including WMV, MP4, MKV, AVI, FLV, MP3, etc. You could also utilize it to rip videos and DVD movies to most compact devices like iPad, iPhone, PS4, Samsung Galaxy, Sony, etc. One thing to keep in mind is that this DVD ripper software works the best with Windows 10 OS.
Advertising as “Making home DVD movie enjoying anywhere anytime as you like”, this software has a built-in video editor that allows users to modify videos before ripping. You additionally can utilize it to make 3D films. The ripping procedure is might be a little bit slow according to customer feedback. Besides that, this DVD Ripper software can convert video and audio between various formats. Other user-friendly features include: set profile parameters, select subtitle output, and audio track, merge files into one, and so on.
3. How to Rip DVDs with Top-level DVD Ripper: DVDFab DVD Ripper
In this part, we would offer show you a simple guide on how to rip a DVD with DVDFab DVD Ripper. Let’s take a look together:
Step 1: Launch DVDFab DVD Ripper and Load the Source
Launch the software, and click the Ripper from the option bar, then insert the DVD disc you’d like to rip into the optical drive or click the “Add” button on the main UI if it is already in.
Rip dvd to videos
Note: if your DVD source is an ISO file or a folder, you can just simply drag and drop it into this best DVD ripper software.
Step 2: Choose Target Profile and Customize DVD
The second step is to choose one target profile. Move to the left panel and click the profile switcher to convert your DVD/folder/ISO to MP4, MKV, AVI, etc. Select the audio tracks and subtitles, and set the video and audio parameters regarding the output with the Advanced Settings. If you like, you can also customize your DVD video with the built-in video editor.
How to rip dvd to video formats
Step 3: Start the Ripping Process
Click the Start button, this best DVD ripper software will immediately begin ripping DVD, during this process, the DVD copy protections would be bypassed and removed. It would provide you with a detailed progress bar to keep track of the conversion.
Voila, 5 best DVD ripper software introduction finish here! Choose the most suitable one by yourself. Finally, we are gonna conclude this article with some FAQs that our users care about most.
FAQ 1: How Can I Rip Multiple DVDs at once?
Basically, you cannot do that with a DVD disc on your DVD drive. Even if your computer allows you to rip multiple DVDs at once, it is probably for your computer to crash due to overwork. That’s the reason for finding a great DVD ripper software to help you out. With good software, you could rip DVD fast and save a lot of time.
That being said, if the source is an ISO file or a DVD folder, you can do that if your computer has a strong CPU processor. For example, DVDFab DVD Ripper could make the ripping process 2X Faster with the VideoToolbox Hardware Acceleration function. That way you might try batch ripping with this strong DVD ripping tool.
FAQ 2: Could I Rip the Copy Protected DVDs with the Above-Mentioned DVD Ripper Software?
The answer is definitely a Yes, but not all of them. From the above 5 best DVD ripping programs, DVDFab DVD Ripper is the most powerful one to remove DVD copy protection, for your reference, almost all DRM protected DVD can be ripped and removed of copy protections in order to back up them, like CSS, Region Code, RCE, APS, UOPs, ARccOS Rip Guard, etc.
FAQ 3: Can I Upscale Those Old DVDs to Better Quality Using DVD Ripper Software?
Yes. You could achieve that with the development of AI. DVDFab DVD Ripper has integrated a new function that is backed by AI Super Resolution Technology to upscale old DVD to new Blu-ray standard, for example, you could enlarge the image resolution and quality to full HD from 480p, a very good choice to refreshing those old DVD collections. As for how to achieve it with the ripping function, please refer to this article: How to Rip DVD with AI.
