Beginners Guide On How To Screen Record On Chromebook
Summary: Learn how to screen record on Chromebook to strike the perfect blend of creativity and productivity and take your gaming and tutorials to the next level.
- • Upscale low-res videos into 720p/1080p/4k content
- • Enhance video clarity to a more realistic and vivid visual effect
- • Support video editing to meet your personalized demands
- • Get 50x faster speed with GPU acceleration
In the grand productivity race, Chromebooks have zoomed to the top, becoming the go-to companions for conquering your tasks with precision and speed. But here's the exciting twist: they've also snatched the spotlight as the ultimate choice for budding video creators, all thanks to their nifty built-in screen recording magic.
Imagine this – no need to summon third-party software to capture your screen escapades, whether creating a tutorial or embarking on an epic gaming quest. Continue reading to discover how to screen record on Chromebook.
How to Capture Your Chromebook Screen as a Video?
Are you planning to record your Chromebook activities? We have you covered with three built-in functionalities available for Chromebook users. Keep reading to learn about each method of how to screen record on chromebook:
Method 1: How to Record Your Chromebook Screen Using Shortcuts
Recording your Chromebook screen is easy with shortcuts. You can capture the whole screen, just a part, or a single window. Here's how:
Method 2: How to Screen Record on a Chromebook Using Screen Capture
If you don't like using shortcuts, you can still record your Chromebook screen with a tool called Screen Capture. This tool is built into Chrome-89 and later versions of Chromebooks and lets you take pictures and videos of what's on your screen. Here's how you do it:
Method 3: How to Record Screen on Chromebook with Audio?
If you're using Chrome OS 103 or newer, a nifty tool called Screencast can answer your query on how to screen record on chromebook with audio. It's meant mainly for students and teachers, but anyone can use it.
Besides recording your screen, you can add your voice, show your face through the webcam, draw on the screen, make written transcripts, and even translate things. But remember, it only works now if your Chromebook is set to English (US).
Let's see how to use Screencast to record your Chromebook screen:
How to Find Your Chromebook Screen Recordings?
When you make screen recordings on your Chromebook, they're saved by default in "Downloads". To find them, open the "Files" app from your launcher and choose "Downloads" on the sidebar.
If you like, you can change where your recordings go by making some settings changes. The recordings you make will be saved as ".webm" files. It's advisable to change them to ".mp4" for greater flexibility.
And if you're using the Screencast app, your recordings won't be on your Chromebook. They'll be up in the cloud, like a magical storage space. You can find and share them in the Screencast app by sharing the link.
Limitations Of Screen Recording On Chromebook
Regrettably, you can't edit video files using Gallery, Chromebook's photo viewer, and editor, unlike screenshots. Your optimal choice is to utilize an application like DVDFab Video Enhancer AI, which serves the dual functionality of screen recorders and video editors.
How to Improve Recorded Videos with DVDFab Video Enhancer AI
DVDFab Video Enhancer AI harnesses the power of artificial intelligence to transform dull, low-resolution videos into vibrant, high-quality masterpieces. Whether it's your cherished old home videos or classic movies that deserve a modern makeover, this tool brings them back to life. Keep reading to know how to add some glitz to the videos recorded using your built-in Chrombook screen recorder with DVDFab Video Enhancer AI.
Step-By-Step Guide On Video Enhancement With DVDFab Video Enhancer AI:
Launch Video Enhancer AI
The first step involves launching the tool and adding the video file you want to enhance.
Make customizations as needed
You can now make adjustments like denoise, enlarge, sharpen, and adjust other parameters before starting the video enhancement.
Complete the conversion
Upon completion of the video conversion, you can view the final results of video enhancement.
Just look at your Chromebook's version. You're good to go if it's 89 or a newer one. To check, go to Settings, About Chrome OS, and Additional Details.
Armed with the knowledge of how to screen record on Chromebook and insights for effective screen recording, you can now create captivating and enlightening videos primed for sharing with a global audience.
