How to Backup Best Crime Movies on Netflix with DVDFab DVD Copy?
Summary: If you love watching crime movies, then you're in for a treat. Netflix has some of the best crime movies that you can watch right now. From true crime documentaries to edge-of-your-seat thrillers, there's something for everyone. Here are top crime movies on Netflix that you can watch right now. Also, we'll show you how to backup your best crime movies on Netflix with DVDFab DVD Copy.
Crime movies are always a popular genre. They're suspenseful, thrilling, and can sometimes even be based on true events. If you're looking for a good crime movie and zombie movie on Netflix, then you're in luck. The streaming service has a great selection of both classic and new crime movies that you can enjoy. From true crime documentaries to edge-of-your-seat thrillers, there's something for everyone. And in this article, we'll be taking a look at the best crime movies on Netflix that you can watch right now. Not only this, but we will also show you how to backup your true crime movies on Netflix with DVDFab DVD Copy. So, if you're ready, let's get started.
DVDFab DVD Copy - Best Tool to Backup Crime Movies on Netflix
DVDFab DVD Copy is a great piece of software that allows you to make copies of your favorite downloaded crime movies from Netflix into DVDs and Blu-rays. It can easily make a 1:1 copy of your movie, including all the special features and menus and without any quality degradation. That way, you'll always have a copy of your favorite crime movies on hand, no matter where you are. Moreover, the copy will be compatible with most home media servers.
Not only this but it also helps to remove Cinavia protection using the DVDFab’s Cinavia Removal Solution. This will allow you to copy and backup your movies without any hassle. The best part is it has a very clean interface which makes it easy for anyone to use it. It supports five modes which are Main Movie, Full Disc, Merge, Customize and Clone/Burn. You can use any of these modes according to your need.
The main movie mode will allow you to select the main movie from the DVD and copy it to your computer. The full disc mode will backup the entire DVD, including all the special features and menus. The merge mode will allow you to combine multiple DVDs into one. The customize mode will let you choose which parts of the DVD you want to copy. And finally, the clone/burn mode will make an exact copy of the DVD, including all the special features and menus. It is available for both Windows and Mac. With its fast copy speed and high-quality output, DVDFab DVD Copy is the best tool to backup the best crime movies on Netflix by removing DVD copying protection.
How to Backup Crime Movies from Netflix with DVDFab DVD Copy?
Now that you know about the best tool to backup top crime movies on Netflix, let's take a look at how you can use it. DVDFab DVD Copy is very easy to use, even if you're a beginner. Just follow the steps below and you'll be able to backup your true crime movies on Netflix in no time at all.
1) Download and Installation:
First, you need to download DVDFab DVD Copy from the official website. Once it has downloaded, double-click on the setup file and follow the instructions to install it. Once it has been installed, launch DVDFab DVD Copy and select the "Copy" option from the main interface.
2) Choose the Source:
Next, you need to select the source of your DVD. You can either load the downloaded movie from your computer or directly drag and drop an ISO file into the software.
3) Select a Copy mode and Customize the Output DVD:
Now, you need to select a copy mode. As we mentioned before, there are five copy modes to choose from. Depending on your needs, you can choose any one of these modes. Once you have selected a copy mode, you can further customize the output DVD. For example, you can choose the audio tracks, subtitles, and even the aspect ratio.
4) Choose the Output:
Finally, you need to choose the output destination. You can either save the DVD to your computer or burn it directly to a blank DVD. If you're going to save it to your computer, then make sure to select the "DVD Folder" option. And if you're going to burn it to a DVD, then select the "ISO File" option.
5) Start the Copying Process:
Once you have configured all the settings, click on the "Start" button to begin the copying process. DVDFab DVD Copy will now backup your best crime movies on Netflix into DVDs or Blu-rays. Depending on the size of the movie, it might take a few minutes to complete the process.
5) Enjoy Your Movie:
Once the process is complete, you can now enjoy your best crime movies on Netflix. You can watch them offline, without any internet connection. You can also copy them to your home media server and stream them to your TV or other devices. Thanks to DVDFab DVD Copy, you'll always have a backup of your true crime movies on Netflix, just in case something happens to the original copy.
Top 15 Best Crime Movies on Netflix:
If you're a fan of the best crime drama movies on Netflix, then you're in luck. Netflix has a great selection of crime movies that you can watch. To help you out, we've compiled a list of the 15 out of 30 best crime movies on netflix. So, without further ado, let's take a look at the good crime movies on Netflix.
1. Cool Hand Luke (100%):
Probably one of the best crime movies of all time, Cool Hand Luke stars Paul Newman as a prisoner who refuses to conform to the rules of the prison. The movie is a classic and is considered one of the best films of all time.
2. Blue Ruin (96%):
A brutal, unforgiving revenge movie that will have you on the edge of your seat, Blue Ruin is one of the best films of the past few years.
3. GoodFellas (96%):
One of Martin Scorsese's best films, GoodFellas is the gangster film to end all gangster films. If you're looking for a crime movie that's both brutal and funny, then this is the one for you.
4. Taxi Driver (96%):
Another one of Martin Scorsese's best films, Taxi Driver is the story of a mentally unstable taxi driver who becomes obsessed with saving a young prostitute. This film is both disturbing and captivating, and it's definitely worth watching.
5. The Irishman (95%):
One of the best films of 2019, The Irishman is a gangster epic that spans several decades. This film is directed by Martin Scorsese and features an all-star cast, including Robert De Niro, Al Pacino, and Joe Pesci. If you're looking for a crime movie that's both violent and emotional, then this is the one for you.
6. Nightcrawler (95%):
A dark and disturbing film about a man who becomes obsessed with filming crime scenes for the local news, Nightcrawler is a must-watch. This film will keep you on the edge of your seat, and it's definitely not for the faint of heart.
7. See You Yesterday (95%):
A heart-wrenching and emotional film about two teenage inventors who build a time machine in order to save one of their brothers from being killed by the police, See You Yesterday is a must-watch. This film is both powerful and moving, and it will stay with you long after you've watched it.
8. Uncut Gems (92%):
A pulsating and intense crime thriller about a jeweler who becomes entangled in the world of organized crime, Uncut Gems is a must-watch. This film is directed by the Safdie Brothers, and it stars Adam Sandler in one of his best performances to date.
9. Good Time (92%):
A fast-paced and thrilling crime film about a man who goes on a desperate search for his brother after he's been arrested, Good Time is a must-watch. This film is directed by the Safdie Brothers, and it stars Robert Pattinson in one of his best performances to date.
10. The White Tiger (92%):
A gripping and harrowing tale about a man who rises from poverty to become a successful entrepreneur, The White Tiger is a must-watch. This film is based on the best-selling novel of the same name, and it's directed by Ramin Bahrani.
11. Enola Holmes (91%):
Based on the best-selling book series by Nancy Springer, this mystery follows the world's greatest detective's teen sister as she solves a case of her own.
12. El Camino: A Breaking Bad Movie (91%):
Aaron Paul returns as Jesse Pinkman in this "Breaking Bad" movie that picks up moments after the series finale.
13. 1922 (91%):
In this Stephen King adaptation, a man plots to kill his wife for her inheritance, but things start to unravel when she doesn't die as planned.
14. The Night Comes for Us (91%):
This Indonesian action movie follows a former hitman who is trying to start a new life, but gets pulled back into the world of crime.
15. The Departed (90%):
Martin Scorsese's Oscar-winning crime drama follows an undercover cop (Leonardo DiCaprio) and a criminal (Matt Damon) who are both working to take down the Irish mob in Boston.
Final Words
These are the best crime movies on Netflix. If you're looking for a good crime movie to watch, then any of these films would be a great choice. And if you want to backup the best crime drama movies on Netflix, you can try DVDFab DVD Copy software. It's a powerful tool that can help you backup your favorite movies with ease. So, what are you waiting for? Go ahead and give it a try!
