How to Burn a DVD from iMovie on Mac in 2026: Create a Playable DVD
Summary: iMovie can export your finished movie, but it cannot create a DVD-Video disc for a standard DVD player. Export the project as a high-quality local video file, then use DVD authoring software such as DVDFab DVD Creator or the free DVDStyler to create the disc. Finder is enough only when you want a data DVD that stores the video file rather than a playable movie DVD.
iMovie is free video editing software developed by Apple for macOS and iOS devices. It comes pre-installed on most Macs and iPhones, allowing users to easily import photos and clips, add titles, music, filters, and transitions, and quickly create high-quality home movies or short videos. iMovie can edit and export your movie, but it does not create DVD menus or write DVD-Video structures by itself.
This guide explains the practical workflow for the U.S. market: how to export an iMovie project, how to convert iMovie to DVD with DVDFab when you need a disc that can play on a home DVD player, and when the old iDVD method still applies.
Can You Burn a DVD Directly from iMovie?
No. iMovie can finish and export your video, but it does not author a DVD-Video disc for a standard DVD player. You need to export the movie first and then use DVD authoring software to create the DVD structure and write it to a disc.
Burning a video file to a DVD is not the same as creating a movie DVD. Finder can write an exported video file to a blank disc for storage, much like copying a file to another drive. A regular DVD player normally expects a DVD-Video structure with titles, playback information, and optional menus.
| What you want to do | What to use | Result |
| Store the exported iMovie video on a DVD | Finder | Data DVD containing the video file |
| Play the movie in a standard DVD player | DVD authoring software | DVD-Video disc |
| Use an older Mac that already has iDVD installed | iDVD | Legacy DVD-Video method |
If your Mac does not have a writable optical drive, connect an external DVD burner before the final disc-writing step. DVD-R is a common choice for home DVD players, but compatibility still depends on the burner, blank media, and target player.
How to Export an iMovie Project for DVD Burning
Step 1: Finish and Check Your iMovie Project
Open the project in iMovie and review the full timeline. Check the beginning and ending, titles, transitions, background music, voiceovers, and any clips you recently changed. The exported file should contain the exact version you want on the DVD.
Step 2: Export the Movie to a Local File
Choose File > Share > File. In the export window, keep both video and audio and choose the resolution, quality, and compression settings for the finished source file.
If the iMovie project is HD, you do not need to reduce it to DVD resolution before authoring. Export a clean source file first; the DVD authoring software will encode it for DVD-Video when the disc is created.
Click Next, choose a file name and destination, and save the movie somewhere easy to find.
Step 3: Check the Exported Video
Play the exported file in QuickTime Player before adding it to a DVD project. Check the audio, picture, titles, transitions, and final seconds of the movie.
If the exported file already has missing audio, incorrect edits, or synchronization problems, return to iMovie and export it again. Fixing the source first makes it easier to separate an iMovie export problem from a later DVD-authoring problem.
Choose a Way to Burn iMovie to DVD on Mac
Once the exported movie plays correctly, choose a DVD authoring method based on whether you want free software, a maintained commercial program, or access to an older iDVD installation.
| Method | Useful when | Free status | DVD menu |
| DVDFab DVD Creator | You want DVD disc, ISO, or folder output with advanced menu and playback settings | 30-day evaluation | Yes |
| DVDStyler | Free DVD authoring is your priority | Free and open source | Yes |
| iDVD | You already maintain an older Mac with iDVD installed | Legacy software | Yes |
If cost is the main concern, DVDStyler provides the DVD authoring functions needed for a basic movie disc. DVDFab DVD Creator provides disc, ISO, folder, menu, and playback options in the same application. If you only need to store the exported video file, neither program is required because Finder can create a data DVD.
How to Burn iMovie to DVD on Older Mac Using iDVD
iDVD is only relevant if you already have an older Mac where the application is installed and working. Apple discontinued iDVD years ago, and it should not be the starting point for a new Mac setup. macOS Catalina 10.15 and later no longer run 32-bit applications.
If you still maintain an older Mac with iDVD and a compatible DVD burner, you can use it as a legacy method. This is useful for restoring old projects, but it should not be the primary workflow for a new Mac setup.
Step 1: Export the iMovie Project
Export your iMovie project as a local video file first. Use the File sharing option in iMovie and save the finished movie to your Mac. Avoid editing the project further after export unless you plan to export a new file.
Step 2: Import the Video into iDVD
Open iDVD, create a new DVD project, and import the exported iMovie video. Choose a theme, adjust the menu text, and preview the DVD navigation before burning. Older iDVD workflows may also include direct iMovie integration, but this depends on the iMovie and iDVD versions installed on that Mac.
Step 3: Burn and Test the Disc
Insert a blank writable DVD into your computer or external burner, then use iDVD to burn a DVD on Mac. After burning, test the disc in a standalone DVD player if that is your target device. A disc that plays on the Mac is not always guaranteed to work on every older DVD player.
How to Burn iMovie to DVD with DVDFab DVD Creator
For newer Macs and Windows PCs, DVDFab DVD Creator provides a maintained way to convert exported iMovie videos into DVD, ISO, or folder output. It supports common video formats such as MP4, MOV, AVI, MKV, M2TS, and VOB, which makes it suitable when your iMovie project has already been exported as a normal video file.
The key benefit is that DVDFab DVD Creator performs DVD authoring, not just file burning. That means it can create a DVD structure with menus, subtitles, audio tracks, and disc output options for playback on DVD players or media software.
Features:
- Burn supported video files to a blank DVD or save them as an ISO or DVD folder
- Supports more than 200 video formats including AVI, MP4, MKV, M2TS, etc.
- Personalize DVD movies via free menu templates
- GPU acceleration on supported hardware
- Customize menu templates with your own style
- Use the built-in editor to crop, trim, adjust color, and add watermarks
Step 1: Open DVDFab DVD Creator and Add the Exported iMovie Video
Install and open DVDFab 13 on your Mac. Select Creator > DVD Creator, then click Add Source or drag the video exported from iMovie into the main window.
Free Download macOS 12 or newer
Step 2: Choose the DVD Size and Playback Settings
Open Advanced Settings. Choose DVD-5 or DVD-9 according to the blank disc you plan to use, then check the aspect ratio, TV standard, and playback mode.
NTSC is normally used for DVDs intended for the US, Canada, and Japan. PAL is common in many other regions. Match this setting to the DVD player and region where the disc will be used.
Step 3: Create or Skip a DVD Menu
Open Menu Settings if you want navigation on the disc. A menu is useful when the DVD contains several videos or when viewers need to select titles or chapters.
For one continuous home movie, keep the menu simple or choose a playback mode that starts the title directly. The main editing should already be finished in iMovie before this stage.
Step 4: Burn the Exported iMovie Video to DVD
Insert a writable DVD and select the optical drive in the Save to area when you want a physical disc. You can also select the folder icon to save a DVD folder or the image icon to create an ISO file.
Check the destination and click Start. After the job finishes, test a physical disc in the DVD player where you plan to watch it.
How to Burn iMovie to DVD for Free with DVDStyler
DVDStyler is a free, open-source DVD authoring program with a macOS installer. It can turn the video exported from iMovie into a DVD-Video project, add a menu when needed, preview the result, and write it to a blank disc.
Step 1: Create a New DVD Project
Open DVDStyler and choose Create a new project. Select 4.7 GB for a single-layer DVD or 8.5 GB for a dual-layer DVD.
Choose the video standard for the DVD player that will use the disc. DVDStyler recommends NTSC for North America and Japan and PAL for other regions.
Step 2: Add the Exported iMovie Video
Open the File Browser, locate the video exported from iMovie, and drag it into the Titleset Manager at the bottom of the window. Check the disc-space indicator before adding more videos.
Step 3: Set Up the DVD Menu
Select a menu template when creating the project, or edit the menu later by changing its background, text, and navigation buttons. For a simple single-movie DVD, you do not need an elaborate menu.
If you add buttons or multiple titles, check each button action before burning so it opens the intended video.
Step 4: Preview and Burn the DVD
Click the Burn button. Select Preview if you want to check the authored DVD before disc writing begins. Insert a blank DVD, select the correct optical drive, and click Start.
Test the finished disc in the DVD player you intend to use rather than relying only on playback on the Mac.
Why Your iMovie DVD Won't Play on a DVD Player
When a burned disc does not work, first identify whether the problem began with the iMovie export, the DVD authoring stage, or the physical disc.
| What you see | Likely cause | What to check | What to do |
| The disc contains only a normal video file | You created a data DVD instead of DVD-Video | Open the disc on your Mac and inspect its contents | Author the exported video as DVD-Video before burning it again |
| The exported movie already has missing audio or incorrect edits | The problem occurred before DVD authoring | Play the exported file in QuickTime Player | Correct the iMovie project and export a new file |
| The DVD works on a computer but not on the intended DVD player | The video standard, disc type, or player compatibility may differ | Check NTSC/PAL settings and test the disc in another player | Re-author the project with settings supported by the target player |
| The disc is not recognized after burning | The write may have failed or the player may not support that writable media | Check whether the Mac can read the finished disc and try another player or blank disc | Confirm the authored project first, then burn a new disc |
One quick check can rule out a common mistake: if the DVD only shows your exported video as an ordinary file, it is a data disc rather than a DVD-Video movie.
Can I burn a playable DVD from iMovie with Finder?
Finder can write the exported iMovie video to a disc as a file, but that creates a data DVD. To make a DVD-Video disc for a standard DVD player, export the movie from iMovie and use DVD authoring software.
Can I burn iMovie to DVD for free?
Yes. Export the finished movie from iMovie and use a free DVD authoring program such as DVDStyler. You still need a writable DVD drive and blank media if you want a physical disc.
What export settings should I use before burning iMovie to DVD?
Export a clean video-and-audio file at a quality suitable for the finished project. If the project is HD, you can keep the HD source and let the DVD authoring software create the lower-resolution DVD-Video output later.
Is iDVD still available for current Macs?
iDVD is a legacy application and is not a current solution for modern macOS. If you already maintain an older Mac where iDVD is installed and working, you can still use that setup; otherwise, use maintained DVD authoring software.
Do I need an external DVD burner for my Mac?
You need a writable optical drive to create a physical DVD. If your Mac does not have one, connect an external DVD burner before starting the disc-writing step.
To burn a DVD from iMovie on a current Mac, finish the edit in iMovie and export the movie as a local video file first. Check that file before authoring so an export problem is not carried into the DVD. Although iDVD was formerly a native solution, its discontinuation renders it an unstable choice. A dependable alternative with advanced capabilities like menu design and subtitle support is provided by DVDFab DVD Creator. It's a smart choice for turning iMovie projects into playable DVDs.
![5 Top AVI to DVD Converters for Windows and Mac [2026]](https://images.dvdfab.cn/artifact/2026/10/19/HsCx2t8W3VyD6wHfogzkhte4XqgpBqdz/feature_cover.jpg)
![Convert Video to DVD: 5 Free & Paid Video to DVD Converters [2026]](https://images.dvdfab.cn/media/convert_vidoe_to_dvd_dza0f3.png/public)
