What is a DVD Drive? Definition, Functions and Types Explained
Summary: Choosing between an internal, external, or virtual DVD drive depends on how much desk space you have and whether your laptop still has a disc slot at all. This guide compares read speeds across drive types, flags the reliability signals worth checking before buying an external unit, and walks through the Device Manager and power-setting fixes that resolve most drives that stop responding.
Most laptops sold in the US today skip the disc slot entirely, yet a DVD drive is still what you reach for to play an old movie, install software that never got a digital release, or pull files off a disc that predates cloud storage. This guide explains the DVD drive definition, what a CD/DVD drive can read or write, which drive type fits your setup, and what to try when a drive stops responding.
A DVD drive is an optical device that reads DVDs and usually CDs. A DVD-ROM drive reads discs; a DVD writer also records data to compatible blank discs. A CD-ROM drive reads CDs, not DVDs, and a standard DVD drive does not read Blu-ray discs.
From a technical point of view, a DVD drive uses laser beams and electromagnetic wave technology to read data on DVD discs or, on writer models, record data, acting as a bridge between physical optical discs and a computer's digital system.
A typical USB DVD drive needs a host computer and suitable playback software, while a standalone DVD player sends video directly to a TV or monitor. Plugging a computer drive into an ordinary USB port on a TV does not turn it into a standalone player.
A DVD drive works as an input device when reading discs and, if it is a writer model, as an output device when burning them. As an input device, it reads the pits and lands on the disc and converts them into digital signals the computer can process. As an output device, it uses a high-power laser to change the chemical properties of the disc's dye layer, permanently recording digital files onto the disc.
So even as computer manufacturers phase out built-in optical drives, a DVD drive remains a practical tool for playing physical movies, installing older software, and reading cold data backups stored on disc.
How Does a DVD Drive Work?
In simple terms, an optical drive works in four steps: emit a laser, focus it on the disc, capture the reflected light, then decode the result into data.
Laser Beam Technology
A DVD drive is a type of optical disc drive. Different types of optical disc drives use lasers with different wavelengths; the shorter the wavelength, the narrower the beam and the higher the data density that can be read. In terms of laser wavelength and disc data density, DVD falls between CD and Blu-ray.
| Drive Type | Laser Wavelength | Laser Color | Data Density | Typical Disc Capacity |
| CD drive | About 780 nm | Infrared | Lower density; wider track spacing | About 700 MB |
| DVD drive | 650 nm | Red | Higher density; tighter track spacing | About 4.7 GB for a single layer |
| Blu-ray drive | 405 nm | Blue-violet | Highest density; tightest track spacing | About 25 GB for a single layer |
The surface of a DVD contains tiny pits and lands that reflect the laser differently as the disc spins. The drive's sensor detects those reflected-light changes and decodes them into the movies or files stored on the disc.
DVD Drive Reading Speed
The 8x, 16x, or 24x printed on a DVD drive's box is an advertised maximum data transfer rating for the drive and compatible media.
In the DVD standard, 1x (single speed) is defined as 1.385 MB/s, roughly the minimum speed needed to play a standard DVD movie.
- 8x = 11.08 MB/s
- 16x = 22.16 MB/s
- 24x = 33.24 MB/s
Actual burn time depends on the drive, the recordable media, and the size and settings of the job.
Different Types of DVD Drives
Not all DVD drives are the same. When choosing or using a drive, it helps to look at it from two angles: connection type (physical form) and supported formats (functionality).
Internal DVD Drives
Internal DVD drives are installed directly inside the computer case and connected to the motherboard. They connect directly to the motherboard, but actual read and write performance still depends on the drive model and disc media. Unlike external drives, they are not portable.
Desktop Internal Drives:
- This is the most traditional form of optical drive, installed in the 5.25-inch drive bay at the front of a desktop case. They connect to the motherboard via a SATA interface. Their larger chassis can provide more room for the drive mechanism and cooling, while supported read and write speeds depend on the model and compatible media.
Laptop Internal Drives:
- Also known as slimline drives, these ultra-thin drives are built to fit the limited space inside a laptop, usually only 9.5 mm or 12.7 mm thick. As laptop makers keep chasing thinner designs, this type of drive is now mostly limited to certain rugged or business laptops rather than mainstream models.
- Don't take up additional desk space.
- Uses a direct motherboard connection.
- Comparatively harder to install.
- Cannot be easily switched between multiple computers.
- Limited to desktop PCs and a shrinking number of laptop models.
External DVD Drives
External DVD drives connect to a computer through USB and provide access to compatible discs when the computer has no internal optical drive. An external drive is worth considering for a laptop without a disc slot, and choosing the best DVD drive for ripping means matching the connector, power supply, operating-system support, and manufacturer's supported-disc list to your computer and discs.
A DVD-only drive cannot read Blu-ray discs through a firmware update. Blu-ray playback requires Blu-ray-capable hardware, while UHD use requires compatible UHD hardware and firmware.
External DVD drives usually offer USB connectivity with USB Type-A or USB Type-C ports, so choose a connector supported by your computer.
- USB Connectivity: An external DVD drive is typically a slim optical drive enclosed in a case and connected through a USB cable.
- USB Type-A: The traditional rectangular connector found on many desktop PCs and older laptops.
- USB Type-C: A smaller reversible connector used by many newer laptops and Mac computers.
- Easy to install and use.
- Provides access to data on compatible optical discs.
- Can be moved between compatible computers.
- Takes up physical desk space while in use.
- May need additional power during demanding operations.
- Connection quality depends on the cable, port, and power supply.
Supported Formats (ROM vs. RW vs. RAM)
Aside from the physical form, the labels printed on the front panel of an optical drive determine what it can do. Typically, you will see labels such as DVD-ROM, DVD-RAM, and DVD-RW/+RW, each indicating slightly different capabilities.
- DVD-ROM Drive (DVD Reader): As mentioned earlier, this type of drive can only read data from DVDs and CDs; it cannot burn discs. It is mainly used for installing software, watching movies, or playing older disc-based games.
- DVD-RW/DVD+RW (DVD Writer/Burner): This is currently the most common type. It can not only read data, but also write data to supported DVD formats, including DVD-R or DVD+R blank discs (write-once) and DVD-RW or DVD+RW discs, which can be erased and rewritten multiple times. Most modern drives are labeled "DVD Multi Recorder" and support both DVD- and DVD+ formats.
- DVD-RAM: This is an older format, but excellent in terms of data reliability. A DVD-RAM disc can access data randomly like a hard drive, and it has a very long lifespan, making it suitable for long-term archiving. It is not very common today, but higher-end drives still support reading this format.
DVD Virtual Drives
When you search for "DVD drive" or "what is a DVD drive," you may come across something that looks like a drive but cannot be touched in the real world: the virtual drive.
A virtual DVD drive is not physical hardware; it is a drive simulated by software. In the "This PC" folder on your computer, it looks exactly like a real DVD drive icon and even has a drive letter, such as G:. It uses software algorithms to make the operating system treat it as if a physical drive were connected.
DVDFab Virtual Drive is a virtual Blu-ray/DVD emulator that can emulate up to 18 drives and mount supported DVD and Blu-ray images. A virtual drive works with an existing disc image; it cannot read a physical disc or create a backup from one without compatible optical hardware and copying software.
- Requires no physical drive bay or external drive enclosure.
- No risk of DVD physical damage.
- Simulates multiple DVD drives on a single computer to suit specific scenarios.
- Mounts supported disc images without inserting physical media.
- Unable to read physical discs.
- Need time to get familiar with operation process.
What to Do With DVD Drive Not Working?
A drive that stops responding is annoying, but it is rarely a reason to throw it out right away. Work through the troubleshooting steps below first. If the problem looks physical, a technician can also take a look at your external CD/DVD drive or your laptop's built-in drive.
Reasons for Your DVD Drive Not Working
There are usually three categories behind a drive that will not read a disc. Check each one before assuming the drive itself is dead.
- Drive issues: hardware failure, outdated firmware, dust on the laser lens, or a loose connection.
- Disc issues: a scratched or damaged disc, a format mismatch, such as trying to play or burn a Blu-ray disc in a standard DVD drive, or copy protection that blocks reading.
- Software issues: no playback software installed that supports the disc or file type.
Check the problem in three stages: whether the computer detects the drive, whether the drive reads a compatible disc, and whether playback software can open the movie.
- Restart the computer, reconnect the USB or SATA cable, and check that the drive receives enough power and supports the host computer's operating system.
- Check Windows Device Manager or the Mac system hardware information for the optical drive. An internal drive may also be identified from the computer's case, specifications, or model documentation.
- If the drive is detected, test a clean disc that matches its supported formats. A standard DVD drive cannot read a Blu-ray disc.
- If the drive reads data discs but a movie will not open, install playback software that supports the disc type and its video format.
- If none of the above helps and the drive is several years old, worn laser optics are a common failure point that no driver or setting change will fix.
For playback software issues, one option built specifically for disc, ISO, and folder playback is PlayerFab.
PlayerFab supports physical DVD/Blu-ray/UHD discs, as well as ISO image files or DVD folders. Physical discs still require compatible optical hardware, while a virtual drive works with supported image files rather than physical media.
- PlayerFab is an option for disc, ISO image, and DVD folder playback.
- Use it when playback, rather than backup, is the task.
- A physical drive is still needed to read a physical disc.
- For a local DVD backup, use the backup workflow below.
Tip: Copy Data before Your DVD Drives Stop Working
It is always a sensible move to plan for a rainy day. For content you are authorized to access, where permitted by platform terms and applicable law, making a local backup can preserve access before the hardware fails. DVDFab DVD Copy is one backup option for this situation.
DVDFab DVD Copy can copy a protected DVD disc to an ISO image or folder and store it on your hard drive for later playback, or save it onto another disc. DVD-9 to DVD-9, DVD-5 to DVD-5, and Clone/Burn support 1:1 copying; DVD-9 to DVD-5 uses compression. The official download includes a 30-day trial that can fully process up to three DVDs. A physical disc output requires a compatible DVD writer and matching blank media. It also processes backup jobs through a task queue.
DVD backups with DVDFab DVD Copy
Step 1: Download and launch DVDFab Software
Free Download macOS 12 or newer
Step 2: Load the DVD Source
Click the "Copy" button, then insert the DVD you want to back up into your computer's optical drive. Click "Add" to load the DVD source. If the source is an ISO file, you can load it by drag and drop instead.
Step 3: Choosing a Copy Mode and Customizing the Output DVD
Select a copy mode from the six available options. Once you have picked a mode, you can customize the output DVD further, such as choosing which audio tracks, subtitles, and chapters to include. Choose a DVD disc, ISO image, or VIDEO_TS folder as the output; physical disc output requires compatible writing hardware and blank media. DVDFab DVD Copy can also synchronize title, cast, and cover metadata and generate an .nfo file.
Step 4: Click "Start" to Begin Copying Your DVD
Keep the backup for personal, noncommercial use, do not redistribute copied content, and follow applicable law and relevant terms.
FAQs about DVD Drive
Are DVD drives obsolete?
No, DVD drives are not obsolete, though they are far less common than they used to be. USB flash drives, cloud storage, and streaming have all cut into the reasons people used to reach for a disc drive every day. Even so, a DVD drive remains the most direct way to play a DVD movie without ripping or converting it first, and plenty of people keep one around for exactly that reason.
What is the difference between an optical drive and a DVD drive?
A DVD drive and an optical drive are not really two different things; a DVD drive is one type of optical drive. "Optical" refers to using light, specifically a laser, as the reading mechanism, and CD, DVD, and Blu-ray drives all work this way. A drive that also reads Blu-ray discs can handle shorter laser wavelengths than a standard one, which is why it can read higher-density discs.
Are external DVD drives good?
Yes, an external DVD drive is a practical option when your computer has no built-in disc slot. Before buying, check the connector, power requirements, operating-system support, and the manufacturer's list of supported discs. USB connectivity alone does not determine performance; the drive model and media rating also matter.
Can I still buy a laptop with a DVD drive?
It has gotten harder. Most mainstream and premium laptops dropped the built-in drive years ago to save space and battery room, and that trend has not reversed. A handful of bulkier budget or business laptops still ship with one, but they are now the exception rather than the rule. If you cannot find a model with a slot built in, pairing a compatible laptop with an external USB DVD drive covers the same need without waiting on a specific laptop line to stock one.
How do I choose a reliable external DVD drive?
Choose a drive with the connector and power requirements your computer can support, then check the manufacturer's operating-system and supported-disc lists. A DVD-only drive cannot read Blu-ray discs through a firmware update; Blu-ray playback requires Blu-ray-capable hardware, and UHD use requires compatible UHD hardware and firmware.
What is a CD/DVD drive?
A CD/DVD drive is optical hardware that reads CDs and DVDs. A DVD-ROM model reads supported discs, while a DVD writer can also record data to compatible blank media; a CD-ROM drive reads CDs but not DVDs.
Virtual DVD drives have not replaced the physical kind. Internal, external, and virtual drives remain distinct options, each suited to a different setup. An internal drive fits a desktop with room to spare, an external drive covers laptops and ultrabooks without a disc slot, and a virtual drive works well when you are dealing with ISO files rather than physical media. Whichever type you rely on, backing up important discs with software such as DVDFab DVD Copy can preserve access if aging drive hardware later stops working.
![11 Best ISO Creators to Create ISO File on Windows & Mac [2026 Updated]](https://images.dvdfab.cn/artifact/2026/10/09/DVxGGdRFZrckamUXZ3-uk9NfbC6bsZr3/feature_cover.jpg)
