How to Convert DVD to MP3? Check 5 Free DVD to MP3 Converters in 2026!
Summary: If you're passionate about a song in a DVD movie and want to convert DVD to MP3, there are several ways to do this using desktop or online free DVD to MP3 converters. Let's learn about each program to help you rip DVD audio to MP3 with ease.
Want movie soundtracks on your phone so you can listen on the go in high quality? You need a reliable and easy DVD to MP3 converter. I compared several free methods and wrote a step-by-step guide on how to convert DVD to MP3 right on your computer. It includes a side-by-side look at five popular free DVD to MP3 rippers. Now, pick a method that fits your setup and grow your music library.
Convert DVD to MP3 with DVDFab DVD Ripper
DVDFab DVD Ripper is one of the best free DVD to MP3 converters that can rip any encrypted DVD. It supports over 1000 video and audio formats, including WAV, OGG, MP4, MKV, AVI, and MP3. Extracted audio supports up to 7.1 channels. The software also caters to audiophiles by allowing them to extract hi-fi audio from DVDs such as Flac Multi-channel, Flac Stereo, Way Multi-channel, and Way Stereo.
Furthermore, it allows for easy customization, resulting in truly personalized audio experiences. With this converter, you can effortlessly convert your DVD collection to MP3 files and listen to your favorite movie soundtracks, dialogues, and commentary without using a DVD player.
💻Available on: Windows 11/10/8.1/8/7 & macOS 10.13 - 15.x
Key Features:
- Keep updating to support the latest released protected DVDs.
- Digitize DVD collection, ISOs, or folders to multiple audio formats.
- Rip DVDs to lossless Hi-Fi audio with 24-bit detailing and up to 192 kHz.
- Offer advanced settings and video editor for you to customize the output audio file.
- 50x faster DVD audio ripping speed with GPU acceleration.
- Support batch DVD to audio conversion.
How to Rip DVD Audio to MP3 with DVDFab DVD Ripper
Step 1: Run DVDFab DVD Ripper and load source DVDs
Download and install DVDFab DVD Ripper on your Windows or Mac. Launch this DVD to MP3 converter and select the "Ripper" module. Then insert your DVD disc or load your ISO file or folder using the "+" icon.
Step2: Select MP3 as the profile and customize output audio
Click "Choose Other Profile" to access the video and audio profile library. Here you can click "Audio" to select "MP3" format. You can also select "Hi-Fi Audio" format to enjoy high-fidelity audio.
Then, return to the main screen and adjust the output audio file to your liking. For example, clicking "Advanced Settings" allows you to configure audio characteristics such as codec, sample rate, channels, bit rate, and loudness. You can also customize the output name, chapters, audio tracks, and subtitles.
Tips: The "Video Edit" option will be available when you convert your DVD to MP4 or other video formats. You can add text or an image to your video, adjust its video properties, playback speed, crop it, or trim it. So, if you only want to rip a portion of the DVD to audio, you can choose a video format first, then proceed to the video editing interface and trim the film as desired. Finally, select "MP3" as the output format to extract the desired DVD audio clip.
Step 3: Start to rip DVD to MP3
Set an output destination from "Save to" according to your requirements. Finally, click the "Start" button for DVD to MP3 conversion, and the DVD audio ripping process will be clearly displayed.
Convert DVD to MP3 Free with VLC
VLC is known not only for its media playback abilities, but also as a DVD audio ripper, capable of converting DVDs into a variety of audio formats such as MP3, OGG (Vorbis), FLAC, and CD. The software supports a variety of audio codecs, including MPEG Audio and MPEG 4 Audio (AAC). Nonetheless, it is worth mentioning that the conversion procedure may cause some level of quality reduction.
💻Available on: Windows, Mac, GNU/Linux, Android, etc.
Key Features:
- VLC is not only a media player but also a converter, recorder, and DVD audio extractor.
- It supports various audio codecs and covers multiple file formats including MP3, OGG, FLAC, etc.
Cons:
- VLC is unable to rip a copy-protected DVD.
- Using VLC requires some technical knowledge.
- VLC does not include advanced audio or video editing tools.
- May cause some loss in audio or video quality.
How to Convert DVD to MP3 with VLC Media Player
Step 1: Open VLC on your Windows PC. Click "Media" in the upper-right corner and choose "Open Disc". Check the box for "No disc menus".
Step 2: Click the ▼ icon near "Play" in the lower-right corner. Choose "Convert ALT+O", and tap "Profile" > "Audio MP3" in the new panel.
Step 3: Click the button of "Browse" and input anything in "File name". Set an output directory by clicking "Save".
Convert DVD to MP3 with Apowersoft Converter Studio
Apowersoft Converter Studio (RecCloud) is a DVD to MP3 converter. You can load a DVD disc or load folder to import .VOB files and convert them to phone-friendly MP3 tracks with one click.
However, there are drawbacks. After Apowersoft Converter Studio was upgraded to RecCloud, it states that the original versatile format-conversion features remain, but in our tests the only output format is MP3. It also accepts .VOB as the only input type, and you can't trim clips or use extras like vocal enhancement. Apowersoft previously offered an online DVD to MP3 converter called Free Online Video Converter, but it no longer supports online DVD-to-MP3 ripping. Also note that this DVD to MP3 converter does not handle DVDs with copyright protection.
Key Features:
- A professional video converter which can rip DVD to MP3.
- Product line upgraded to RecCloud, adding AI tools and expanded workflows.
Cons:
- No built-in decryption for copy-protected DVDs (expects accessible files like VOB/VIDEO_TS).
- Not compatible for Mac and Linux.
- Limited output formats.
How to Rip DVD to MP3 with Apowersoft Converter Studio/RecCloud
Step 1: Open Apowersoft Converter Studio and go to the “Video Editor” section. Choose “Extract Audio” before you insert the DVD into the optical drive. To add .VOB files from your VIDEO_TS folder, click the folder icon or drag and drop the files into the panel.
Step 2: After uploading, click the "gear" icon in the upper-right corner to choose a destination directory, then click "Export" to rip DVD to MP3. You will see a progress bar that shows the current status. When it finishes, open the output folder to find the .mp3 files.
Convert DVD Audio to MP3 with HandBrake
HandBrake is a complimentary open-source tool that can transform DVDs to MP4, MKV, and WebM formats. While it's not specifically designed as a DVD-to-MP3 converter, it can still be utilized for this purpose. You can use this best DVD ripper for Plex to convert your DVD to MP4 format which includes all audio tracks and then convert MP4 to MP3 with VLC.
💻Available on: Win, Mac, and Linux
Key Features:
- It is a cross-platform video converter.
- Convert DVD to MKV, MP4, and WebM.
- Allows users to customize audio quality parameters.
- Support to compress, convert, and edit DVD videos.
Cons:
- Doesn't support MP3 output directly; requires a second tool to extract audio.
- Only some encrypted DVDs are supported even with libdvdcss installed.
How to Convert DVDs to MP3 Files with HandBrake+VLC
Step 1: Insert the DVD into your PC's optical drive and open HandBrake. In the source chooser, select your DVD drive to load the disc. If your content is already on your computer, you can also choose "File" or "Folder" to open a VIDEO_TS folder or ISO image.
Step 2: After the disc source finishes loading, go to the "Summary" tab and set "Format" to MP4. In the "Audio" tab, choose your output quality by adjusting the codec, bitrate, and mixdown settings as needed. Then click "Browse" to choose an output folder, and click "Start Encode" to convert videos to MP4.
Step 3: Now switch to VLC. Play the MP4 file in VLC media player by "Media/File" > "Convert/Save" > "File" > "Add". Click "Convert/Save" button > "Profile" to convert MP4 to MP3. Finally, set audio directory and click the button of "Start" to convert DVD to MP3. If you are using MAC to rip DVD to MP3, uncheck the "Video" box instead.
Convert DVD to MP3 via ZamZar
ZamZar is an online DVD to MP3 converter you can use for DVD audio conversion. Head to its official website and open your files > choose the output audio format as MP3 > input your E-mail > start the conversion process. It is very easy to use. However, compared with desktop software, online tools have inherent drawbacks. ZamZar cannot directly rip audio from physical DVDs, and it cannot rip DRM-protected VOB files. Furthermore, the free version limits each conversion to a maximum file size of 150 MB.
To rip DVDs to MP3 with ZamZar, you must first extract the VOB files, which is not possible with protected DVDs without the use of an additional DVD ripper. Furthermore, it has limitations on conversion speed and file size, necessitating a robust internet connection and ensuring that the DVD VOB file does not exceed the permitted size.
Key Features:
- 100% web-based DVD to MP3 converter.
- Very simple to use.
- Supports multiple output formats such as MP3, AAC, WAV, etc.
Cons:
- Works with uploaded files only (not physical discs) and doesn't handle DRM-protected DVD.
- Free tier size limit 50 MB.
How to Convert DVD (VOB) to MP3 Files with ZamZar
Step 1: On your computer, copy the DVD's contents to a folder so you have the standard VIDEO_TS structure. You'll be uploading one or more .VOB files (these hold the audio/video). Online services, including Zamzar, only convert VOB files, not physical DVDs.
Step 2: Go to Zamzar's VOB to MP3 converter page. Click "Choose Files" (or drag and drop) and select the VOB you want. Zamzar explicitly supports converting VOB files in DVD folders to MP3.
Step 3: Make sure MP3 is selected as the target format, then click "Convert Now" to start the job. When the conversion finishes, download the .mp3 file from the results page.
Comparison of 5 Free DVD to MP3 Converters
Below is a side-by-side table comparing 5 best free DVD to MP3 converters that can suits your needs to rip MP3 music from DVDs without any hassle.
| DVD to MP3 Converter | Platforms | Input formats | Remove copy-protection | Audio outputs |
| DVDFab DVD Ripper | Windows, macOS | Disc / VIDEO_TS / ISO | Yes | MP3, AAC, M4A, FLAC, WAV, OGG, AC-3/E-AC-3, DTS, more |
| VLC | Windows, macOS, Linux | Disc / VIDEO_TS / ISO | No | MP3, OGG, FLAC |
| HandBrake+ VLC | Windows, macOS, Linux | Disc / VIDEO_TS / ISO | No | MP3, OGG, FLAC |
| Apowersoft Converter Studio (RecCloud) | Windows | VIDEO_TS and VOB files from DVD | No | MP3 |
| Zamzar (Web) | Browser | VOB from DVD | No | MP3, AAC, WAV, etc. |
Yes, you can create an MP3 DVD. All you need is a DVD burner and the appropriate software. Burning MP3 to DVD is the same technique as burning CDs. However, bear in mind that not all DVD players handle MP3 files, so make sure the device you intend to use for playback is suitable.
This blog recommended best free DVD to MP3 converters, available both offline and online. You can choose your preferred option to convert DVD to MP3. Overall, DVDFab DVD Ripper software is highly recommended by our team among these programs after testing. It is the only one that can rip encrypted DVDs and has different output presets for audio codec, video codec, and playback devices.
![How to Convert DVD to USB for TV/Car Playback [2026 Guide]](https://r2.dvdfab.cn/upload/resource/en/convert-dvd-to-usb-ISbr.jpg)
![How to Convert DVD to MP4: 14 Tools Tested & Guide [2026]](https://r3.dvdfab.cn/upload/resource/convert-dvd-to-mp4-p2X3.jpeg)
