How to Convert Movie Maker Files to MP4
Summary: Want to learn how to convert Windows Movie Maker to MP4 fast and easily? Here are methods and detailed guide steps.
Windows Movie Maker is an editing software that used to come pre-installed with older versions of Windows. Microsoft discontinued support for the software a few years ago, however, it’s still possible to find the software online and install it even on newer operating systems like Windows 10. The problem with this software is that it is only capable of one type of file output known as Windows Media Video or .wmv for short. This type of file has its uses but you’ll be able to get a lot more out of it if you convert Movie Maker to MP4 or one of the other widely used video formats.
Want to learn how to convert Windows Movie Maker to MP4 fast and easily? Well, you definitely came to the right place. There are actually a few different methods that allow you to do just that and today we’re going to take a look at the most popular ones. Each method has its advantages when trying to convert Movie Maker to MP4 so pick the one that’s most suitable to your needs.
1. Premium Video Converter
If you want to convert Movie Maker to MP4 like a pro there’s no better solution than DVDFab Video Converter. The reason for that is because with this software you can convert multiple videos at a time and even merge them together if needed. What’s more, the conversion process is very fast and you can use the built-in advanced editing tools to access a wide variety of customization options. DVDFab Video Converter offers a 30-day free trial so you can check all these features and many more without spending a penny.
Not only can you expect excellent quality on the output file when you convert Windows Movie Maker to MP4 but you can also play the file on any number of devices. One of the disadvantages of .wmv files is that they only work on certain platforms. When you learn how to convert Movie Maker to MP4 with DVDFab Video Converter this won’t be a problem anymore because MP4 files run on pretty much anything. Now that you have an idea about what to expect let’s take a look at a step-by-step guide that will teach you how to convert Movie Maker to MP4.
Step 1. Launch DVDFab and select the Converter option from the primary menu at the top. Next, click the “+” in the window that appears or simply drag the Movie Maker file you want to this location. After the file has been selected you can click the profile switcher in the upper left corner to select the desired format and the type of device you want the file to play on. Note that DVDFab Video Converter supports batch conversion so feel free to add additional files from the button next to the profile switcher.
Step 2. Once one or more files have been added you can now start to customize them using the little buttons found to the right of the file (in the same bar). Click the second button to access the Advanced Settings to modify things like resolution, encoding method, video quality, frame rate and more. Once you’re happy with your choice, click the button next to Advanced Settings to access the Video Editing tools. Here is where you can trim, crop or change the aspect ratio of the video. And if you want to add subtitles or a watermark this is the place to do it.
Step 3. Once you’re done editing and customizing the file it’s time to pick a destination folder. To do this simply select the folder icon at the bottom of the screen and then pick a suitable location for the output file. All done? Great. Now it’s time to convert Movie Maker to MP4. Do this by clicking the green Start button in the lower right corner of the screen and then wait until the conversion is complete. This process usually only takes a few minutes but it all depends on how fast your machine is.
2. Free Video Converters
You can also convert Movie Maker to MP4 using free software. These programs are usually either slower or lack the advanced features found in premium video converters, however, they can still get the job done if all you’re looking for is a simple conversion. We’re going to use HandBrake for this example since it’s one of the most popular ones but there are many similar video converters available online. How to find the right transcription tools for precise transcription from audio to text? There are so many options.
Step 1. Open Handbrake and select File to open a single video file or Folder for batch conversion.
Step 2. Look for Format in the Summary section of the preview window and then select MP4.
Step 3. Next to Summary there are a number of other categories such as Dimensions, Filters, Video, Audio and Subtitles. Click on each of these categories to make any necessary modifications to the output file.
Step 4. Click the Browse button in the lower right corner to select the destination folder and then pick a name for the file. Finally, Convert Movie Maker to MP4 by clicking the Start Encode button found at the top of the screen.
3. Online Video Converters
If you don’t want to download any software you can also convert Windows Movie Maker to MP4 by using an online conversion tool. You’ll need a reliable internet connection for this method and there aren’t many formats to choose from but it does allow you to convert Movie Maker to MP4. We’re going to use Online Convert for this example.
Step 1. Go to the website and select Choose File to upload the video you want to convert. You can also select files found on your Dropbox or Google Drive.
Step 2. Scroll down a bit to find the Optional Settings. There’s not a lot to work with but you can find a few basic editing options here so make sure to use them if necessary.
Step 3. Click the Convert Now button and wait until the process is complete. It’s worth noting that only files up to 100 MB in size can be converted for free.
Step 4. Once the file is ready you will receive a link. Click this link in order to download the new file.
