How to Convert Video to Audio? Solved!
Summary: This article covers the conversion of videos to audio, and why you should use the DVDFab Converter. The article also deals with the salient features of the software and includes a detailed user guide.
How to convert video to audio is a question that is asked by thousands of people from across the globe every day. This question usually pops up when people are watching their favorite music videos on the internet, and they want to save the video on their phones as an audio file so that they can play it anywhere, and anytime.
Although it is not that difficult, a lot of people are unable to find the answer to the question of “how to convert a video to audio?” If you are also asking yourself the same question, then this article is meant specially for you. It is so because, in this article, we are going to answer your query about “how to convert video into audio” once, and for all.
We will tell you everything you need to know about “how to convert video to audio”, and if you stay with this article till the end, you will be able to convert videos to audio yourself by just clicking a few buttons. Additionally, we will also tell you how to convert video to audio on iPhones, and how to convert a YouTube video into an audio file.
So without any further ados, let us jump straight into the article, and see how converting video to audio actually works.
Use DVDFab Video Converter to Convert Video to Audio
If you have a basic understanding of computers, you must be knowing that video and audio files have their respective file formats. If you want to know how to convert a video to an audio file, you will have to first know about some special softwares that goes by the name of “Video Converters.”
These video converters are special softwares that are capable of converting the file formats of video files to audio files. In simple words, if you have a video that you want to convert into an audio file, you will have to use the “Video Converter” softwares.
What is the DVDFab Video Converter?
DVDFab Video Converter is one of the best downloadable softwares on the internet that allows you to convert videos into any format of your choice including audio in a simple, yet interesting way. You can use the DVDFab Video Converter to change the format of your existing videos or convert it into videos of higher resolution including 1080p, 2K, 4K, 5K, and 8K.
A major reason why the DVDFab Video Converter is so popular is that it has a really simple & easy to use interface. Thanks to this easy-to-use interface, even beginners, who have prior experience in video conversion or editing can use the DVDFab Video Converter without any trouble. However, the software is also recommended for experienced professionals because it offers a whole lot of features that would help you create stunning professional projects.
How to Convert Video into Audio using DVDFab Video Converter: User Guidance
Now that we have discussed what is the DVDFab Video Converter, let us have a look at how to convert video to audio using this video converter software. You can use the DVDFab Video Converter to convert the format of your favorite videos from MP4, AVI, MKV, and more to common audio formats like MP3, and more. Following is the detailed user guide on how to convert a video file to an audio file using the DVDFab Video Converter if you are using a Windows PC.
Step #1: Download the Software
Before you can start using the DVDFab Video Converter to convert video into audio files, you need to download the software on your device. Although there are multiple sources on the internet from where you can download the DVDFab Video Converter software, the easiest & safest way to download the software is directly from the official website.
Spot the “Free Download” option, and hit it. The website would automatically detect your Windows version, and download the setup file of the software which is compatible with your currency system.
Step #2: Install the Setup File
Once you have downloaded the setup file, it's time to install the setup file. All you need to do is click on the “Setup” file, and wait for the installation process to begin. Click on the “Install Now” option, and wait for the installation process to complete.
Step #3: Launch the DVDFab Video Converter Application
Once the application is successfully installed on your device, and you have launched it, you will see a window that looks like the following.
Step #4: Adding Files from the Device
Spot the “Converter” option present on the top bar, and click on this option. To add the files saved locally on your PC, you can either click on the “+” icon present at the center of the page, or you can click on the “Add from Local” option.
Step #5: Selecting the Files
Once you have clicked on the “Add file” option, a window would appear that would ask you to select the files that you want to convert. Browse the files from your computer, and click on the “Add” option. Once done, click on the “OK/Done” option.
Step #6: Select the Conversion/Output Options
Once you have added the file, you will have to specify the output parameters or quality of the video that you want to convert.
Adjust the settings as per your requirements, and once done, click on the “OK” option present on the top-right corner of the window.
Step #7: Conversion Process
After you clicked on the “OK” button, the software would start the preparation process for converting the file for you. You need to click on the “Start” option present in the top-right corner of the page to initiate the conversion process.
Step #8: Confirm the Conversion Process
The DVDFab Video Converter would ask you for one last confirmation. If you are willing to initiate the conversion process, click on the “Confirm/Start” option, and the application will finally start the video to the audio conversion process. Alternatively, if you want the conversion process to begin after some time, you can click on the “Schedule Conversion or Continue Later” option.
Main Features
There are hundreds of video converters that allow you to convert videos to audio on the internet. But why should you skip all of them, and opt for the DVDFab Video Converter? Well, one of the main reasons why the DVDFab Video Converter is one of the best video converters on the planet is primarily because of the vast number of features it offers. Some of the main features offered by the software are:
- Ease of Usability
The DVDFab Video Converter has one of the simplest user interfaces, which makes it a really easy-to-use software. What this means is that even if you are a beginner, you can use this software with the same ease as a video editing professional.
- Powerful yet less demanding
The DVDFab Video Converter is an extremely powerful video converter, and it will take care of your video processing, no matter how tough they are. However, this does not mean that you need a high-end PC to use the DVDFab Video Converter software, as it can be installed on a PC with not so attractive specifications, and work just fine.
- Multiple Conversion Options
Although you might want a video editor solely for converting video to audio, there is no harm if you have additional conversion options available. The DVDFab Video Converter offers multiple videos and audio conversion features that might be of great help to you in the future.
- Multimedia Editing Toolbox
If you have converted videos to audio before, you might be aware that there are situations when you have to make some edits to the videos before or after you have converted them. This is where the Multimedia Editing Toolbox feature of the DVDFab Video Converter comes into play, as it allows you to edit your videos as per your requirements.
Final Thoughts
In this article, we have told you everything you need to know about the DVDFab Video Converter, and some of the major reasons why you should prefer it over other alternatives available in the market. The DVDFab Video Converter is one of the most powerful, and simple to use video converters that can be used by anyone, and everyone ranging from amateurs to professionals. Additionally, we have also included a proper detailed video guide, that tells you the step-by-step process to use the DVDFab Video Converter to convert videos to audio with ease.
