Convert M4A to WAV with the Best Solution
Summary: This article covers the conversion of videos from M4A to WAV format, and why you should use the DVDFab Converter. The article also deals with the salient features of the software, and how to use it.
Do you want to convert the format of some of your videos from M4A to WAV, but you are finding this task to be difficult? If yes, then you are not alone, because converting video formats is a task that sounds easier than done.
I am saying so primarily because there are hundreds of software in the market that claim themselves to be the best video converter. They offer different functionalities, support different formats, and carry different price tags. The market space is full of such software, and you can get confused easily if you have no prior experience with video editing or video converting software. Additionally, there is plenty of free software, and websites that claim to convert M4A to WAV, and vice versa.
Audacity and DVDFab Video Converter are some of the best software/converting tools that allow you to convert M4A to WAV and convert WAV to M4A online without any troubles.
In this article, we are going to tell you everything that you need to know about the DVDFab Video Converter. If you are planning to invest your hard-earned money in this software, then you cannot skip this article. Additionally, we will also answer common queries like how to convert M4A to WAV using the DVDFab Video Converter. So please stay with us till the end.
Use DVDFab Video Converter to Convert WAV to M4A
If you are just starting with video editing or if you are looking for easy use, and cost-effective video converting software, then you should have a look at the DVDFab Video Converter. It is one of the most popular video converters in the market currently, and many experts find its M4A to WAV conversion feature to be the best in the business.
The DVDFab Video Converter is a must-have tool for video editors and content creators. DVDFab Video Converter is a 3 in 1 video editing tool that not only allows you to convert the format of videos, but it also helps you in producing creative videos and editing them as per your requirements.
The DVDFab Video Converter eliminates the need for you to purchase multiple software for creating, editing, and converting your videos. This tool not only saves you a lot of money, but it also saves a lot of time and boosts your productivity multiple folds.
How to Use DVDFab to Convert M4A to WAV?
Before you can use the DVDFab Video Converter to convert video formats, you first need to download the software and register for the same. You can download the DVDFab Video Converter using this link. You get a free trial period for the paid version, so you do not have to pay straight away to use this software. Once you have downloaded the software and registered yourself on the platform, you should follow these steps to convert your video formats.
Step 1: Open the DVDFab Video Converter. Once opened, you would see the following interface. Spot the Converter option present on the top menu of the software, and click it.
Step 2: Next click on the “Add from Local” option, or click on the giant “plus” icon located on the center of the page. This would then redirect you to your device’s internal storage from where you will have to choose the files that you want to convert.
Step 3: Once you have selected the file, the DVDFab Video Converter would load the file. Wait for a few seconds for the file to load successfully. Once loaded, you will something like this:
Step 4: You would get the details of the uploaded video. The software would then ask you to select the output file format. Change the settings as per your requirements. You can switch between Mobile and Theater modes using the toggle present on the bottom-left corner of the window. Once you have changed the settings as per your needs, click on the “OK” button.
Step 5: Once you have clicked on the “OK” button, the software would start preparing the video for conversion. Once done, you would see a window that looks like this. Click on the “Start” button on the bottom-right corner of the page to start the conversion.
Step 6: The DVDFab Converter would then ask your for a confirmation whether you want to proceed with the conversion or not. If you are ready to go ahead, click on the “Continue” button. Alternatively, you can also select the “Continue Later” option if you want to schedule the conversion for sometime later.
Step 7: If you click on the Continue button, the conversion would start, and you would see the details of the task. Once the download has been completed, you can save the video at your desired location.
DVDFab Video Converter: Main Features
DVDFab Video Converter offers a lot of features that make it one of the best video editing software in the market. Let’s have a look at the main features offered by the DVDFab Video Converter:
Easy to Use
The DVDFab Video Converter is one of the easiest to use video editing software. Even if you have no prior experience of using video converters and video editors, you would not have a lot of difficulties in using the DVDFab Video Converter. All you need to do is use these features once or twice, and you would get an understanding of how things work.
Powerful Video Editor
The DVDFab Video Converter is an extremely powerful video editor, and it is well suited for professional requirements. You can work even on the most complex projects, to create captivating videos.
Various types of conversions
The DVDFab Video Converter supports more than 28 video formats, and you can convert your videos from any one of these formats to another. Additionally, you can also convert your videos to audio, and tweak it as per your requirements.
Plenty of customizing options
The DVDFab Video Converter has support for more than 100 filters, and you can choose any one of them as per your requirements. You can change the speed of the videos clips, and blend pictures, audio, & videos to create stunning projects that can draw the attention of the masses. If you have a creative mind, then the sky’s the limit when you are using the DVDFab Video Converter.
Multimedia Editing Toolbox
Creating videos is not enough because there are occasions when you need to edit videos as well, and the multimedia editing toolbox offered by DVDFab Video Converter is one of the best in the industry. There are more than 20 different operating tools that allow you to edit your videos and audio files as per your requirements.
For starters, you can crop, trim, and flip your videos without breaking a sweat. If you want to add subtitles to your videos, there is a dedicated tool for the same that would help you complete this task with ease. Creating and merging audio files is no longer an issue. You can also add watermarks to your creation to give it that final professional touch.
Great Conversion Speeds
Time is one of our biggest assets and you can afford to waste it. The DVDFab Video Converter is a powerful video converter that allows you to convert your videos at blazing fast speeds so that you can easily meet your project deadlines.
System Compatibility
Compatibility is another plus point of the DVDFab Video Converter as it supports all major Windows versions including Windows 7/8/10/11. Additionally, you can also use this software on a wide array of portable devices including Apple, Samsung, SanDisk, HTC, Huawei, LG, Sony, Amazon, Blackberry, and more.
DVDFab Video Converter: Variants
The DVDFab Video Converter is offered in two variants: Standard and Pro variants. Let us discuss them one by one.
Video Converter Standard
The Standard variant as the name suggests is the base variant, and it offers its users basic features like converting video & audio formats and basic editing. The Standard variant supports video resolution output of up to 8K and a Multi-Channel audio output channel.
The Standard variant is best suited for beginners who have just started editing videos. The Standard variant is good for editing videos for your personal use. The Standard variant also supports hardware acceleration, and to purchase the Standard variant, you need to spend $ 29.99.
Video Converter Pro
If you are a professional, or if you are really serious about video editing, then it is the Pro variant that you should be interested in. The Pro variant supports all the features offered by the Standard variant, and adds much more to the list. In addition to converting video formats, you can convert videos to images using the Pro variant.
You can denoise, de-shake, and deinterlace your videos for better quality. You can add text, watermark, and timestamps for that professional touch. You can add customized video effects that make your videos much more interesting. There are hundreds of filters to choose from that would add a unique look to your files. There is plenty of royalty-free music and video clips to choose from so that your video does not become a victim of copyright.
Final Thoughts
Converting videos from M4A to WAV or from one format to another might not seem to be extremely difficult. However, if you have the right tools, then converting video formats can be an extremely easy affair, and all you need is a few clicks.
In this article, I have discussed how you can use the DVDFab Video Converter to help you convert videos from M4A to WAV format. If you have any queries, or if you are facing any troubles with the video conversion process, do let me know. I would try my best to help you out with your troubles and queries.
Frequently Asked Questions
Is DVDFab Video Converter free?
No, the DVDFab Video Converter is not free but you do get a 30-day trial version period. During these 30 days, you can use the DVDFab Video Converter for free. However, once the trial period is over, you will have to pay if you want to continue using the software.
Is DVDFab safe to download?
Yes, DVDFab is safe to download only when it is downloaded from the official website of DVDFab. It is not recommended to use a third-party website or application to download DVDFab as they might be infected with malware.
How do I use the DVDFab video converter?
If you want to use DVDFab’s video conversion feature, all you need to do is follow the steps we have mentioned in this article.
Is M4A the same as WAV?
Although both M4A and WAV are extensions for audio files, they are not the same. WAV is an audio file format that has been created by Microsoft and IBM whereas Apple created the M4A format to save audio files.
