Top 2 MOV to MP3 Converter
Summary: There are plenty of MOV to MP3 converters online, and there are plenty of MOV to MP3 converter free softwares as well. Which is the best one? This article will provide detailed reviews.
DVDFab Video Converter: Best Choice to Convert MOV to MP3
As the name suggests, the DVDFab Video Converter is software that converts the format of your video from one format to another format. The DVDFab Video Converter is one of the most popular, and widely used video converter softwares out there, and there are good reasons behind the same.
The DVDFab Video Converter is one of the most full-featured video converter softwares on the planet primarily because it supports over 100 different video formats, and your video must support one of them.
In addition to letting you convert videos from a higher resolution to a lower resolution, the DVDFab Video Converter allows you to do the exact opposite as well. You can also up the quality of your current video by up to 300%, a feature that is offered by limited video converter softwares. For example, you can convert a 480p video to a 1080p video, and you can also convert a 1080p video to up to 4K resolution without losing any quality of the video file.
How to Use the DVDFab MOV to MP3 Video Converter?
One of the first things that you would notice when you start using the DVDFab Video Converter software is its easy-to-use interface. This allows almost anyone to use the software like a pro, even when they have never used it before.
However, in case you are experiencing any troubles, you can follow this detailed user guide that tells you about the step-by-step process you need to follow for your file conversions.
Step #1: Download the Software
Head on to the official website of the DVDFab Video Converter software for downloading the setup file. Although you can use multiple other sites to download the content as well, it is recommended that you use the official website itself. It is so because the setup files on the official website are genuine and free from any malicious or infectious files.
Once you open the website, you will see a homepage that looks similar to the one shown below.
Now, you need to select whether you want to download the DVDFab Video Converter software for Windows or a macOS. Once you have selected it, you need to hit the “Download” button. The website would automatically scan your system, and select the best version of the software that would pair with your system the best.
You will be redirected to a website, and your download would then begin shortly.
Step #2: Install the Software
After you have successfully downloaded the setup file, locate it in the internal storage of your device, and double click on it to enter the installation process. Grant the permission that the package installer asks for, and proceed ahead. Read the terms & conditions if you wish, and then hit on “I Agree”, and then press the “Next” button.
The package installer would take care of the rest for you. As soon as the installation process ends, you will notice that a desktop icon has already appeared for the DVDFab Video Converter software.
Once you see this icon, you can either launch the application directly, or reboot your device, and then launch the application. Once the application is launched, follow the next step.
Step #3: Choose the Converter Profile
After you have launched the application, locate the “Converter” option present on the menu at the top. Once you have done that, you need to add the files stored on your local storage.
Now, there are two methods by which you can add files to the DVDFab Video Converter software. You can either press the huge plus icon that is present at the center of the page, or you can click the “Add from Local” option. Regardless of which method you choose, you will be redirected to your device’s internal storage.
Here you need to select the file or files that you want to change the format of. Once you have selected the files, just click on the “Add” button, and the files would then be added to the software, and you can proceed ahead with the conversion process.
Step #4: Make the Preparations
Once you have added the file, you need to make the final tweaks before you can start converting the video file. In this step, you need to decide points like which format do you want to convert your video file into. Scroll through all the supported video formats, and select the one that you want to use for your video file.
Once you have selected the file format, a new Window would load up that would look like the one shown below.
If you just want to get your video converted from MOV to MP3, it is best you stick with regular settings. It is so because these settings work well with most files, and if you do not have proper knowledge of video editing, it is better if you stick to default settings. However, if you are a professional, or if you want to tweak some settings, you can opt for the “Advanced Settings” or “Editor” option.
If you opt for the additional settings, you can make changes to the bit rate, the video rate, the quality, and more. If you opt for the “Editor” option, you can make changes to the video in terms of adding music, cutting or cropping the file, and more.
Step #5: Start the Conversion Process
Once you have changed the settings as per your own preferences, and you are ready to begin the conversion process, click on the “Start” option present in the bottom-right corner of the page. Conversely, if you want to get done with the conversion process, you can click on the “Inverted Arrow” option, located right next to “Start”, and select the option that suits you the best.
Step #6: Saved the Converted File
Once the software finishes the conversion task, it will display the message to you successfully on the screen. Now all you need to do is save the file at your preferred location and hit the Save button. That’s all.
Best MOV to MP3 Converter Software: Other Alternatives
We have already seen why the DVDFab Video Converter is one of the best MOV to MP3 Converter softwares in the market currently. But what if you are looking for some other software for some reason? Are there other softwares that are as good as DVDFab Video Converter when it comes to converting MOV files to MP3 files? Yes, there are plenty of video converters just like the DVDFab Video Converter, and some of them are the best in the business as well. Following are some of the other best MOV to MP3 Converter softwares:
HD Video Converter Deluxe
The HD Video Converter Deluxe is an extremely popular video conversion softwares, and a lot of people believe it to be one of the best video converter softwares of them all. The HD Video Converter Deluxe software can be used to convert video files in multiple formats, and even in MP3 files if the need arises for the same.
The HD Video Converter is available for download on both Windows, and macOS devices, and you can download the setup file that suits your requirements the best. One of the major benefits of using the HD Video Converter Deluxe is the fact that it is highly versatile software. You can use the HD Video Converter software to work with video files for media playback on smartphones, action cameras, professional DSLR cameras, Drone, Camera recorders, and more.
The HD Video Converter Deluxe software claims that if you use the software, you can compress the original file to up to 90% of the original size, without losing out on quality. Additionally, you can use the HD Video Converter Deluxe software to save audio, and video files from more than 1,000 different websites. The exhaustive features list of the WinX HD Video Converter software makes it one of the best MOV to MP3 converter softwares on the internet currently.
Final Thoughts
MOV to Mp3 conversion is a task that seems way more difficult than it really is. Gone are the days when you needed the help of a professional to help you with your video conversion requirements. These days, all you need is video conversion software, and you can convert your favorite video files with just the click of a few buttons.
The DVDFab Video Converter is one of the best video conversion softwares available on the internet currently. It offers its users an exhaustive list of features, and has a clean & simple to use interface. In case you are finding it difficult to use the application, we have also included a detailed user guide that guides you with a step-by-step process on how to use the application.
