What is Bitrate and Why is Everyone Talking About It 2023
Summary: Is a high Bitrate always better? Read on to find the answers and know what is bitrate and its effect on video quality in this post.
- • Upscale low-res videos into 720p/1080p/4k content
- • Enhance video clarity to a more realistic and vivid visual effect
- • Support video editing to meet your personalized demands
- • Get 50x faster speed with GPU acceleration
Introduction
Have you ever needed help with your YouTube videos while watching them on a slow internet connection? The low resolution might result in a blocky or pixelated video quality blocking your enjoyable video-viewing experience while streaming an HD video can still be somehow manageable.
While the bandwidth plays a crucial role, do you know even bit rate varies depending upon your internet connection to provide you with improved image quality and pixels? So if you have ever encountered the term 'bitrate' while exporting your videos, here's a complete guide to understanding it better.
This article will help you learn what is bitrate and its relationship with video quality. You'll also be in for methods to measure video bit rates and bit rates needed for YouTube videos and live streaming. So stay tuned with us and get started to enhance your video-viewing experience.
What is Bitrate
In simple terms, since bits are data units that compile a piece of digital content, like images or videos, bit rates refer to the number of bits your PC can process within a certain amount of time. So it is the number of bits processed per second, denoted by bit/s, and is used to measure the amount of data your PC can handle at a given time.
They are typically used to determine file size, video quality, and streaming performance for online videos. For example, you can measure a file size easily by the formula, File Size = bit rate (kilobits per second) x duration. Moreover, bit rates help you measure the file upload/download speed or the internet speed.
What is the Effect of Bitrate on Video Quality
Bit rates can affect your video quality in several ways. Besides being a vital measure of any video file size, it also affects video quality. For example, the higher the video bit rates, the higher, more prominent, and more detailed your video quality is, and vice-versa.
However, you must be careful as once the video resolution goes up, even the bit rates tend to rise, processing higher data. So using an extremely high bit rate can result in wasted bandwidth by straining your hardware resulting in stutters.
Measurement of Video Bitrates
Generally, video bit rates are measured in kilobits per second (Kbps) or megabits per second (Mbps). To measure the video bit rates, consider the frame rates taken every second and the frame size. The higher the video quality, the higher the number of images you'll need to process each second, resulting in a higher bit rate.
You must also remember that when you measure the bit rates, these measurements are for the raw data, not the compressed files like MP4 or AVI that use compression algorithms to reduce the file size before encoding.
Video Bitrates for YouTube Videos
The recommended video bit rates for setting YouTube videos can be put into two standards: SDR uploads and HDR uploads.
SDR and HDR Uploads:
Video Resolution |
Video Bitrate: Standard Frame Rate |
Video Bitrate: High Frame Rate |
2160p |
SDR: 35 - 45 Mbps HDR: 44 - 56 Mbps |
SDR: 53 - 68 Mbps HDR: 66 - 85 Mbps |
1440p |
SDR: 16 Mbps HDR: 20 Mbps |
SDR: 24 Mbps HDR: 30 Mbps |
1080p |
SDR: 8 Mbps HDR: 10 Mbps |
SDR: 12 Mbps HDR: 15 Mbps |
720p |
SDR: 5 Mbps HDR: 6.5 Mbps |
SDR: 7.5 Mbps HDR: 9.5 Mbps |
480p |
SDR: 2.5 Mbps HDR: Unavailable |
SDR: 4 Mbps HDR: N/A |
360p |
SDR: 1 Mbps HDR: Unavailable |
SDR: 1.5 Mbps HDR: N/A |
How to Set a Good Video Bitrate for Streaming
For steady streaming of your videos, you must match your video resolutions with a suitable video bit rate. Setting a good video bit rate for streaming your treasured videos on YouTube, FaceBook, and other channels can be challenging. However, here's a quick guide to help you with the process.
Video Resolution |
Bitrates |
Regular HD videos with a standard resolution |
Set bit rate between 2,500 to 4,000 kbps |
Full HD videos with a standard resolution |
Set bit rate between 3,500 to 5,000 kbps |
Regular HD videos with high resolution |
Full HD videos with high resolution |
Set bit rate between 4,500 to 6,000 kbps |
Video Bitrates to Use for OBS (Open Broadcasting Software)
With the help of OBS, video-makers can capture and record videos and live streaming seamlessly. Generally, the video viewers select the video resolution compatible with the device and their data affordability. In addition, you can use the OBS video bit rates below to set your video resolutions.
Video Quality |
Video Resolution |
Video Bitrate |
Low |
480p x 270p |
400 kbps |
Medium |
640p x 360p |
800 to 1200 kbps |
High |
960p x 540p or 854p x 480p |
1200 to 1500 kbps |
High-Definition (HD) |
1280p x 720p |
1500 to 4000 kbps |
HD 1080 |
1920p x 1080p |
4000 to 8000 kbps |
4k UHD |
3840p x 2160p |
8000 to 14000 kbps |
To stream videos on Twitch, you can choose an OBS video bit rate between 450 kbps to 6000 kbps. As a thumb rule, if your bandwidth exceeds 2 Mbps, you must use at least 6500 kbps. However, if it doesn't go beyond 1 Mbps, consider using 3000 kbps.
So after thoroughly knowing video bit rates and their supreme goodness in enhancing your image quality, you must not hold back on streaming video content for complete enjoyment.
Instead, you can rely on a photo and video enhancing tool like the DVDFab Enlarger AI to upscale your videos using the AI-powered solution. So let's explore this fantastic video upscaling answer to learn its functioning and features.
DVDFab Enlarger AI: AI-Powered Video Upscaling Solution
DVDFab Enlarger AI uses super-resolution technology to better AI upscale your video. It is a complete deep-learning video enhancing solution to enrich your video-viewing experience from a standard definition (480p SD) resolution to high definition (1080p HD blu-ray standard) quality and up (4k UHD).
Using the DVDFab Enlarger AI, you can enlarge the video images by 300% and add great details to improve video quality mountingly. Besides increasing resolution, it supports multiple graphic cards, providing video sharpness and enhanced quality.
But that's not it. Check out its other exciting features to amplify and upgrade your video-viewing experience.
Notable Highlights
- Upscales the quality of old videos from SD (480p) to Full HD (1080p Blu-ray standard) or from 1080p to 4K.
- Enlarges your videos by 300% with AI-powered enhancing their clarity exponentially
- AI upscales the video image with excellent details to present true colors
- Works great with DVD Ripper, Blu-ray Ripper, Video Converter, and DVD to Blu-ray Converter
- Availability of fours quality output options
- Applies intelligent deep learning technologies like NVIDIA, TensorFlow, OpenVINO, NVIDIA CUDA, cuDNN, and AMD
- Hardware acceleration for better conversion efficiency
- Available on Windows PCs
How to Upscale Your Videos Using DVDFab Enlarger AI?
To upscale your DVD discs, ISO files, or folders, you can use DVDFab Enlarger AI in some simple and quick steps as mentioned below
Step 1: Download and install the software
First, launch the DVDFab 12 and select the Copy Module, then switch to the Blu-Ray option at the backup mode panel in the left corner.
Step 2: Load the DVD disc and upscale your file
Next, load your DVD disc, ISO file, or folder that you need to upscale and check mark the Enlarger AI option box that is located behind the wrench icon at the screen's center.
Step 3: Begin the video conversion process
Finally, click the Start button to trigger the upscale conversion process smoothly.
Final Verdict
So since now you know the power of bit rates, you must not hold back or compromise on your video-watching experience. So we have already provided you with a comprehensive guide on what is bitrate, how it affects your video quality, and how you can measure it.
If you are seeking for a powerful and robust video enhancer tool, DVDFab Enlarger AI can be your best-chosen solution to upscale your ISO files, folders, and DVD discs. It is a beginner-friendly way to improve your video's sharpness and upscaling quality.
