You've probably seen DVDs on store shelves or in old media libraries, but have you ever stopped to ask: what exactly is a DVD? A DVD is an optical format designed to hold far more data than its predecessor, the CD (Compact Disc). While DVDs once dominated home entertainment, streaming services now carry much of that load. If you still own a DVD collection, it's wise to think about backing it up and protecting it. In this article I'll walk through what a DVD is, how it differs from a CD, and how you can back up even protected discs to keep your media safe for years to come.
What Is a DVD? Types, Capacity, and Backup Options
What is a DVD?
A DVD (Digital Versatile Disc, also commonly called Digital Video Disc) is a 12 cm optical disc format for storing digital video, software, and computer data. A standard single-layer DVD holds about 4.7GB, while a dual-layer DVD holds about 8.5GB. It looks similar to a CD, but it stores data more densely, so it can carry full-length DVD-Video content and larger files.
DVD data is stored as microscopic pits and lands arranged in a spiral track inside clear polycarbonate plastic. A red laser in a DVD player or drive reads those marks and converts them back into video, audio, files, or software instructions. The most important limitation is that a DVD needs DVD-capable hardware, such as a DVD drive; a CD player cannot read a DVD.
DVD factQuick answer
Full nameDigital Versatile Disc; Digital Video Disc is also commonly used.
Physical format12 cm optical disc; Mini DVD uses an 8 cm disc.
Common capacityAbout 4.7GB on a single-layer disc and about 8.5GB on a dual-layer disc.
Common usesDVD-Video movies, software installation, data storage, offline playback, and personal archives.
Playback requirementA DVD player, DVD recorder, game console with DVD support, or computer DVD drive.
Key limitationLower capacity and typical video resolution than Blu-ray; not readable by CD-only players.
DVDs became common because they offered far more space than CDs without changing the familiar disc shape. Understanding what a DVD is helps you choose an authorized DVD backup that preserves either the full disc structure or the content you want to play.
CD, DVD, and Blu-ray: Key Differences
What is a DVD:The Difference Between a CD and a DVD?
Once you understand what DVD stands for, the difference between CD, DVD, and Blu-ray becomes easier to see. All three are optical discs, but they use different data densities, laser technology, capacity levels, and playback hardware.
FeatureCDDVDBlu-ray
CapacityAbout 700 MB4.7GB single-layer; 8.5GB dual-layer25GB single-layer; 50GB dual-layer
Main useAudio and small filesMovies, software, and backupsHD video, games, and large files
Video roleNot a standard movie formatStandard-definition DVD-VideoHD video; UHD Blu-ray is separate
LaserInfrared, commonly 780 nmRed, commonly 650 nmBlue-violet, commonly 405 nm
File structureAudio CD, MP3, WAV, ISOMPEG-2, VOB, ISO, VIDEO_TSBDMV, M2TS, high-bitrate video
Playback hardwareCD player or computer driveDVD player or DVD driveBlu-ray player or Blu-ray drive
A DVD is not simply a larger CD. It uses tighter tracks and different reading requirements, which is why CD-only players cannot play DVD movies. A Blu-ray disc goes further with higher capacity and higher typical video resolution, but it also needs Blu-ray-capable hardware. Among the three, DVD occupies the middle ground between CD capacity and Blu-ray capacity.
Overview of DVD Types and Their Uses
DVDs are available in several formats. The letters used in DVD formats matter because they tell you whether the disc is factory-pressed, recordable once, rewritable, dual-layer, or intended for a more specialized device.
DVD TypeDescriptionTypical Uses
DVD-ROM (Read-Only Memory)Pre-recorded discs produced by manufacturers. The data cannot be changed or erased by the user.Commercial movies, video games, software releases, and reference discs.
DVD-R (Recordable)Write-once disc. After burning, the content cannot be erased or rewritten.Personal archives, home videos, and data that should not be changed later.
DVD+R (Recordable)Write-once disc using the +R recording standard. Compatibility depends on the burner, player, disc quality, and book type settings.Home video projects, data storage, and playback in compatible DVD players.
DVD-RW (Rewritable)Can be erased and re-recorded multiple times in compatible drives.Temporary backups, repeated testing, and draft media projects.
DVD+RW (Rewritable)Rewritable version of the + format, designed for multiple write and erase cycles.Projects that need frequent file updates or repeated disc reuse.
DVD-R DL (Dual Layer Recordable)Write-once DVD-R disc with two recording layers, increasing capacity to about 8.5GB.Longer videos, larger folders, and archives that exceed single-layer capacity.
DVD+R DL (Dual Layer Recordable)Write-once DVD+R disc with two layers and about 8.5GB of capacity. Playback support still depends on the target device.Long-form video and larger data backups for compatible players and drives.
DVD-RAM (Random Access Memory)Random read/write DVD format used in compatible drives and some recorders, with stronger error management than common recordable DVDs.Professional video recording, repeated data updates, and device-specific archival workflows.
Single-sided / Double-sided DVDsA single-sided disc stores data on one side. A double-sided disc can store data on both sides, usually requiring you to flip the disc.Higher-capacity releases or archives, though double-sided DVDs are less common for everyday use.
Mini DVDSmaller 8 cm discs, compared with the standard 12 cm DVD size.Older camcorders, some portable DVD players, and compact recording devices.
For a simple rule of thumb, choose DVD-ROM for factory-made read-only content, DVD-R or DVD+R for write-once storage, and DVD-RW or DVD+RW when you need to erase and reuse the disc. Choose dual-layer media only when your burner and playback device support it and the project is larger than a single-layer DVD.
DVD Backup Options with DVDFab DVD Copy
Before using a dedicated tool, separate DVD backup into three common cases. For an ordinary data DVD, you can often copy DVD files to a computer or USB drive with File Explorer or Finder. For a home-authored video DVD, you may save the disc structure as a VIDEO_TS folder or ISO image with compatible disc software. For any backup, use only content and access you are authorized to use, keep the copy for personal use, do not redistribute it, and follow applicable US law and relevant terms.
DVDFab DVD Copy is a DVD backup tool that can copy both protected and unprotected DVDs. Its handles common protection systems such as CSS, RC, RCE, APS, and Sony DADC, allowing you to create playable backups without errors. Its GPU acceleration and batch processing enables you to copy large collections efficiently.
There are six modes in the Copy module:
  • Full Disc: This mode copies the entire DVD, including menus and special features.
  • Main Movie: This mode copies only the main movie without any extras.
  • Split: This mode lets you split a DVD-9 into two blank discs.
  • Customize: This mode allows you to choose specific titles or chapters to copy from the source DVD.
  • Merge: This mode enables you to combine two or more DVDs into one.
  • Clone/Burn: This mode lets you clone your DVD in a 1:1 ratio or burn it to a blank disc.
DVDFab DVD Copy backup options for ISO and VIDEO_TS folders
How to Use DVDFab DVD Copy to Back Up Your DVD
Step 1: Download and Install DVDFab
Free download and install DVDFab on your computer. You can obtain it from the official website or click the download button below.
 Free Download
 100% Safe & Clean
 Free Download
 100% Safe & Clean
Step 2: Load the DVD Source
Once installed, open the program and switch to the Copy module. Insert the DVD into your optical drive. The software will detect the disc automatically in many cases. You can also click "+" to load the disc manually, or drag and drop an ISO/DVD folder into the main interface.
How to Backup Protected DVDs By DVDFab DVD Copy
Step 3: Choose a Copy Mode and Customize the DVD
Select a copy mode based on your goal. For example, Full Disc keeps menus and extras, while Main Movie focuses on the main title. Clone/Burn preserves the original audio and video data in a 1:1 copy, while DVD-9-to-DVD-5 compression re-encodes the content to fit the smaller disc; choose DVD-9 output when you want a 1:1 copy. You can also select specific chapters, audio tracks, and subtitles. For content you are authorized to access, save the backup locally as an ISO image or VIDEO_TS folder.
How to copy DVDs with DVDFab DVD Copy
Step 4: Start Copying
After confirming the output location and copy mode, click the "Start" button. Progress and remaining time are displayed, and you can pause or cancel the task if needed.
How to copy Protected DVDs with DVDFab DVD Copy
Frequently Asked Questions
Can I legally back up a DVD I own?
Owning a DVD does not automatically authorize every copying method, because permission to copy content and restrictions on access controls are separate matters under U.S. law. Whether a specific backup is permitted depends on the content, access method, applicable law, and relevant terms.
What should I do if a DVD backup stops?
Confirm that the disc is readable, the DVD drive is connected, and the destination has enough free space, then restart the job with a fresh output folder. Physical disc damage can prevent a complete read; if the backup stops again, install the current version from DVDFab's official download page and contact DVDFab Support.
Can I save DVD episodes as separate files?
Yes. DVDFab DVD Ripper can convert selected episode titles to MP4 or MKV files. DVDFab DVD Copy creates DVD, ISO, or VIDEO_TS folder backups, so its Main Movie mode is not an episode-file export.
Why do some people still keep DVDs?
DVDs are useful for collectors who want physical ownership and do not want to lose access when a title leaves a streaming platform. They also work well when internet access is unstable. Keeping the original disc also preserves access to its menus, extras, and physical packaging.
Can a DVD play in a CD player?
No. A CD-only player cannot read a DVD because DVDs use different data density and reading requirements. Many DVD drives can read CDs, but the reverse is not true. To play a DVD movie or read DVD data, use a DVD-capable player, recorder, game console, or computer drive.
What is the difference between DVD-R and DVD+R?
Both DVD-R and DVD+R are write-once formats that use different recording standards. Playback compatibility depends on the burner, disc quality, player support, and settings such as book type.
For reusable media, choose DVD-RW or DVD+RW, which support repeated writing and erasing in compatible drives.
The Bottom Line
A DVD is more than just a movie disc. It's one of the most influential forms of optical storage in digital history. It bridged the gap between physical and digital media, offering a durable and affordable way to preserve data and entertainment. Even as streaming dominates today's media landscape, understanding what a DVD is and how to keep your collection usable remains valuable. DVDFab DVD Copy creates DVD, ISO image, or VIDEO_TS folder backups. DVDFab DVD Ripper converts DVD titles to MP4 or MKV files.
