Now trimming an MP3 file might seem to be an extremely difficult, and rigorous process for a lot of people, even when it’s not. Thanks to a lot of MP3 Clipper softwares these days, clipping MP3 files is as easy as it can get, and you can trim your favorite MP3 files within just a few minutes, and with just a few simple clicks.
But how do you actually trim an MP3 file? The answer is simple. You trim your favorite Mp3 files with the help of specialized softwares that is known as MP3 Clipper Software. This softwares are designed with the purpose of helping you clip your favorite audio files without any trouble. Most of the Mp3 Clipper applications ask you to select the file, and specify the start & stop location, and the clipper application takes care of the rest for you.
Now, if you make a quick search on Google on Mp3 clippers, you will find plenty of offline & online softwares that claim themselves to be the best MP3 clippers on the internet. However, not all of these softwares work the way they advertise. A lot of such online sites are either filled with unnecessary advertisements that can put your personal privacy at risk. On the other hand, there are a lot of downloadable MP3 clippers that are nothing but malicious softwares that could be a potential hazard for your computer if not dealt with immediately. in this article, we will provide a detailed review of the wonderful MP3 clipper.
DVDFab Video Cruise Software: Wonderful MP3 Clipper
The DVDFab Video Cruise as the name suggests is an all-in-one video editing application, which as per its developers, is the best video editing software to date. The developers of the DVDFab Video Cruise application have developed the software, especially for creative minds who want to make some amazing projects using nothing but their creativity, and the DVDFab Video Cruise software.
Although the DVDFab Video Cruise is a dedicated video editing application, it does not mean that it cannot be used to clip your favorite MP3 files. The Mp3 Clipping feature offered by the DVDFab Video Cruise is one of the best in the industry because, in addition to letting you clip your favorite MP3 files, the DVDFab Video Cruise also allows you to edit those clipped files as per your needs & requirements.
The DVDFab Video Cruise application has support for over 1000 audio and video file formats, which means that you can use this software to clip almost every audio file there is in existence.
How to use the DVDFab Video Cruise to Clip your MP3 Files?
Now that we have told you that the DVDFab Video Cruise is one of the best applications for clipping your favorite MP3 files, it is important for us to have a look at how to use the DVDFab Video Cruise to clip MP3 files.
Step #1: Download the Setup File
Before you can start using the DVDFab Video Cruise application, it is necessary to download the setup file first. Now, you might find the setup file for the DVDFab Video Cruise application on several websites, but the best place to download the setup file is from the official website of DVDFab Video Cruise. Once you have opened the official website, you will see a window that looks like the one shown below.
mp3 clipper:How to use the DVDFab Video Cruise to Clip your MP3 Files?
Spot the “Free Download” option, and hit the button. The software would automatically detect your current windows version, and download the best software as per your system specifications. Wait for the setup file to finish downloading.
Step #2: Install the Setup File
Once the setup file has been downloaded successfully, it is time for you to install it on your device. Locate the DVDFab Video Cruise setup file in your downloads folder, and initiate the installation process. Once the process has been initiated, the DVDFab Video Cruise package installer would do the rest for you.
Step #3: Launch the Application
Once the DVDFab Video Cruise software is installed successfully on your device, launch the application. Once done, you will see a window similar to the one shown below that asks you to select the aspect ratio of the software.
Select the aspect ratio as per your requirements, and wait for the application to open. Once the application has started, you will see a window that looks similar to the one shown below.
Step #4: Upload files
Once the application has opened successfully, you need to add files to the software. You can either drag and drop the files on the box that reads “Drag files to import”, or you can choose files saved on your internal storage.
Step #5: Initiate the Trimming Process
After the file has loaded successfully, it is time for you to initiate the trimming process. Finalize the initial and final timelines, and click on the “Start” button to initiate the trimming process. Wait for the process to complete, and then save the files internally on your device’s storage, or export it as per your needs.
DVDFab Video Cruise: Top Features
One of the major reasons why the DVDFab Video Cruise is so popular is primarily because of the features it has to offer. These features make the DVDFab Video Cruise a top pick even amongst professionals, who need to handle complex, and large projects. Following are some of the essential features offered by the DVDFab Video Cruise application.
mp3 clipper:DVDFab Video Cruise: Top Features
Feature #1: Mosaic
The Mosaic tool is one of the best tools offered by the DVDFab Video Cruise because it lets you hide any information on the screen easily and in a discreet manner. All you need is a few clicks, and you are good to go.
Feature #2: Freeze Frame
How often do you watch a video, and there are a few frames in it that have a certain appeal? Quite often, right. The freeze-frame feature offered by the DVDFab Video Cruise is the perfect feature for such occasions because it allows you to freeze the frames of the video you are editing, which helps in creating the perfect still image, something that could never be achieved by a screenshot.
Feature #3: Green Screen Cut Out
The Green Screen Cut Out feature allows users to remove the green screen from the background in their pictures. Users can easily edit these green screens and can either remove them completely or replace them with a background of their choice.
Feature #4: Speech and Text Converter
The Speech and Text Converter feature of the DVDFab Video Cruise application makes voiceovers a really simple task for you. Using this feature, you can not only convert audio to text, but you can also convert text to speech which would help you especially if you are someone who does a lot of voiceovers.
Feature #5: Volume Adjustment
Using the volume adjustment feature of the DVDFab Video Cruise application, you can adjust the volume up to 400%, and add fading in/fading out effects with just the press of a few buttons.
Feature #6: Royalty-Free Music
Copyright is one of the biggest nightmares of any content creator, but the DVDFab Video Cruise has got you covered. When you use this software, you get complete access to hundreds of royalty-free music that you can use in your projects as per your needs, and requirements.
Feature #7: Filters
Filters are one of the most popular features of social media platforms, and these filters can add to the beauty of your project multiple times. There are hundreds of filters available in the DVDFab Video Cruise, and you can use them as per your requirements.
DVDFab Video Cruise: Functions Offered
In addition to the numerous features offered by the DVDFab Video Cruise application, it also offers several functions that might be of immense help to you. Let’s have a look at some of the best functions offered by the DVDFab Video Cruise application.
  1. You can split a large MP4 file into smaller snippets.
  2. You can adjust the frame of the video or crop it in such a way that you only keep those frames of the video that you want. Alternatively, you can also zoom the video as you wish.
  3. You can flip the video any way you want: either horizontally, or vertically.
  4. You can also rotate the videos by 90 degrees or 180 degrees.
  5. You can vary the speed of the video from 0.2x to 5x.
  6. You can separate the audio from the video file as you wish.
Final Thoughts
Overall, the DVDFab Video Cruise is one of the best video trimming or cropping softwares available in the market. The list of features offered by the DVDFab Video Cruise is huge, and they help you a long way especially when you are working on professional projects. In this article, we have told you everything you need to know about the DVDFab Video Cruise application, and we have also included a proper in-depth user guide that would help you use the application with much greater ease.
