How to Enjoy Blu-ray with DVD Player?
2020-07-09 21:22:58
If one day, someone tells you that you can watch Blu-ray movies on a regular DVD player, don’t trust it, as it is technically impossible. That’s because DVD players are not able to read Blu-ray movies, from the perspective of industry standard. But this does not mean you are not able to watch the movie on a regular DVD player. You can convert that Blu-ray movie into regular DVD quality and then play it on a DVD player. To that target, you need Mac Blu-ray to DVD converter software, such as DVDFab Blu-ray to DVD Converter for Mac.
This tip below will tell you how to do that on your Mac:
Convert Blu-ray to DVD on Mac > Step 1: Download, install and launch DVDFab 9 for Mac on your Mac computer;
Convert Blu-ray to DVD on Mac > Step 2: Select Copy option from Option Bar and choose “To DVD” mode, add the to-be-converted Blu-ray ISO file or movie folder from your Mac HDD, and then insert a blank DVD disc (DVD 9 or DVD 5) into your Mac disc tray;
Convert Blu-ray to DVD on Mac > Step 3: Select the output size at the “Output” section according what you’ve inserted in your Mac disc tray, set the “Save to” as your disc tray, too, and then press “Start” button to release the burning.
Note:1. You need copy your Blu-ray movies onto your Mac HDD first if you do not have an external Blu-ray drive connected to your Mac;
         2. By default, program will select the main movie title to convert and burn, if you need more titles, please select them by hand, you can also select to keep the audios and subtitles you wanna keep and dump the rest ones.
Software you need: The latest build of DVDFab 9 for Mac
Product you need order: Blu-ray to DVD Converter for Mac
For more information, visit https://www.dvdfab.cn/blu-ray-to-dvd-converter-for-mac.htm
① Convert & downscale Blu-rays to standard DVDa with high quality
② Burn the converted DVDs to blank discs or save as ISO files/folders
③ Support all types of blank discs like DVD±R and DVD±RW
④ Offer multiple sets of beautifully crafted menu templates
