MP4 is a common format which generally is supported by all playback devices or media player software. If you want to watch a DVD movie on your MP4 or other portable devices, you can rip or convert the DVD into MP4 format. So how can you convert DVD to MP4? Use DVDFab DVD Ripper! DVDFab DVD Ripper is an outstanding and professional ripper tool, which can help you rip your DVD to MP4 quickly.
How to Rip and Convert DVD to MP4: Step 1> Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to MP4: Step 2> Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to MP4: Step 3> Navigate to the profile library on the top left corner of the main interface and choose MP4 format.
How to Rip and Convert DVD to MP4: Step 4> Now you can choose the titles, chapters, audios and subtitles, define the names of the titles, and do advanced settings according to your needs. You even can edit the DVD video with the built-in editor.
How to Rip and Convert DVD to MP4: Step 5> Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
If you want to know more about DVDFab DVD Ripper, please visit https://www.dvdfab.cn/dvd-ripper.htm.
