How to Rip 2D/3D Blu-rays to SBS 3D Videos and Other 3D Video Formats
2020-07-28 06:55:00
Nowadays, 3D TV has entered thousands of households, which makes it possible to enjoy a 3D movie through a 3D TV at home rather than going to a cinema. If you have collected a batch of 3D Blu-ray discs, you can rip and convert them to SBS 3D videos to play them on your 3D TV without using a Blu-ray player and the 3D Blu-ray discs. The conversion would be easy if you have a good Blu-ray 3D to SBS 3D converter at hand. DVDFab Blu-ray Ripper is the best 3D Blu-ray converter that can rip 3D Blu-rays to SBS 3D videos in M2TS, AVI, MKV and MP4 formats in an easy and quick way. Now let’s see the detailed converting steps.
Step 1: Load the 3D Blu-ray source
Run DVDFab 10, go to Ripper module, and load the 3D Blu-ray source according to the instructions on the main interface.
Step 2: Choose a 3D format
Go to the profile library on the top left corner, and click Format > Video > Filter > 3D to choose a 3D format.
Step 3: Customize your 3D video
The main movie title has been selected by default here, but you can also choose other titles. You can also change the title name, choose the chapters, audio tracks and subtitles you want, edit the video and customize your settings. At the “3D” part of the Advanced Settings panel, you should choose the 3D format as “Split Screen” (SBS). You are able to choose the screen size as half size or full size.
Step 4: Select a directory and start the conversion process
Click the “folder” icon to select an output directory to save the output SBS 3D video. And then you can click the “Start” button to start the process of ripping Blu-ray 3D to SBS 3D.
If you are also interested in ripping DVDs to various video/audio formats, please click DVDFab DVD Ripper to learn more.
