How to Rip Video from DVD?
Summary: Are you looking for a tool to rip videos from DVDs? Here is the detailed guide of ripping videos from DVDs with DVDFab DVD Ripper.
- • Copy DVD and Blu-ray files with two backup modes: Full Disc and Main Movie
- • Convert Videos/DVDs/Blu-rays to MKV or MP4 format
- • Work at top speed and export files without quality loss
A lot of movie lovers take great pride in their collection of CDs and DVDs or even going back all the way to VHS tapes in some cases. But while it does feel great to own physical copies of movies, sooner or later everybody runs out of storage space in their home. That is precisely why a lot of collectors are now switching over to digital. With digital movies you don’t need to worry about space as nowadays hard drives of 1 TB or more are cheap and can be found everywhere.
You do need to a good piece of software in order to rip video from DVD but don’t worry because that’s exactly what we’re going to be discussing today. There are plenty of programs that allow you to make digital copies of your DVDs, some of which are even available for free. However, if you’re looking for a professional tool to rip video from DVD your best bet is to go for a premium piece of software like DVDFab DVD Ripper.
Despite being a premium tool, DVDFab DVD Ripper actually offers a 30-day free trial so it’s possible to try it out without spending any money. If you’re looking for software that you can use over a long period of time you’ll find that the full version of DVDFab DVD Ripper is well worth the investment. Ripping video from DVD is extremely fast and simple with this software and you also get all the features you will ever need.
With DVDFab DVD Ripper you can take DVD discs, DVD folders or even ISO image files and convert them to a wide variety of different formats like MP4, AVI, MKV and many more. These files can then be played not only on your computer but also on mobile devices like smartphones, tablets and certain gaming consoles. To make the conversion process as easy as possible, DVDFab DVD Ripper comes with batch conversion, file merging and many advanced editing options that let you customize the output file to your specific needs.
The sleek and intuitive interface makes it very simple for anyone to load up a DVD and start ripping within seconds. However, if you’ve never used a software program like this before you may not know where you should start. Well, don’t worry about it because we’re here to teach you how to rip video from DVD so that you can make the most out of this software. Ripping video from DVD is pretty straightforward but it’s always helpful to have a step-by-step guide just in case you need it. With that in mind, let’s take a look at how the process works.
Step 1. Open DVDFab and then go to the Ripper section found in the top menu. Here you can quickly add DVDs by clicking the “+” symbol in the middle or simply by dragging files into this area. Remember that DVDFab DVD Ripper supports batch conversion so feel free to add as many files, folders or ISO images you want.
Step 2. In order to select the output format, click on the Profile Switcher in the top left corner and then pick a suitable format. Here you can also pick Audio if you only want to extract the sound or pick a specific Device that you want to play the output file on. There are many formats and devices to choose from so make use of the filters to make the search easier. You can add additional files by clicking the Add button next to the Profile Switcher or combine multiple files into one by clicking the Merge button.
Step 3. Before you start ripping the video from the DVD you can make a few other modifications to the output file. For example, you can click on the name of the movie to change its title or you can choose to extract only certain chapters from the DVD by clicking on the Choose Other Titles button. And you can also choose the audio tracks and subtitles you want.
A few more important buttons to keep an eye on can be found to the right of the title. You can use these to access the Advanced Settings where you can modify things like resolution, frame rate, video and audio quality, sample rate, and more. Meanwhile, the Video Edit button allows you to crop or trim the video, adjust brightness and contrast, add subtitles and even add watermarks.
Step 4. Now that we’ve made all the modifications we want we can start ripping the video from the DVD. To do this first pick a destination by clicking the folder icon found at the bottom. Now simply click the Start button and wait a few minutes for software to finish the conversion process. It’s worth noting that you can pause this process at any time if you need to and then resume it at a later time.
