Top 3 Best MP4 Players For Android
Summary: Looking for the best MP4 player for Android to enjoy MP4 videos on smartphone freely? Here is the list of top 3 best Android MP4 players for your reference.
• Offer two display modes: PC Mode and TV Mode
• Provide menu support for DVD and Blu-ray discs, folders and ISO files
• Play 4K UHD, HEVC videos and 3D media contents with HDR 10 and HD audio output support
MP4 is the common video format that is mostly used by smartphones, PCs, HDTVs, and media players. MP4 is the default video recording format on Android because of its compatibility across multiple devices. MP4 videos may vary in size, quality, and resolution. Most large resolution MP4 videos can’t be played on small screen Android phones. Today almost every Android phone is using Google photos as the default MP4 video player except for some manufacturers that employ their own custom MP4 video players in Android UI. Google photos sometimes fail to play MP4 videos or movies which are shot on other Android phones and downloaded from the internet.
So, in this post, we will be listing the best MP4 players for Android smartphones with maximum compatibility.
1. MX Player for Android
2. Xplayer (Video player all formats)
3. BS Player for Android
MX Player is one of the most popular Android MP4 players. Its popularity lies in the fact that it supports almost every video format. It provides Full HD video playback on Android smartphones and tablets. With MX player you can turn your smartphone or tablet into a mini home theater. MX Player’s UI is also very easy to use as it provides on-screen controls to change settings during video playback. On-screen touch controls will let you control the sound, brightness, and the player’s seek bar. You can also lock in the device rotation to make it fixed. MX Player fully supports subtitles and you can see them while watching a movie. Just make sure you have the subtitles file (.srt) place in the same folder as of the movie.
MX Player can also play dual audio MP4 movies. A dual audio language movie is not supported by all players. Most android MP4 players will pick up the default audio without giving an option to select the audio. But MX android MP4 player lets you choose the audio language if it is a dual audio movie. Have a look at the UI of the MX player.
Full HD/4K Ultra HD MP4 Player for Windows 10
Are you a fan of Full HD or 4K Ultra HD movies? Do you want to watch them on a Full HD or a 4K screen? Then check out DVDFab Player 5 for Microsoft Windows. I know high definition TVs ( Full HD or 4K) come with their own media player which can play MP4 movies but they fail to deliver real eye-soothing entertainment on your TV screen. The reason being here is the hardware used on the TV. DVDFab Player 5 is designed to work with the top-notch PC hardware having powerful graphics cards like the Nvidia GeForce GTX employing the Pascal architecture.
DVDFab Player 5 is the only MP4 player for Windows of its kind employing the HDR10 technology which delivers crystal clear image on the TV screen. The exciting thing about DVDFab Player 5 is that it can be used in two modes TV mode and PC mode. So TV mode makes it the number one MP4 player for Windows 7/8/10 if you want to bridge the entertainment between your PC and TV via an HDMI cable. DVDFab Player 5 is specially designed for high-end graphics, however, it will work with any graphics chip but the viewing experience will be degraded. So if you have a PC gaming rig or a computer with good hardware then you can turn it into a home theater system. All you need is a 4K TV, HDMI cable, and most of all DVDFab player 5 which will do the entire magic and give you a life-like viewing experience on your TV screen with HDR10 feature. Have a look at the player’s UI below.
DVDFab Player 5 is fully compatible with all Blu-ray formats and supports Dolby Atmos, Dolby TrueHD, DTS-HD Master and DTS:X audio. And don’t forget 3D movies because they are fully supported by DVDFab Player 5. DVDFab Player 5 will be soon getting an advanced 3D upscaling algorithm update which will allow you to watch 2D content in 3D mode. Isn’t that nice? A player that upscales 2D movies to 3D, all you need is 3D glasses. I say DVDFab Player 5 is the best MP4 and Blu-ray 4K ultra HD player for Windows 10. But this may not convince you fully. The only way to get yourself fully convinced is to test the software fully for 30 days without paying a penny. In these 30-days you can try DVDFab Player 5 with multiple video formats, different PC hardware, and multiple TV screens. This will finally let you know how the player works on different PC hardware and TV screens. So go ahead, download it for your Windows 7/8/10 PC and start testing.
2. XPlayer (Video player all formats)
XPlayer is an easy to use Android MP4 player. It is a tiny MP4 player that weighs only 11MB in size but has powerful video playing capability. The Xplayer provides a wide range of on-screen controls including a night mode. It can also download subtitles for any movie and can play dual audio movies. Apart from these features, you are allowed to customize the sound equalizer. This android MP4 player also lets you change the video aspect ratio. Have a look at the UI of Xplayer below.
3. BS Player Free for Android
BS player is another free android MP4 player with all essential features like on-screen controls, dual audio support, and easy to use UI. The BS player only weighs 9MB in size. The main reason for using BS player as an Android MP4 player is that it is easy to use and features all the most of the main controls on the screen. You can make changes to playback settings, audio, subtitles, and aspect ratio. BS player also supports pop up play just like Xplayer.
The above post listed the three best MP4 players for Android with an MX player being at the top spot. MX player MP4 player for Android gives more options while playing a video. So there are a lot of customization options in the MX player. But if you want an Android MP4 player with a small size then go for Xplayer. Xplayer is easy to use and provides most of the controls on the screen. BS player is another MP4 player for Android and can be used if you want a simpler player. For watching 4K ultra HD content on your TV or PC we recommended DVDFab 10 for Windows. It is currently the best MP4 player for Windows with HDR10. You can try it free for 30-days before purchase and your transaction is backed by a 30-day money back guarantee. So no worries, now it’s your turn to check it out.
