How to Play DVDs on PS4 in 3 Ways [Free & Easy]
Summary: Does the PS4 play DVDs? How to play DVDs on PS4 easily? What’s the best alternative PS4 DVD player? If you are a game console user, these questions are crucial to you. Read this post to master three ways to play DVDs easily, namely, to play DVDs on PS4 directly, play DVDs via USB stick, and rip DVDs to compatible videos for better playback on mobile devices.
- • Copy DVD and Blu-ray files with two backup modes: Full Disc and Main Movie
- • Convert Videos/DVDs/Blu-rays to MKV or MP4 format
- • Work at top speed and export files without quality loss
Does PS4 play regular DVDs? Can PS4 play DVDs? Want to know how to play DVDs on PS4 free and easily? Let's start with the meaning of PS4. PlayStation 4, short for PS4, is a wonderful video game console developed by Sony for game enthusiasts. But can the PS4 play DVDs?
The truth is that PS 4 is not merely a game console but also can be used as a multimedia player to play DVD/Blu-ray movies and various video files including 4K videos watching free movies on PS4 is great, but you may encounter some annoying playback issues due to various known or unknown reasons. To tackle the DVD playback problems completely, you can convert your DVD to PS4 video formats. So in this article, we will show you how to play DVDs on PS4 directly and how to rip DVDs to PS4 video formats and then play movie on PS4 through a USB stick.
Part 1: How to Play DVDs on PS4 Directly
Does PS4 play regular DVDs? What are PS4 video formats? All the DVD formats including DVD-ROM, DVD-R/RW, and DVD+R/RW are supported by PS4, but to make sure you can play your DVDs successfully, you had better update your PS4 to the latest system version. The playback of DVDs on PS4 is pretty easy, and you can begin by inserting a DVD disc into the disc tray of your PS4. In this sense, you have come to an easy PS4 DVD player. Can PS4 play 4K Blu ray? Click here to find more.
Now let's look at how to play DVDs on PS4 easily.
- Step 1: Turn on the PS4, and log into your account if necessary.
- Step 2: Insert the DVD you want to play into the optical drive of your PS4 DVD player.
- Step 3: Then the dynamic menu will pop out, and you should locate the disc icon and hit the play button to play the DVD movie.
Can you watch regular DVDs on PS4? It is simple to use PS4 to play DVD discs, but you may meet various playback errors that prevent you from watching free DVD movies on PS4. Problems caused by the internet connection or improper assembly of the connectors, DVD dust, etc. are easy to be solved, but errors from scratched disc or region code limitations cannot be fixed.
Does PlayStation play DVDs? There is still another way to play the movies on scratched DVD discs or DVD discs with region code on PS4. You can use DVDFab DVD Ripper to rip and convert your DVDs to PS4 or PS4 compatible formats and then play the converted DVD movies on PS4 with the best free media player.
Part 2: How to Rip DVDs to PS4 Compatible Videos
Can you play DVDs on PS4? DVDFab DVD Ripper is the best DVD to PS4 converter that can convert any DVDs (include scratched DVDs) to PS4 or PS4 video formats like MKV, AVI, MP4, and PS4 audio formats like MP3, AAC, and more in an easy and quick way. It can remove the DVD region codes as well as other copy protections completely and permanently. With the employment of the latest hardware acceleration technology, the DVD to PS4 converter can convert DVDs to high-quality videos at a lighting fast speed. So, 'PS4 won't play DVD' doesn't exist with the help of a PS4 DVD player.
In DVDFab DVD Ripper, there are also many customization tools for you to tweak your settings like codec, resolution, frame rate, etc., and edit the video by cropping, trimming the video, add watermark, and subtitles, adjusting picture values, etc. All the advanced options are easily found on the clean interface, so if you want to rip DVDs to PS4 simply, you can just load the DVD source, choose the PS4 profile and click the Start button. Now let’s check how to rip DVD to PS4 to play a movie on PS4 easily.
Step 1: Does PS4 play regular DVDs? Run DVDFab 12, go to the Ripper module and insert the DVD disc you want to rip. Then DVDFab will load the DVD source automatically.
Step 2: How to watch free movies on PS Vita? In order to download movies on PS4, hit 'Choose Other Profile' > 'Device" > 'Sony' to select the PlayStation 4 as the profile. If you want to convert the DVD to a certain format you like, you should click the Format tab instead.
Note that if you aim to upscale video, you are advised to enable the Enlarger AI option, which is embedded into DVDFab 12 to help users to enhance the video quality as desired. It is an AI upscaling program designed to upscale video from 480p to 1080p, or from 1080p to 4K. However, DVDFab Enlarger AI is a bundled program that can be only used with DVD Ripper, Blu-ray Ripper, DVD to Blu-ray, and Video Converter. But, it is totally free for you to play movies from USB on PS4.
Step 3: Does PlayStation play DVDs? Yes. Now you are able to customize the video in your way. The main movie title has been selected by default here, but you still can choose other titles when you rip DVD on PS4.
Then you can change the title name and choose the chapters, audio tracks, and subtitles you want.
When you rip DVD to PS4, you also can click the Wrench icon to customize your settings like codec, frame rate, resolution, etc., and use the built-in editor to set the aspect ratio, trim and crop the video, add watermark and subtitles, adjust picture values, etc.
Step 4: How to put movies on PS Vita? Navigate to the bottom of the main interface and click the Folder icon to select a directory to save the output video. And then you can click the Start button to start the process of converting the DVD to PS4.
Can you play DVDs on PS4? Does PlayStation play DVDs? Follow the steps above and rip DVD to PS4 video formats using DVDFab DVD Ripper. We are sure that you can have the best answer to can ps4 play DVDs. Click the following button to get the latest DVD/Blu-ray ripper software from DVDFab.
Part 3: How to Play Converted DVDs on PS4 via USB
You are close to watching free movies on PS4. When the conversion is complete, you can put the PS4 supported videos on your USB stick that can be connected to your PS4 and then play it. But before playing the video, you need to download and install the Media Player app on the PlayStation Store first. Just go to the PlayStation Store, find the app, and install it.
Below are the detailed steps of playing the converted DVD on PS4 through USB.
- Step 1: Open Media Player. If your USB storage device is on the same network as your PS4, it will be detected automatically.
- Step 2: Select the USB device.
- Step 3: Find the DVD video and click it to play it.
Of course, if you are a DVDFab fan with DVDFab Player 6 at hand, it will be more convenient to play the converted PS4 DVD to video files on the best 4K media player.
Can you watch regular DVDs on PS4? To sum up, does PS4 play DVDs? YES! PS4 can play commonly used DVDs. How to play DVDs on PS4 in different ways? But if there are problems when playing a DVD PS4, you can rip and convert it to PS4 compatible formats and then play it through a USB storage device without any limitations.
PS4 can also be used to play 4K videos but not 4K Ultra HD Blu-rays, but you still can enjoy your 4K Ultra HD Blu-ray movie on PS4 if you convert the 4K UHD Blu-ray to PS4 supported 4K video format. Click How to Rip UHD Blu-rays to learn the steps of ripping 4K UHD Blu-rays to 4K videos.
Other Articles Recommended:
Choose the Best Free AnyDVD Alternatives for a Safe DVD Rip
Everything You Need to Know about Dear Evan Hansen
How to Decrypt with DVD/Blu-ray/Text Decryption Tools Free
Disney DVD Collection, Movie, Song for Sale & Rip
What Is Streaming 2022 [The Best Video Streaming Service and Device]
