If you are a Mac user and have collected a great number of DVD movie discs, you may want to clone these DVD discs on your Mac for backup. How to clone DVD discs on Mac? The DVD clone job would be very easy if you have a powerful DVD cloner at hand. DVDFab DVD Copy for Mac is the best DVD Cloner for Mac that allows you to copy and clone DVD discs on Mac with only a few minutes and several mouse clicks. The output DVD would share the same quality with the original DVD movie. Here is the guide of how to use this Mac DVD cloner.
Step 1: Choose the Clone/Burn mode
Run DVDFab 10 on your Mac, choose the Copy module and go to the mode switcher at the top left corner to choose the Clone/Burn mode.
Step 2: Load the DVD source
Insert the DVD disc you want to clone or burn to your disc drive, and then DVDFab will load the DVD movie automatically.
Step 3: Select a directory
Go to the “Save to” part to select an output directory. If you want to burn the DVD movie to a blank DVD disc, you should first insert a DVD-5/9 (choose according to the size of your DVD movie) and then select your optical drive from the drop-down list box as the directory. If you want to copy the DVD to an ISO file, you should click the “image” icon to select a directory.
Step 4: Start the clone process
Click the “Start” button to start the process of cloning the DVD movie disc.
If you also want to clone Blu-rays on your Mac, you can try this Blu-ray Cloner for Mac.
