ARCHOS used to produce top quality portable video players, which are now still in popularity. If you have one and are running short of instant videos for it, you can convert your DVD movies into ARCHOS ready videos. With just a versatile DVD ripper software, you can do it quickly on your computer. Look into this tip below to check how you can do that with DVDFab DVD Ripper.
Move on to see the details:
Convert DVDs for ARCHOS: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Convert DVDs for ARCHOS: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Convert DVDs for ARCHOS: Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find ARCHOS from Profile Library, Device column and PVP section, then press "OK" button, next just hit  “Start” button at the Main Interface to go converting.
Note: selecting ARCHOS profile from the built-in Profile Library is the key point of the whole process.
Product you need order: DVD Ripper
For more information, just move on to DVDFab DVD Ripper page.
