How to Rip DVD for PS3 with DVDFab DVD Ripper?
05/27/2020
PS3, short for PlayStation 3, is a home video game console developed by Sony Computer Entertainment. But it also can be used as a DVD player to play DVD movies. There are two ways to watch your DVD movie on PS3: you can either put the DVD disc into its disc tray to watch the movie directly or convert the DVD to PS3 to watch the movie via its internal HDD. If you choose to convert DVD to PS3, you need a piece of DVD ripper software. DVDFab DVD Ripper would be the one you need. Now let’s have a look at how to rip DVD for PS3.
Step 1: Load the source
Run DVDFab 10, go to Ripper module and load the source.
Step 2: Choose the Play Station 3 profile
Navigate to the profile library on the top left corner of the main interface and choose Device >Sony >Play Station 3(MP4) or Play Station 3(VOB).
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and define the name of the chosen title. If you want, you can also click the “Advanced Settings” icon to customize your settings and click the “Editor” icon to edit the video.
Step 4:Select a directory and start the ripping process
Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the process of ripping DVD to PS3.
Ok, done. You can enjoy the converted video on your PS3 in a few minutes.
DVDFab not only can rip DVD but also provides Blu-ray ripping solution. If you want to rip Blu-ray to various video/audio formats and devices, you can try out DVDFab Blu-ray Ripper.
