Is there a best way to watch videos on XBox 360? The first intention Microsoft rolled out this device if for gamers to enjoy their loved games at home. But, you will find that there are a lot of gamers also treat their XBox 360 as their video players. So, how to easily and efficiently find videos that can play on this box becomes a much talked question. The solution is to get a DVD ripper software which has the power to rip DVDs for this box. Is there one? Sure, DVDFab DVD Ripper is exactly what you are talking about.
Read on to see details:
Convert DVDs for XBox 360: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Convert DVDs for XBox 360: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Convert DVDs for XBox 360: Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find XBox 360 from Profile Library and press "OK" button, then just hit  “Start” button at the Main Interface to go converting.
Note: selecting XBox 360 profile from the built-in Profile Library is the key point of the whole process.
Product you need order: DVD Ripper
For more information, just move on to DVDFab DVD Ripper page.
