Copy DVDs with 6 Different Modes: Clone, Full Disc, Main Movie, Customize, Split, Merge
2020-10-29 05:59:29
Sometimes you may want to clone several pieces of your DVDs for backup or for you to playback in different places. Then what you need is a DVD clone tool. DVDFab DVD Copy is a great DVD clone tool which can help you clone your DVD with only several steps. Moreover, supported by advanced technologies, it can clone DVD at a pretty fast speed. Now, let’s have a look at the clone process.
How to Clone DVD with DVDFab DVD Copy: Step 1> Run DVDFab 10, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose Clone/Burn mode.
How to Clone DVD with DVDFab DVD Copy: Step 2> Load the source.
How to Clone DVD with DVDFab DVD Copy: Step 3 > Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "image" icon is to save the output as an ISO image file.
How to Clone DVD with DVDFab DVD Copy: Step 4> Click the "Start" button to start the clone process.
Note:
If you choose to save the output to a blank disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the clone process.
For more detailed information about DVDFab DVD Copy, please visit https://www.dvdfab.cn/dvd-copy.htm.
