How to Rip and Convert DVD to AVI with DVD to AVI Ripper?
2020-06-24 02:17:19
Sometimes you may need to convert DVD videos to AVI video format to play it on your tablet or other portable devices, do you? DVDFab DVD Ripper is an excellent DVD to AVI converter tool for users to convert DVD to AVI. You can try DVDFab DVD Ripper.
How to Rip and Convert DVD to AVI: Step 1> Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to AVI: Step 2> Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to AVI: Step 3> Navigate to the profile library on the top left corner of the main interface and choose AVI format.
How to Rip and Convert DVD to AVI: Step 4> Now you can choose the titles, chapters, audios and subtitles, define the names of the titles, and do advanced settings according to your needs. You even can edit the DVD video with the built-in editor.
How to Rip and Convert DVD to AVI: Step 5> Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
If you want to get more information about how to rip DVD, please go to https://www.dvdfab.cn/dvd-ripper.htm
