Does your smart phone, tablet, or video player device supports to play DivX or XviD encoded AVI videos? If yes, then you can convert your DVD movies into DivX or XviD encoded AVI videos by your own hands at home with an efficient DVD to DivX and XviD ripper software. By doing this, you can save a damn lot of time to find and buy online videos. So, why not! DVDFab DVD Ripper will help you do that, with just a few mouse clicks.
Step-by-Step tips:
Rip DVDs DivX or XviD Videos: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Rip DVDs DivX or XviD Videos: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Rip DVDs DivX or XviD Videos: Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find DivX or XviD profiles from Format column, AVI section in the Profile Library and press "OK" button, then just hit  “Start” button at the Main Interface to go converting.
Note: there are a couple of DivX and XviD profiles in the Profile Library, you can choose either of them.
Product you need order: DVD Ripper
For more information, just move on to DVDFab DVD Ripper page.
