How to Rip and Convert DVD to ZUNE with DVD to ZUNE Ripper?
2020-05-28 03:26:35
Want to watch your DVD movie on your ZUNE? Just use DVDFab DVD Ripper to do this. It can rip DVD to various videos and can be used as DVD to ZUNE ripper for outputting video for ZUNE. It’s easy to use, and strong in the customization power. Next let’s have a look at it through this task.
Step1: Start up DVDFab 9, choose Ripper option, and insert DVD into optical drive, or drag and drop the DVD folder/ISO on your PC into the program, then DVDFab will load it in. The longest movie title is auto selected, and its audio tracks and subtitles can be freely changed.
Step 2: Open Profile list, navigate to Device, to Microsoft, then choose a .h264 or .wmv profile for ZUNE, since they are profiles for video.
Step 3: Click Advanced Settings to set video and audio parameters if you’re professional at this. Or just leave the default settings where they are.
Back to the last interface, to click Edit button to go to Video Effect window. You can resize source aspect ratio and frame resolution of the video. And crop the image for the output video.
Step 4: Go back to the main interface, preview the title in real time, then, if everything is OK, hit Start button to start conversion.
During the process, you can: monitor progress info; preview progress with images; set auto shut down or exit program for the time when all tasks are done.
OK, Done. More details about this DVD ripper, just visit: https://www.dvdfab.cn/dvd-ripper.htm
