How to Rip DVD with DVDFab DVD Copy?
2020-05-28 03:26:29
Sometimes you may want to rip your DVD movies onto your hard drive for backup if you do not have a blank DVD disc at hand. Then at this time you can use DVDFab DVD Copy, which can help you rip your DVD quickly and easily. Now please have a look at the following tip on how to rip DVD with DVDFab DVD Copy.
How to Rip DVD with DVDFab DVD Copy: Step 1> Run DVDFab 10, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes to choose. Here I take Main Movie mode as an example.
How to Rip DVD with DVDFab DVD Copy: Step 2> Load the source.
How to Rip DVD with DVDFab DVD Copy: Step 3> After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitlesand do advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
How to Rip DVD with DVDFab DVD Copy: Step 4> Navigate to the bottom of the main interface to select a directory to save the output DVD: to select a directory by clicking the "folder" icon is to save the output as a DVD folder on your hard drive; to select a directory by clicking the "image" icon is to save the output as an ISO image file on your hard drive.
How to Rip DVD with DVDFab DVD Copy: Step 5> Click the "Start" button to start the copy process.
Note:
You are not allowed to do any operation to customize your output DVD on Clone/Burn mode; on Full Disc mode, you cannot choose the titles, chapters, audio tracks and subtitles but you can do advanced settings.
For more detailed information about DVDFab DVD Copy, please visit https://www.dvdfab.cn/dvd-copy.htm
