Part One: Introduction
If you have a collection of DVDs that you want to convert to digital files for safekeeping or easy access, creating an ISO file is a great solution. An ISO file is a complete disc image of a CD or DVD bundled into a single file, including the file system and directory structure.
Being single files, they are easier to store and organize than outright copies of the folders and files on a disc would be. You can store them on a USB drive, cloud storage, or other portable devices, making it easy to take your entire DVD collection with you on the go. ISO files can also be played on most media players and operating systems, which is a versatile option for those who want to access their DVD collection on various devices.
So, how to create ISO image files from your DVDs on Windows 11, 10, 7, or Mac? Below are the best solutions respectively. Let's get started and unlock the potential of your DVD collection!
Part Two: How to Create ISO from DVD on Windows
As you may have already awarded that Windows doesn’t have a built-in way to create ISO files from DVDs. Therefore, you may need a third-party program to help you. Here, we would like to recommend the following ISO creators that will be most beneficial to you.
DVDFab DVD Copy
DVDFab DVD Copy
DVDFab DVD Copy
DVDFab DVD Copy allows you to losslessly backup or compress any DVD disc to a blank disc directly or save it as an ISO image file or folder on your hard drive.
Available on: Windows 11/10/8.1/8/7 and MacOS 10.10-13
Major Features:
  • Decrypt any protected DVD automatically
  • Offer 6 different copy modes to burn ISO files from any DVD discs
  • Better preserve the original video and audio quality
  • Support customizable options and batch copying at lightning speed
  • Remove Cinavia watermarks
  • Clean and navigable interface
Cons:
  • Only offer a 30-day free trial
How to create an ISO image file from your DVD with DVDFab DVD Copy:
Step 1: Get DVDFab DVD Copy software on your computer. It should be pointed out that no junkware is packed with this ISO maker.
Step 2: Once you launch up it, click on the “Copy” tap>select a copy module>insert your DVD disc/add your DVD folder via that plus button.
how to copy DVDs guide 1
Step 3: To customize your file, you can define the volume label and change other copy options, such as picking the specific chapters, audio tracks, and subtitles that you want to convert to ISO file. Then select your output directory as ISO file at the bottom of the window.
how to copy DVDs guide 2
Step 4: Last, hit that "Start" button to create an ISO file as desired. DVDFab will complete the DVD copy task with lightning speed and high quality.
Tips: After a 30-day trial period, DVDFab DVD Copy will automatically upgrade to DVDFab HD Decrypter, which is completely free but has limited features. Use it to create ISO images from your DVD discs on a Windows or Mac system for free as long as you want if it can fulfill your needs.
MagicISO Maker
MagicISO is a powerful CD/DVD image file creation tool. It can open, create, edit, and extract CD and DVD image files, and it can make an ISO file from a DVD, CD-DRM, or hard disk while also handling bootable data. MagicISO also includes a built-in CD/DVD burning tool that allows users to burn ISO files to physical discs.
Available on: Windows XP, Vista, 7, 8, 10
Major Features:
  • Support all known CD image type
  • Directly edit CD/DVD image file
  • Backup CD/DVD to your hard disk
  • Make bootable CD/DVD
  • Windows Explorer Embed
Cons:
  • Not friendly to the beginners
  • Not free
  • Difficult to uninstall
How to burn DVD data to ISO image files using MagicISO Maker:
Step 1: Insert the DVD into your computer's disc drive, open MagicISO, and select the "File" menu. From there, select "New" and then "CD/DVD Image".
Step 2: In the "CD/DVD Image" dialog box, select the source drive that contains the DVD and choose the output file format as "Standard ISO Image".
Step 3: Then, click "OK" to start the ISO creation process.
WinCDEmu
WinCDEmu is an open-source CD/DVD/BD emulator - a tool that allows you to mount optical disc images by simply clicking on them in Windows Explorer. If you have downloaded an ISO image and want to use it without burning it to a blank disc, WinCDEmu is the easiest way to do it.
Available on: 32-bit and 64-bit Windows versions from XP to Windows 10
Major Features:
  • One-click mounting of ISO, CUE, IMG images
  • Supports unlimited amount of virtual drives
  • Allows creating ISO images through a context menu in Explorer
  • Small installer size - less than 2MB
  • Does not require rebooting after installation
  • Translated to more than 20 languages
Cons:
  • Hard to uninstall
To use WinCDEmu to create an ISO image from a DVD, please follow these steps:
Step 1: Download and install WinCDEmu on your computer and insert the DVD into your computer's DVD drive. Right-click on the DVD drive icon in Windows Explorer and select "Create ISO Image."
Step 2: In the WinCDEmu window that appears, choose the location where you want to save the ISO file and give it a name. Select the format of the ISO file (ISO or BIN) and set the compression level if desired.
Step 3: Click "Create" to start the process of creating the ISO file. Once the ISO file is created, you can use it to burn a new DVD or mount it as a virtual drive using WinCDEmu or other software.
WinCDEmu
BurnAware Free
BurnAware is a full-featured ISO file maker that can create ISO images from DVDs, CDs, and BD discs. Users can benefit from BurnAware's advanced options, including control of boot settings, ISO levels, and direct copying, etc,. With it you can create data, music, video, and bootable discs, as well as working with images.
Available on: Windows XP, Vista, 7, 8, 8.1, 10, 11, both 32 and 64 bit.
Major Features:
  • Create ISO Images from DVDs free
  • Super-intuitive user interface
  • Support lots of media types
  • Offer three versions
Cons:
  • Premium and Professional versions not free
  • No disc-to-disc copying
  • No content menu integration
How to create an ISO image from a physical DVD using BurnAware:
Step 1: Open BurnAware and select "Copy to Image" option from the main menu. Insert the DVD into your computer's DVD drive.
Step 2:In the "Source" section, select your DVD drive from the drop-down list. In the "Destination" section, choose the location where you want to save the ISO file.
Step 3:Under the "Image Settings" section, select the "ISO" option from the "Image Type" drop-down list. Choose the "File System" as per your requirement. Configure other settings such as "Volume Label," "File Names Length," etc.
Step 4:Click on the "Copy" button to start the process of creating an ISO image.
Part Three: How to Create ISO from DVD on Mac
Disk Utility
Differently to Windows, macOS offers a built-in way to convert DVD to ISO format. That is Disk Utility, which is a built-in macOS application that allows users to manage and maintain their storage devices, including hard drives, solid-state drives, USB drives, CDs, and DVDs.
Major Features:
  • Create disk images of CDs, DVDs, or other disks
  • Mount and unmount disks and disk images
  • Restore previously created disk images to a disk
You can utilize the Disk Utility and do the following things:
Step 1: To start with, please press Command+Space to open the Spotlight search box. Type “Disk Utility”, and then press Enter.
Step 2: Insert a disc once you have entered > click on the File menu > put your mouse cursor on New > select the Disc Image from [Device].
:PART TWO: Create ISO from DVD on Mac
Step 3: Select the “DVD/CD master” as the format and leave encryption disabled. As a result, the Disk Utility will create a .cdr file from the disc which is practically as good as an ISO file.
Step 4: In order to convert it to an ISO file so that it can be used on other operating systems, you can run the following command on a Terminal Window.
Roxio Toast
If you prefer a third-party program to help you convert DVD discs to ISO images on Mac, then you can try the DVDFab DVD Copy software (mentioned above) and Roxio Toast program. This is a leading digital media manager and DVD burner for Mac and delivers everything you need to perfect all of your digital media projects. Roxio Toast is the easiest way to capture, convert, edit, secure, and publish your videos, photos, music and files -to disc, popular file format, or online.
Major Features:
  • Support numerous formats
  • Burn music, photos, and data to DVD with drag and drop controls
  • Convert DVDs to digital files
  • Recover damaged discs
  • Support multiple languages
Cons:
  • Can’t deal with protected files
  • Only available on Mac OS X 10.11 and above, 64-bit application
How to create a standard ISO image file with Roxio Toast:
Step 1: Open Roxio Toast. Insert the DVD you want to create an ISO of. In the main window, click on "Copy" in the left-hand sidebar. Select "Image File" as the copy format.
Step 2: Choose the DVD drive that contains the disc you want to copy. Select "DVD-Video" as the format if prompted. Choose a destination folder where you want to save the ISO file.
Step 3: Click the "Record" button to start the ISO creation process.
:Roxio Toast: Alternative tool to create ISO from DVD on Mac
Part Four: Conclusion
Creating ISO images from DVDs makes it possible for you to play your preferred discs even when there is no disc player around you. So pick up your favorite one, and then start the trip to enjoy your DVDs better. And if you need to burn ISO to DVD on Windows or Mac rather than creating ISO images, there are also many applications here to help you cope with this issue.
